Time to upgrade! NAM is scheduled for end of support. It's time to move to Dynatrace our all-in-one software intelligence platform.
LOW_OPER_4_CAP_MOD
This alert is triggered by problems with memory utilization, average time of processing data files, or nightly task execution time.
The alert is raised only once per time the threshold for any of three capacity criteria is exceeded. If more than one threshold is exceeded at the same time, the alert is still triggered only once, but the alert message reports on all existing alert causes.
Characteristics
Name: Capacity problems of reporting server module
Type: diagnostics
Status (default): enabled
Detector: built-in, non-SQL
Message
“Capacity problem detected for the reporting server module: *module_name*, sub-module: *module_name* .”
“Capacity problem cause: *cause* . ”
Detector parameters
This alert has no parameters.
