Replicate nodes across DCs for Premium HA
To create a globally distributed high availability deployment (Premium High Availability), you must add a redundant set of nodes to your original Managed cluster deployment. Typically, such high availability deployments span across multiple data centers. Dynatrace Managed enables you to add mirrored nodes located in another data center.
In this procedure, the following terms are designated as follows:
  • DC-1 - The data center where the initial Managed cluster is located.
  • DC-2 - An additional data center designated for Premium High Availability deployment.
  • seed node - Any node within DC-1 that will be used for performing the installation tasks and distribution of configuration.
The procedure involves migration and replication of Dynatrace Managed components separately so they are prepared for data replication across two data centers. See Overview of Dynatrace Managed components.
Requirements
  • Premium High Availability license. See Calculate Dynatrace monitoring consumption
  • DC-1 cluster release must be 1.196+.
  • DC-1 cluster must have backup disabled before starting the migration procedure. We recommended that you create a fresh cluster backup and disable cluster backup shortly before deploying the additional data center.
  • DC-1 cluster automatic update must be disabled before starting the migration procedure. The cluster must not be upgraded during migration. See Automatic update. Contact Dynatrace ONE if your automatic update option is disabled.
  • Make sure the machines are prepared for the cluster in DC-2.
    We recommend
    Since DC-2 will replicate the data of DC-1, we recommend that you designate the same number of nodes with the same hardware, including disk storage.
    All nodes in DC-1 and DC-2 must be time-synchronized. This can be achieved by setting up Network Time Protocol (NTP).
  • Premium High Availability deployment requires at least three nodes in DC-1 and three corresponding nodes in DC-2.
  • Make sure that all nodes in both data centers can communicate with each other.
Preparation
In order to streamline the numerous REST API calls during the deployment, set environments variables on the seed node in DC-1 and every node in DC-2.
Gather information
The commands will use these variables in executing the REST API calls. For this, you will need the following information:
  • <seed-node-ip> - The IP address of the seed node from DC-1.
    This can be any node running in the existing data center that will be used for performing the installation tasks and distribution of configuration.
  • <nodes-ips> - The list of IPV4 addresses of new nodes in DC-2.
    Example: "176.16.0.5", "176.16.0.6", "176.16.0.7"
  • <api-token> - A valid Cluster API token (ServiceProviderAPI scope is required).
    You can generate it in the Managed Cluster Management Console. See Cluster API - Authentication.
  • <dynatrace-directory> - The directory where Dynatrace Managed is installed on the seed node.
    The default Dynatrace Managed installation directory is /opt/dynatrace-managed
  • <datacenter-1> - The DC-1 name must be the same as the Cassandra DC name.
    The default Cassandra DC name is datacenter1.
  • <datacenter-2> - The DC-2 name can be any string that begins and ends with an alphanumeric character and is no longer than 80 characters. Underscores and dashes are allowed within the name. Example: dc-us-east-2.
Set variables
Set the following environment variables on EVERY NODE in DC-1 and DC-2:
SEED_IP=<seed-ip>
DT_DIR=<dynatrace-directory>
NODES_IPS=$(echo '[<nodes-ips]')
API_TOKEN=<api-token>
DC1_NAME=<datacenter-1>
DC2_NAME=<datacenter-2>
For example:
SEED_IP=10.176.37.201
DT_DIR=/opt/dynatrace-managed
NODES_IPS=$(echo '["10.176.37.218", "10.176.37.227", "10.176.37.120"]')
API_TOKEN=R_SZOpV4RTOmjr9fFmK4x
DC1_NAME=datacenter1
DC2_NAME=dc-us-east-2
Check for custom settings
If your Cassandra or Elasticsearch cluster is configured with custom.settings that enable rack-awareness, contact Dynatrace ONE to apply these custom settings before proceeding with DC-2 installation.
To check whether custom settings are applied, execute on seed node:
Download
ls $DT_DIR/installer/custom.settings
If the custom.settings file exists, you are using custom settings.
Installation
To create a cluster in a second DC, follow this procedure.
