Time to upgrade! NAM is scheduled for end of support. It's time to move to Dynatrace our all-in-one software intelligence platform.
SSL_APPL_INOPER
This alert is triggered when the SSL connection setup time for a software service on a server is too long.
Characteristics
Name: SSL connection setup time too long for SSL service
Type: performance
Status (default): enabled
Detector: SQL-based
Message
“The SSL connection setup time of software service *software_service_name* on server *IP_address* (*server_name*) was too long.”
“The setup time value: *time* ms.”
Detector parameters
Overriding values can be specified in the *<installation directory>* \config\alarmdetectorparams-rtm.config configuration file.
  • Selector of the SSL connection setup time (0 - per session / 1 - per page)
    Toggle defining what metric is to be used for analysis; if the parameter equals 0, we use the current plain SSL connection setup time; otherwise, the current transaction-weighted SSL connection setup time is used.
  • Lower limit of the unacceptable setup time [ms] (number)
    Lower limit of unacceptable values of the SSL setup time, expressed in milliseconds.
