Enterprise Synthetic Integration
Enterprise Synthetic has reached end of support
This integration is no longer supported as Enterprise Synthetic has reached end of support.
The Dynatrace software intelligence platform has evolved in capability and enterprise readiness, and it's time to upgrade Enterprise Synthetic to the new, all-in-one Dynatrace solution.
The integration with Enterprise Synthetic allows you to use AppMon to precisely analyze response times and failure rates of synthetic transactions produced by Enterprise Synthetic. Enabling the AppMon integration in Enterprise Synthetic adds contextual information about each synthetic transaction in the HTTP header string of each transaction request. For example, the script name of the transaction in Enterprise Synthetic can be viewed in the Timer Name column on the AppMon System Profile <name> > Diagnose Performance > Tagged Web Requests dashlet.
