Extend the platform,
empower your team.
Reporting health and resource consumption of deployed extensions.
ExtensionThis extension provides you with deep insights into the health of all extensions in your environment created with the Extensions 2.0 framework. It provides unified analysis capabilities for Ops, DevOps and IT Admins.
For more information on the Extensions 2.0 framework, see Extensions 2.0 concepts in Dynatrace Documentation.
Note: The data used is collected for statistical purposes, the customer does not pay additional fees for it.
Activate the extension using Dynatrace Hub.
The extension comes with two pre-defined dashboards containing the following sections:
OK
and IDLE
are classified as errors. Most common errors shows the most common error states. You can find detailed information about the latest error using the Configuration log events section.Note: After creating the monitoring configuration for chosen extension, in the configurations table there will be showing a magnifying glass (look at the last screenshot) that enables go to the Unified Analysis screen for this monitoring configuration.
Added:
Improved:
No release notes
