Time to upgrade! NAM is scheduled for end of support. It's time to move to Dynatrace our all-in-one software intelligence platform.
Exporting and importing
Applies to NAM 2019+
Use the Export/Import page to export and import configuration files.
Alerts
You can export and import NAM alerts as JSON files zipped together.
Export
When you export alerts, the alert definition files are zipped together and saved to your disk. The zip file includes:
  • alertsExport.json - Alert definitions in JSON format.
  • recipientsExport.json - Alert recipients in JSON format.
Alerts with duplicate names are not exported. You must rename them before export.
Import
When you import alerts, browse for a zip file containing the alert definitions and alert recipients as described above.
Caution
If you import alerts with the same names, you overwrite the existing alerts with the alerts you are importing.