API return codes
Each of the REST API calls will return the HTTP code. Go to the next step only when the returned code is 200. Expect the following return codes:
200 - Go to the next step, current step was executed successfully.
207 - The request is being processed, repeat step after few minutes if there's no response.
40x - Revise your request path and arguments, then repeat the request.
5xx - Contact Dynatrace ONE.
1. Update Elasticsearch
Update Elasticsearch to the proper version. Execute the following command on each existing DC-1 node successively:
Download
sudo $DT_DIR/installer/reconfigure.sh --only els
2. Distribute the installer
In this step, you will copy the node installer to every node in DC-2.
Log into your Dynatrace Managed Cluster Management Console.
From the navigation menu, select Home to go to the Dynatrace Managed deployment status page.
Click Add new cluster node.
Copy the wget command line from the Run this command on the target host text box.
Do not run the installer script
The Run this installer script with root rights text box contains a command for the installation script. Ignore this command; do not execute the provided script.
Paste and execute only the wget command line into your terminal window.
3. Create the data center topology
In this step, you will create a configuration that defines which node belongs to which data center.
Execute the following cluster API call only on the seed node:
Download
curl -ikS -X POST -d "{\"newDatacenterName\" : \"$DC2_NAME\", \"nodesIp\" :$NODES_IPS}" https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/datacenterTopology?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If the status code is not 200 and the response does not suggest next steps, contact Dynatrace ONE.
4. Open firewall rules
In this step, you will you will add firewall rules that open ports for traffic to the new DC-2 nodes.
Open ports
To open ports to traffic from the new DC-2 nodes, execute the following cluster API call only on the seed node:
Download
curl -ikS -X POST -d "$NODES_IPS" https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/clusterNodes/currentDc?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If successful, the status code will be 200 and the response body will contain a request ID you need to check the firewall rules status.
Verify firewall rules
Set the request ID environment variable on seed node only. The request ID is from the response in the previous API call.
REQ_ID=<topology-configuration-request-id>
To check the firewall rules status, execute the following cluster API call only on the seed node:
Download
curl -ikS https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/clusterNodes/currentDc/$REQ_ID?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If the status code from this call is not 200, try again after a few minutes.
5. Install second data center nodes
In this step, you will install managed nodes on all hosts within DC-2 and, once completed, you will check for the presence of a Nodekeeper service. This will indicate if all nodes were successfully installed in DC-2.
Install nodes in DC-2
Execute the following command on every node in DC-2. Follow the on-screen instructions, as this will be a typical node installation.
Download
sudo /bin/sh ./managed-installer.sh --install-new-dc --datacenter $DC2_NAME --seed-auth $API_TOKEN
This operation should take 3 to 5 minutes and the expected result should be similar to this:
Installation in new datacenter completed successfully after 2 minutes 51 seconds.
Check Nodekeeper in DC-2
Execute the following cluster API call only on the seed node when all nodes in DC-2 finish installing:
Download
curl -ikS https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/nodekeeper/healthCheck?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If the status code is not 200, try again after a few minutes.
6. Replicate Cassandra
In this step, you will reconfigure Cassandra in DC-1 and DC-2 for cross-data center replication, trigger data synchronization, rebuild Cassandra data, and verify the Cassandra state.
It may take minutes to hours, depending on your metric storage size.
Replication of Cassandra in DC-1
In this step, you will reconfigure Cassandra for cross-data center replication.
Replicate Cassandra
To start Cassandra replication in the DC-1 data center, execute the following cluster API call only on the seed node:
Download
curl -ikS -X POST https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/cassandra/currentDc?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If successful, the status code will be 200 and the response body will contain a request ID that you need to check replication status. Set the request ID environment variable only on the seed node. The request ID is from the response in the previous API call.
REQ_ID=<replication-old-datacenter-request-id>
Check replication status
To check replication status, execute the following cluster API call only on the seed node:
Download
curl -ikS -X GET https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/cassandra/currentDc/$REQ_ID?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
Replication of Cassandra in DC-2
In this step, you will reconfigure Cassandra for cross data center replication and trigger data synchronization.
