Execute dynatrace.sh bash script
Dynatrace Managed software consists of a number of Dynatrace services that are dependent on each other and should be stopped or started in a particular order. You can use the official dynatrace.sh script with additional parameters to properly start, stop, or restart Dynatrace services. By default, the script is located at /opt/dynatrace-managed/launcher/. Make sure the dynatrace.sh script has executable permissions.
You can execute the dynatrace.sh script with a parameter (start, stop, restart, status, check, pid) as described below.
- start
Starts all Dynatrace Managed required services in the recommended order.[root@localhost]# ./dynatrace.sh start - stop
Stops all Dynatrace Managed required services in the recommended order.[root@localhost]# ./dynatrace.sh stop - restart
Restarts all Dynatrace Managed required services in the recommended order.[root@localhost]# ./dynatrace.sh restart - status
Displays a list of Dynatrace required services and the status of each, including detailed information about each service:[root@localhost]# ./dynatrace.sh status
● dynatrace-firewall.service - Dynatrace Firewall settings
Loaded: loaded (/etc/systemd/system/dynatrace-firewall.service; enabled; vendor preset: enabled)
Active: active (exited) since Tue 2019-07-09 08:34:54 UTC; 1 months 3 days ago
Main PID: 12967 (code=exited, status=0/SUCCESS)
Tasks: 0
Memory: 0B
CPU: 0
CGroup: /system.slice/dynatrace-firewall.service
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
● dynatrace-nodekeeper.service - Dynatrace Nodekeeper
Loaded: loaded (/etc/systemd/system/dynatrace-nodekeeper.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-07-09 08:30:02 UTC; 1 months 3 days ago
Tasks: 69 (limit: 32768)
Memory: 389.2M
CPU: 2h 9min 51.936s
CGroup: /system.slice/dynatrace-nodekeeper.service
├─ 552 /opt/managed/nodekeeper/jre/bin/java -Xms239M -Xmx239M -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=60 -Duser.language=EN -Djava.io.tmpdir=...
├─ 966 /bin/sh /opt/managed/nodekeeper/services/watchdog.sh watch /opt/managed/nodekeeper/services/nodekeeper.sh
└─22167 sleep 60
● dynatrace-cassandra.service - Dynatrace Cassandra
Loaded: loaded (/etc/systemd/system/dynatrace-cassandra.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-07-09 08:37:52 UTC; 1 months 3 days ago
Tasks: 199 (limit: 32768)
Memory: 3.2G
CPU: 17h 1min 32.540s
CGroup: /system.slice/dynatrace-cassandra.service
├─13690 /opt/managed/jre/bin/java -javaagent:/opt/managed/cassandra/bin/../lib/jamm-0.3.0.jar -XX:+CMSClassUnloadingEnabled -XX:+UseThreadPriorities -XX:ThreadPr...
├─13721 /bin/sh /opt/managed/services/watchdog.sh watch /opt/managed/services/cassandra.sh
└─22197 sleep 60
● dynatrace-elasticsearch.service - Dynatrace Elasticsearch
Loaded: loaded (/etc/systemd/system/dynatrace-elasticsearch.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-07-09 08:38:15 UTC; 1 months 3 days ago
Tasks: 58 (limit: 32768)
Memory: 884.6M
CPU: 6h 59min 48.051s
CGroup: /system.slice/dynatrace-elasticsearch.service
├─14802 /opt/managed/jre/bin/java -Xms558M -Xmx558M -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysP...
├─14834 /bin/sh /opt/managed/services/watchdog.sh watch /opt/managed/services/elasticsearch.sh
└─21975 sleep 60
● dynatrace-server.service - Dynatrace Server
Loaded: loaded (/etc/systemd/system/dynatrace-server.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-07-09 08:39:01 UTC; 1 months 3 days ago
Main PID: 2927 (code=exited, status=0/SUCCESS)
Tasks: 475 (limit: 32768)
Memory: 1.6G
CPU: 1d 3h 10min 18.812s
CGroup: /system.slice/dynatrace-server.service
├─15294 /opt/managed/server/dynatraceserver -vm=/opt/managed/jre/bin/java -vmargs -Xms2873M -Xmx2873M -XX:-OmitStackTraceInFastThrow -XX:+UseConcMarkSweepGC -XX:...
└─15302 /opt/managed/jre/bin/java -Dcom.compuware.apm.WatchDogPort=50004 -classpath :/opt/managed/server/lib/ace-1.4.4-dt-2.0.jar:/opt/managed/server/lib/acme4j-...
Aug 12 13:04:05 ip-10-176-32-69 sudo[20856]: pam_unix(sudo:session): session closed for user root
Aug 12 13:04:05 ip-10-176-32-69 sudo[21125]: dynaman : TTY=unknown ; PWD=/opt/managed/server ; USER=root ; COMMAND=/opt/dtrun/dtrun service dynatrace-cassandra status
Aug 12 13:04:05 ip-10-176-32-69 sudo[21125]: pam_unix(sudo:session): session opened for user root by (uid=0)
Aug 12 13:04:05 ip-10-176-32-69 sudo[21125]: pam_unix(sudo:session): session closed for user root
Aug 12 13:04:05 ip-10-176-32-69 sudo[21389]: dynaman : TTY=unknown ; PWD=/opt/managed/server ; USER=root ; COMMAND=/opt/dtrun/dtrun service dynatrace-security-gateway status
Aug 12 13:04:05 ip-10-176-32-69 sudo[21389]: pam_unix(sudo:session): session opened for user root by (uid=0)
Aug 12 13:04:05 ip-10-176-32-69 sudo[21389]: pam_unix(sudo:session): session closed for user root
Aug 12 13:04:05 ip-10-176-32-69 sudo[21665]: dynaman : TTY=unknown ; PWD=/opt/managed/server ; USER=root ; COMMAND=/opt/dtrun/dtrun service dynatrace-server status
Aug 12 13:04:05 ip-10-176-32-69 sudo[21665]: pam_unix(sudo:session): session opened for user root by (uid=0)
Aug 12 13:04:05 ip-10-176-32-69 sudo[21665]: pam_unix(sudo:session): session closed for user root
Hint: Some lines were ellipsized, use -l to show in full.
