Component compatibility
Although certain version combinations may be compatible, it is strongly advised for all users to upgrade all components as soon as possible to the same version as the server.
Compatibility and support
Components are said to be compatible, if they can connect and offer any kind of functionality together. For a specific feature to work, the support of all involved components (Agents, Collectors, Server, Client) is required.
Example: Infrastructure: Process Availability
When using 6.2 Host Agents with a 6.5 Server and Client, you can configure Process Availability patterns, but these have no effect and do not fire incidents as the 6.2 Agent does not support them. This feature was introduced starting with 6.5.
Agent-Collector compatibility
Agents need to have the same or lower version than the Collector. Compatibility is guaranteed for supported versions, but typically also true for all Agent versions greater than 5.6.
Collector 7.0 Collector 7.1 Collector 7.2
Agent 7.0 Yes Yes Yes
Agent 7.1 No Yes Yes
Agent 7.2 No No Yes
Bootstrapped Agents are upgraded automatically upon restart of the monitored application up to the version of their Collector. Therefore, upgrade first the Server, then Collectors and last the Agents.
Collector-Server compatibility
Collectors need to have the same or lower version than the Server. Compatibility is guaranteed for supported versions, but typically also true for all Collector versions greater than 6.0.
Server 7.0 Server 7.1 Server 7.2
Collector 7.0 Yes Yes Yes
Collector 7.1 No Yes Yes
Collector 7.2 No No Yes
Collectors are upgraded manually like Servers.
Client-Server compatibility
The major and minor version of the client has to match that of the Server. Lower-version Clients can auto-upgrade to the Server version if the major version matches.
Examples:
  • 6.5.0 Client cannot connect to a 2017 May (7.0) Server - requires a new installation
  • 6.5.0 Client can connect to a 6.5.10 Server
  • 6.3.0 Client when connecting to a 6.5.0 Server can auto-upgrade to 6.5.0.
  • After such an auto-upgrade: a 6.5 Client cannot connect to a 6.3 Server
Bootstrap Agents compatibility
See the release notes section "Dynatrace AppMon components" for supported versions of Bootstrap Agents. Unsupported Bootstrap Agent versions are not tested, but all Bootstrap Agents should still work.
Mobile Agent compatibility
The Compatibility and support statement also applies to the Mobile Agent. Newer Mobile Agent versions are compatible with older AppMon components. Therefore, we recommend upgrade to the latest major version of the Mobile Agent even if you don't plan to upgrade other AppMon components.
For some new features however you have to upgrade all AppMon components. For further details see the Android Agent and iOS Agent upgrade pages.
