Time to upgrade! NAM is scheduled for end of support. It's time to move to Dynatrace our all-in-one software intelligence platform.
LOAD_TIME_4_URL
This alert is triggered if the operation time for the entire page (including frames, linked style sheets, images, and other page components) exceeds the threshold value and if there have been at least a specified number of such page loads. The alert is similar to LOAD_TIME_4_URL_4_CLI .
Characteristics
Name: High operation time for URL pattern occurred more than N times per client
Type: performance
Status (default): disabled
Detector: SQL-based
Message
“URL Pattern: *URL_pattern* ”
“Metric: Page Download Time”
“Threshold: *time* ms.”
“Description: at least *page_downloads* page downloads of *total* lasted more than *time_threshold* ms. The mean time for *number* downloads was *time* ms.”
“Summary Statistics: *URL* ”
Detector parameters
  • thrs (number)
    Threshold value of the operation time, expressed in milliseconds.
  • noo (number)
    Threshold value of the number of operations per user.
All the alert parameters are defined in the *<installation directory>* \config\alarmdetectorparams-rtm.config file in the following form:
LOAD_TIME_4_URL | String:url_pattern ” = threshold_in_ms, page_loads_per_user
Example:
LOAD_TIME_4_URL| String: "http://www.yahoo.com/%" = 20000,2
