Time to upgrade! NAM is scheduled for end of support. It's time to move to Dynatrace our all-in-one software intelligence platform.
Trace Trimmer tabs
Trace Trimmer's tabs offer seven views of a traffic capture.
MAC addresses
Displays a MAC-centric view of your data.
  • Node A is the MAC address of one end of a connection
  • Node B is the MAC address of the other end of that row's connection
  • Packets and Bytes indicate the traffic volume between the two MAC addresses
Conversations
Displays a conversation-centric view of your data.
  • Node A is the IP address of one end of a conversation
  • Node B is the IP address of the other end of that row's conversation
  • Packets and Bytes indicate the traffic volume of that conversation
Connections
Displays a connection-centric view of your data.
  • Node A (graph and table column) is the IP address of one end of a connection, and Node A Port is the port number on that end of the connection.
  • Node B (graph and table column) is the IP address of the other end of that row's connection, and Node B Port is the port number on that end of the connection.
  • Application Protocol (graph and table column), Transport Protocol (table column only), and Network Protocol (table column only) are the active protocols for those three network levels of the connection.
  • You can view and sort connections in the table by MPLS, VLAN, and QoS. These are each shown in graphs and in the table.
    • QoS shows the Quality of Service values for the traffic as encoded in differentiated services code point (DSCP) per-hop behavior (PHB) class. We assume that each connection is associated with one unchanging DSCP value for the whole connection.
      • DF = Default Forwarding. Typically, this is best-effort forwarding.
      • EF = Expedited Forwarding. Typically, this is low-loss, low-latency, low-jitter traffic suitable for real-time audio and video.
      • AF = Assured Forwarding. Typically, delivery of this traffic is guaranteed as long as it stays within the subscribed rate.
      • CS = Class Selector. This is used to maintain backward compatibility with networks that continue to use the old Precedence field to specify traffic priority.
    • Packets and Bytes (table column only) indicate the traffic volume of that connection.
Nodes
Displays a node-centric view of your data.
  • Tables Node A and Node B (under table Node A) both initially list the IP addresses of all nodes; they are identical except for sort order. If you click a node in either table, however, that table will be restricted to only the selected node and the other table will show only those nodes that have a connection with the selected node.
  • Packets and Bytes indicate the traffic volume of that connection
Protocols
Displays a protocol-centric view of your data.
  • Application Protocol displays the name and traffic volume of each application protocol detected in your data. Click an application protocol name to hide all other application protocols.
  • Transport Protocol displays the name and traffic volume of each transport protocol detected in your data. Click a transport protocol name to hide all other transport protocols.
  • Network Protocol displays the name and traffic volume of each network protocol detected in your data. Click a network protocol name to hide all other network protocols.
MPLS
The MPLS tab presents all MPLS labels gathered during trace parsing. If a conversation contains different labels or there are stacked labels, all are concatenated and displayed in one row. Each MPLS label can be used as a view or output filter.
VLAN
The VLAN tab presents all VLAN labels gathered during trace parsing. There can be more than one label per conversation and in theory a double-tagged, stacked VLAN label is also possible. If a conversation contains different labels or there are stacked labels, all are concatenated and displayed in one row. Each VLAN label can be used as a view or output filter.
  • VLAN ID lists associated VLAN labels.
  • Packets and Bytes indicate the traffic volume associated with this row.
