Monitor dockerized apps with AppMon
This page describes two methods for integrating an Application Monitoring agent with a Dockerized application. These methods, referred to as the composition-based and inheritance-based approach on this page. Pros and cons of each are noted. The inheritance-based, however, is not recommended to use, and presented here for demonstration purposes.
Composition-based approach
With the composition-based approach, you use the AppMon/agent Docker image that includes all variants of the AppMon agent that you can configure to attach to your existing Docker containers.
Technically speaking, this approach uses a feature of Docker that allows a Docker container to export parts of its file system as Docker volumes and thereby make them obtainable by other, interested containers. THis looks similar to the following.
Examples
The following examples assume that you are already running a dynatrace/agent Docker container by name dtagent that exports the /dynatrace installation folder as a volume. The AppMon in Docker project on GitHub includes scripts to do exactly that and even allows you to conveniently set up an entire AppMon environment in Docker. More information can be found in the following Performance Clinic.
Example: Apache Tomcat
This docker-compose.yml file mounts the exported volumes of a container dtagent and initializes the CATALINA_OPTS environment variable with a proper -agentpath.
tomcat:
  image: tomcat
  ports:
  - 8080
  volumes_from:
  - dtagent
  environment:
    CATALINA_OPTS: "-agentpath:/dynatrace/agent/lib64/libdtagent.so=name=tomcat,collector=127.0.0.1:9998"
  command: catalina.sh run
Example: NGINX
This docker-compose.yml file mounts the exported volumes of a container dtagent and overrides the container's CMD to load the agent with NGINX.
nginx:
  image: nginx
  ports:
  - 80
  volumes_from:
  - dtagent
  environment:
    DT_AGENT_NAME: "nginx"
    DT_AGENT_COLLECTOR: "127.0.0.1:6698"
    LD_PRELOAD: "/dynatrace/agent/lib64/libdtagent.so"
  command: sh -c "/dynatrace/run-wsagent.sh && nginx -g 'daemon off;'"
Analysis
  • On the pros side, this approach neatly contributes to a clean separation of concerns, which is a design principle in the containers world. Also, you don't have get agents into your base images. A simple configuration at run time is all you need to get your containers monitored.
  • On the cons side, while the Docker run time has great support for exchanging volumes between containers, doing so on a container orchestration platform such as Kubernetes or OpenShift can render your application configurations overly complex.
Inheritance-based approach
Note
This method is not recommended to use, and presented here for demonstration purposes.
In technical terms, Dockerizing an application process typically involves two parts:
  • A base image, such as java:8 or node:7, which provides the basic execution environment
  • A Dockerfile that augments selected base image with application-specific setup instructions.
Building your Dockerfile using the docker build command creates the desired Docker image.
A comprehensive set of base images is provided on the Docker Hub. You can also read Using Dockerfiles to Automate Building of Images and Best Practices for Writing Dockerfiles for more information.
Examples
You can create base images for your application that are ready for monitoring. Weaving the agent into base images auto-enables monitoring by making AppMon part of the platform.
Example: Java
This example shows a Dockerfile that extends the official openJDK Docker image base image and downloads and extracts the agent. A number of environment variables are set for convenience, such as DT_AGENT_NAME and DT_AGENT_COLLECTOR, which you can populate with your own values. Additionally, JAVA_OPTS is initialized with a proper -agentpath that picks up these variables and points to the 64-bit agent in DT_AGENT_LIB64.
FROM openjdk:8
ENV DT_AGENT_INSTALLER_URL "https://files.dynatrace.com/downloads/OnPrem/dynaTrace/7.0/7.0.0.2469/dynatrace-agent-7.0.0.2469-unix.jar"
ENV DT                     "/dynatrace"
ENV DT_AGENT_LIB32         "${DT}/agent/lib/libdtagent.so"
ENV DT_AGENT_LIB64         "${DT}/agent/lib64/libdtagent.so"
ENV DT_AGENT_NAME          "java"
ENV DT_AGENT_COLLECTOR     "127.0.0.1:9998"
ENV JAVA_OPTS              "-agentpath:${DT_AGENT_LIB64}=name=${DT_AGENT_NAME},collector=${DT_AGENT_COLLECTOR}"
# Install the Agent
RUN curl -L -o /tmp/`basename ${DT_AGENT_INSTALLER_URL}` ${DT_AGENT_INSTALLER_URL} && \
    java -jar /tmp/`basename ${DT_AGENT_INSTALLER_URL}` -t ${DT} && \
    rm -f /tmp/`basename ${DT_AGENT_INSTALLER_URL}`
Building this Dockerfile using docker build . -t openjdk:8-dtappmon -f ./Dockerfile for example creates a new Docker image with name openjdk and tag 8-dynatrace-appmon in your local Docker registry. With each application build, you can now create an application image that extends openjdk:8-dtappmon as shown in the following example (where repo.internal refers to a fictitious binary repository and my-app is a fictitious application). This also gives you the possibility to override the DT_AGENT_NAME environment variable to be more specific than its definition in the base image.