Replicate Cassandra
To start replication of Cassandra in the DC-2 data center, execute the following cluster API call only on the seed node:
Download
curl -ikS -X POST https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/cassandra/newDc?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
REQ_ID=<replication-new-datacenter-request-id>
To check the replication status, execute the following cluster API call only on the seed node:
Download
curl -ikS -X GET https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/cassandra/newDc/$REQ_ID?Api-Token=$API_TOKEN -H  "accept: application/json" -H  "Content-Type: application/json"
Rebuild Cassandra data
In this step, you will rebuild Cassandra and verify the progress by checking the status. Depending on the size of your Cassandra database, this can take several hours.
Rebuild data
To rebuild Cassandra, run the following command on each new DC-2 node successively:
Download
sudo $DT_DIR/utils/cassandra-nodetool.sh rebuild -- $DC1_NAME
Verify progress and status
To verify the progress and status, execute the following cluster API call only on the seed node:
Download
curl -ikS -X GET https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/cassandra/rebuildStatus?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If the status code is not 200, try again after approximately 15 minutes. Remember that the rebuild process can be time-consuming.
Verify Cassandra state
To verify the Cassandra cluster state, execute the cassandra-nodetool.sh with the status parameter only on the seed node:
Download
sudo $DT_DIR/utils/cassandra-nodetool.sh status
The result should look similar to this:
Datacenter: dc1
Status=Up/Down
|/ State=Normal/Leaving/Joining/Moving
--  Address        Load       Tokens       Owns (effective)  Host ID                               Rack
UN  10.176.41.167  18.82 GB   256          100.0%            3af25127-4f99-4f43-afc3-216d7a2c10f8  rack1
UN  10.176.41.154  19.44 GB   256          100.0%            5a618559-3a73-42ec-83f0-32d28e08beec  rack1
UN  10.176.41.43   19.58 GB   256          100.0%            191f3b30-949a-4cf2-b620-68a40eebf31e  rack1
Datacenter: dc2
Status=Up/Down
UN  10.176.42.54   19.18 GB   256          100.0%            852ce236-a430-400a-92a6-daeed99acf68  rack1
UN  10.176.42.104  19.12 GB   256          100.0%            84479219-b64d-442c-a807-a832db9aae18  rack1
UN  10.176.42.234  19.4 GB    256          100.0%            507b377c-5bfc-4667-b251-a9b7c453ed22  rack1
The Load value should not differ significantly between the nodes and Status should be UN on all nodes.
7. Replicate Elasticsearch
In this step, you will replicate Elasticsearch to the DC-2 data center and verify the configuration and data replication. This step may take minutes or hours, depending on your Elasticsearch storage.
replicate Elasticsearch to DC-2
To start replication of Elasticsearch to the DC-2 data center, execute the following cluster API call only on the seed node:
Download
curl -ikS -X POST https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/elasticsearch?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
REQ_ID=<replication-elasticsearch-request-id>
To check the replication status of Elasticsearch, execute the following cluster API call only on the seed node:
Download
curl -ikS -X GET https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/elasticsearch/$REQ_ID?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
Verify data replication
To verify replication Elasticsearch data replication, execute the following cluster API call only on the seed node:
Download
curl -ikS -X GET https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/elasticsearch/indexMigrationStatus?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
8. Migrate the server
In this step, you will migrate the server, start ActiveGate, and start Nginx in the DC-2 data center.
Migrate server
Launch the Managed cluster in the DC-2 by executing the following cluster API call only on the seed node:
Download
curl -ikS -X POST https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/server?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If successful, the status code will be 200 and the response body will contain a request ID that you need to check cluster readiness. Set the request ID environment variable only on the seed node. The request ID is from the response in the previous API call.
REQ_ID=<replication-server-request-id>
Check cluster readiness
To check if the cluster is ready, execute the following cluster API call only on the seed node:
Download
curl -ikS -X GET https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/server/$REQ_ID?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
9. Enable the new data center
  1. Enable OneAgent traffic.
    For details, see Enable/Disable a cluster node.
  2. Enable backup in one of the data centers. Your backup is disabled after migration.
    For details, see Back up and restore a cluster.