● dynatrace-security-gateway.service - Dynatrace Active Gate
Loaded: loaded (/etc/systemd/system/dynatrace-security-gateway.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-07-09 08:39:37 UTC; 1 months 3 days ago
Main PID: 16173 (dynatracegatewa)
Tasks: 247 (limit: 32768)
Memory: 410.7M
CPU: 3h 44min 58.189s
CGroup: /system.slice/dynatrace-security-gateway.service
├─16173 /opt/managed/security-Gateway/launcher/dynatracegateway -bg -vm=/opt/managed/jre/bin/java -vmargs -Xms638M -Xmx638M -XX:+UseConcMarkSweepGC -XX:CMSInitia...
└─16182 /opt/managed/jre/bin/java -Dcom.compuware.apm.WatchDogPort=50005 -classpath /opt/managed/security-Gateway/lib/* -XX:ErrorFile=/var/opt/managed/log/securi...
● dynatrace-nginx.service - Dynatrace Nginx
Loaded: loaded (/etc/systemd/system/dynatrace-nginx.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-07-09 08:39:46 UTC; 1 months 3 days ago
Tasks: 14 (limit: 32768)
Memory: 92.7M
CPU: 40min 38.507s
CGroup: /system.slice/dynatrace-nginx.service
├─17152 nginx: OneAgent companion process
├─17153 nginx: master process /opt/managed/nginx/sbin/nginx -c /opt/managed/nginx/conf/nginx.conf
├─17155 nginx: worker process
├─17156 nginx: worker process
├─17164 /bin/bash /opt/managed/services/logs-watcher.sh watch-nginx /var/opt/managed/log/nginx/access.log /var/opt/managed/log/nginx/error.log
└─19214 sleep 600
All services are OK
- check
Checks the status of iptable rules and the processes for Nodekeeper, Cassandra, Elasticsearch, ActiveGate, Watcher, and Nginx.[root@localhost]# ./dynatrace.sh check
Checking rules in iptables ...
Rule is present in 'filter': INPUT -p tcp -m tcp -m multiport --ports 443,5701:5711,7000:7001,7199,8018:8022,8443,9042,9200,9300,9998 -j DROP
Rule is present in 'filter': OUTPUT -p tcp -m tcp -m multiport --ports 443,5701:5711,7000:7001,7199,8018:8022,8443,9042,9200,9300,9998 -j ACCEPT
Rule is present in 'filter': INPUT -p tcp -m addrtype --src-type LOCAL -m tcp -m multiport --ports 443,5701:5711,7000:7001,7199,8018:8022,8443,9042,9200,9300,9998 -j ACCEPT
Rule is present in 'filter': INPUT -s 10.10.10.10/32 -p tcp -m tcp -m multiport --ports 5701:5711,7000:7001,7199,8019,9042,9200,9300 -j ACCEPT
Rule is present in 'filter': INPUT -p tcp -m tcp -m multiport --ports 443,8020:8022,8443,9998 -j ACCEPT
Rule is present in 'filter': FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
Rule is present in 'nat': PREROUTING -p tcp -m addrtype --dst-type LOCAL -m tcp --dport 443 -j REDIRECT --to-ports 8022
Rule is present in 'nat': OUTPUT -p tcp -m addrtype --dst-type LOCAL -m tcp --dport 443 -j REDIRECT --to-ports 8022
All rules are active.
Nodekeeper is running at launcher PID: 966, main PID: 552, listening on ports 8018
Cassandra is running at launcher PID: 13721, main PID: 13690, listening on ports 9042
Elasticsearch is running at launcher PID: 14834, main PID: 14802, listening on ports 9200,9300
"cluster_name" : "11bc1cd1e1-c222-33e3-4f44-0e0bc0dcdc0d",
"status" : "yellow",
"timed_out" : false,
"number_of_nodes" : 1,
"number_of_data_nodes" : 1,
"active_primary_shards" : 299,
"active_shards" : 299,
"relocating_shards" : 0,
"initializing_shards" : 0,
"unassigned_shards" : 598,
"delayed_unassigned_shards" : 0,
"number_of_pending_tasks" : 0,
"number_of_in_flight_fetch" : 0,
"task_max_waiting_in_queue_millis" : 0,
"active_shards_percent_as_number" : 33.33333333333333
Server is running at launcher PID: 15294, main PID: 15302, listening on ports 8021
ActiveGate is running at launcher PID: 16173, main PID: 16182, listening on ports 8443
Command to run as user dynaman: /opt/managed/services/logs-watcher.sh status
Watcher is running, reporting in log: /var/opt/managed/log/logs-watcher-for-nginx-logs.log
Nginx is running at launcher PID: 17153, main PID: 17155 17156, listening on ports 8022
All processes are OK
- pid
Displays the process ID for all Dynatrace required services that were started with thedynatrace.shscript.[root@localhost]# ./dynatrace.sh pid
966 552 13721 13690 14834 14802 15294 15302 16173 16182 17153 17155 17156
