• Home
  • Setup and configuration
  • Dynatrace ActiveGate
  • Operation
  • Uninstall ActiveGate
ActiveGate has a dedicated uninstall program. You'll need to run it to remove ActiveGate from your system.
  • On Windows:
    Use the Windows Control Panel to remove ActiveGate.
  • On Linux:
    Go to the /opt/dynatrace/gateway directory and, using root rights, run the uninstall.sh script.
After uninstall
Following uninstallation, log files and part of the configuration are preserved in the ActiveGate log and configuration directories respectively. You'll have to remove these files manually.
