Time to upgrade! NAM is scheduled for end of support. It's time to move to Dynatrace our all-in-one software intelligence platform.
DISKS_STORAGE
This alert is triggered when there is too little free space on the server hard drives. It is not dependent on AMD data; all the disks installed in the server are checked. The alert is available in Central Analysis Server and Advanced Diagnostics Server.
Characteristics
Type: diagnostics
Status (default): enabled
Detector: built-in, non-SQL
Message
“Not enough space on disk *hard_drive* . Free disk space: *disk_space* MB (*percentage_of_free_disk_space* %). Total disk storage: *disk_space* MB.”
Detector parameters
  • External disk checker (valid file path)
    Name of the executable file used for testing available free storage size: df.exe
  • Threshold [% of free space] (number as percentage)
    Minimum percentage value of free storage. For example, 10.
