Time to upgrade! NAM is scheduled for end of support. It's time to move to Dynatrace our all-in-one software intelligence platform.
ERR_INC_4_SGL_TRANS
This alert reports on a failure of a single-user transaction.
A transaction is a sequence of operations performed by a user by means of a network application. A transaction is a sequence of operations performed by a user by means of a network application. We consider transaction failed if an error occurs, the predefined application error or user-defined error.
Characteristics
Name: Failure of a single-user transaction
Type: anomalies
Status (default): enabled
Detector: SQL
Message
Transaction of name {1}, with ID {2}, for user {3}, ({4}) resulted in failure {5}.
The transaction consisted of {6} step(s) and included {7} page(s).
Link: Alert details.
Detector parameters
This alert has no parameters.
Reported information
1 - Transaction name (string) - The name of the transaction experiencing failures.
2 - Transaction id (string)
3 - User IP address (IP address) - The IP address of the user that has performed the transaction.
4 - User name (string) - The name of the user that initiated the transaction.
5 - Failure description (string) - For predefined application errors, such as HTTP errors, the failure code and the description, for exampleHTTP 404 - page not found.
6 - Number of steps in a transaction (number)
7 - Number of pages (number) - The average number of pages loaded while the transaction was in progress.
