How does Mission Control pro-active support work?
Dynatrace Managed automatically solves many common maintenance and support challenges for you. With Dynatrace Mission Control, you get fully automated management capabilities in a pro-active way that keep Dynatrace Server secure, reliable, and up-to-date—all while saving you from the hassles of administrative tasks like upgrades and troubleshooting. Once you've granted the required permissions, our Mission Control team can remotely access your Dynatrace Server to assist with upgrades and troubleshooting when you run into problems.
How Mission Control works
To facilitate pro-active support, your Dynatrace Server transmits status information to Dynatrace Mission Control. The only data that our Mission Control team can access comes from the Dynatrace Managed components. At no time can our Mission Control team access your operating system or file system.
Given permission, our Mission Control team can remotely analyze the hardware utilization of your Dynatrace Managed installation and alert you if more resources are required.
Our goal is to provide the highest possible system uptime for UI and monitored data. For more information, check out Dynatrace Managed Mission Control and Service Level Agreement.
What Mission Control does
Dynatrace Mission Control is responsible for sending:
Usage and billing information
Dynatrace cluster health
We gather basic Dynatrace Managed deployment statistics for quick alerting in case of infrastructure issues, and to provide configuration automation. Mission Control gathers such information as number of nodes, status of Dynatrace services, or disk partitions usage. -
Dynatrace Cluster events
Events like server starts/shutdowns, added/removed nodes, and ActiveGate registrations are tracked automatically. Our Mission Control team can remotely analyze and address problems or incompatibilities with your Dynatrace Server, so you don't need to track and react to system events. If you should ever need to contact Dynatrace Support, you won't need to collect the required log files for problem details—Mission Control gathers this data for your automatically. To see the list of Dynatrace Server system events that are automatically logged, click the Events tile on your Dynatrace Managed home page. -
Cluster settings
Our Mission Control team can remotely optimize your Dynatrace Managed settings to ensure optimum performance and stability. -
Software updates
Dynatrace Managed software updates are mandatory and are typically published every four weeks. You can customize the timing of Dynatrace Managed updates (daily or weekly). Updates are automatically communicated to your users at least 24 hours in advance. Dynatrace Managed updates are fast and allow monitoring to continue seamlessly.
Mission Control security
All communication with Mission Control is secure and performed via HTTPS with browser-like certificate checks. All Dynatrace Managed configuration changes are fully audit-logged and each remote access is logged as a separate event (click the Events tile on your Dynatrace Managed home page to view the list of recorded events). The Mission Control team can't access certificates or user credentials. They also can't gain root access to any servers. For analytical information on what is exchanged between your Dynatrace Managed cluster and Mission Control and how often, please check Data exchange between Managed clusters and Mission Control.
