Time to upgrade! NAM is scheduled for end of support. It's time to move to Dynatrace our all-in-one software intelligence platform.
Opening a Smart Packet Capture with DNA
Tools > Packet data mining tasks, then download the file and open in DNA.
Prerequisites
Opening the trace
  1. On the NAM Server main menu bar, select Tools > Packet data mining tasks.
    This screen lists all Smart Packet Captures in progress or previously captured.
  2. In the list of tasks, find the task that generated the trace file you want to download and click Expand button to expand the task.
  3. In the list of traces for that task, find the trace you want to download and click Download button.
  4. The Download file window displays a suggested file name and the target file format.
  5. Select the opcx file format (for a DNA import) and click OK.
  6. In the Opening filename .opcx window, select Open with and Dynatrace Network Analyzer, and then click OK.
  7. DNA will open your file in the Save window.
  8. Set Filter and click Finish.
    • No filter
      Opens your trace with no filtering. You can still filter it later.
    • Trace Trimmer
      Opens your trace in Trace Trimmer, which offers easy but effective trace filtering through a simple GUI.
    • Basic or BPF Filter
      If you prefer to write a filter by hand, you can click the Set Filter button and write a BPF filter to apply to your trace.
