Time to upgrade! NAM is scheduled for end of support. It's time to move to Dynatrace our all-in-one software intelligence platform.
View properties
For most DNA views, View  ► Properties opens a pane where you can adjust the way the view is presented.
Depending on the view, you can select which data to display and which data to hide, change the order of columns in tables, and otherwise adjust how data is displayed in that view. Any changes you make to the properties, such as clearing certain properties, become the automatic default for that view until you make another change.
