Load tests
Load tests can be analyzed using a separate Load Test Overview dashboard. You must record sessions for performing load tests.
Perform the following steps to record a session with a load test.
  1. Start the session recording, with your session name specified. You can do that manually or using the REST API.
  2. Run your load test.
  3. Stop recording.
To analyze the session containing your load test, use the Analyze Load Test Results link from the Test Overview dashlet or choose the Start Center > Analyze Performance > Analyze Load Test Results link for more information.
