NAM integration
Network Application Monitoring (NAM, formerly known as DC RUM) provides real-time access to information about performance and usage of key business applications. Based on measurement data provided by network monitoring devices, it monitors application performance, with the purpose of detecting, identifying and solving problems. Analysis gives insight into business application performance on transaction and operation level.
In combination with the in-depth analysis capabilities of AppMon PurePath technology, you can quickly find the root cause of problems in its code-level context.
To combine NAM data with AppMon, configure a connection to your NAM appliances in the Integration section of the System Profile Preferences dialog box. Enabling integration correlates data collected by NAM to AppMon PurePaths.
Supported releases
Integrating NAM with AppMon requires the following:
  • NAM (DC RUM) version 12.4.10 or later.
  • Flash installed on the client's browser. Drilldowns from the NAM Central Analysis Server (CAS) require Flash.
This integration will be deprecated with NAM 2019 release.
For detailed instructions on configuring the AppMon - DC RUM integration, see System Profile - Integration.