FROM openjdk:8-dtappmon
ENV DT_AGENT_NAME "my-app"
ADD https://repo.internal/my-app/builds/latest.tar.gz /app
CMD java ${JAVA_OPTS} -jar /app/my-app.jar
Example: Nginx
This example shows a Dockerfile that extends the official NGINX Docker image base image and downloads and extracts the agent. A number of environment variables are set for convenience, such as DT_WSAGENT_NAME and DT_WSAGENT_COLLECTOR, which you can populate with your own values. Additionally, DT_WSAGENT_INI provides a proper agent configuration and overrides the container's CMD to load the agent with NGINX.
FROM nginx:1.9
ENV DT_WSAGENT_INSTALLER64_URL "https://files.dynatrace.com/downloads/OnPrem/dynaTrace/7.0/7.0.0.2469/dynatrace-wsagent-7.0.0.2469-linux-x86-64.tar"
ENV DT                         "/dynatrace"
ENV DT_WSAGENT_INI             "${DT}/agent/conf/dtwsagent.ini"
ENV DT_WSAGENT_BIN64           "${DT}/agent/lib64/dtwsagent"
ENV DT_WSAGENT_LIB64           "${DT}/agent/lib64/libdtagent.so"
ENV DT_WSAGENT_NAME            "nginx"
ENV DT_WSAGENT_COLLECTOR       "127.0.0.1:9998"
ENV DT_WSAGENT_LOG_LEVEL       "info"
# Install the Agent
ENV DT_INSTALL_DEPS            "curl"
RUN apt-get update && apt-get install -y --no-install-recommends ${DT_INSTALL_DEPS} && \
    curl -L -o /tmp/`basename ${DT_WSAGENT_INSTALLER64_URL}` ${DT_WSAGENT_INSTALLER64_URL} && \
    tar -C /tmp -xf /tmp/`basename ${DT_WSAGENT_INSTALLER64_URL}` && sh /tmp/dynatrace-wsagent-*.sh && mv /dynatrace-* /dynatrace && \
    rm -f /tmp/dynatrace-* && apt-get remove --purge -y ${DT_INSTALL_DEPS} && rm -rf /var/lib/apt/lists/* /tmp/*
# Configure the AppMon WebServer Agent
RUN sed -i -r "s/^#?Name.*/Name ${DT_WSAGENT_NAME}/;s/^#?Server.*/Server ${DT_WSAGENT_COLLECTOR}/;s/^#?Loglevel.*/Loglevel ${DT_WSAGENT_LOG_LEVEL}/;s/^#?ConsoleLoglevel.*/ConsoleLoglevel ${DT_WSAGENT_LOG_LEVEL}/" ${DT_WSAGENT_INI}
CMD sh -c "(${DT_WSAGENT_BIN64} &) && LD_PRELOAD=${DT_WSAGENT_LIB64} nginx -g 'daemon off;'"
Analysis
  • On the pros side, this approach reduces the integration of a monitoring solution like AppMon to less frequent, preparatory work that does not add any overhead to the much more frequent process of building, shipping and running Dockerized applications.
  • On the cons side, depending on your particular use-case and on the technologies you use, you must integrate with each of these technologies by hand. And since this approach tightly ties together the agent with a particular technology in the same base image, these base images may have to be recreated when switching to a new version of either the technology or of AppMon.
Q&A
Can I monitor applications running on alpine in docker?
As of now, the AppMon agent does not support monitoring applications which are statically or dynamically linked against musl standard C library (instead of the more widely distributed and common glibc). As a temporary workaround that also saves a considerable amount of disk space, you can use a vanilla Alpine Docker image and install glibc together with your runtime environment, such as Java, on top. This means that you cannot install Alpine's OpenJDK using apk since it, like all Alpine packages, depends on musl. Refer to anapsix/alpine-java as your base image, which at the time of writing combines Alpine 3.4, glibc 2.23-r3 and Oracle Java 1.8.0_71 out of the box.
FROM anapsix/alpine-java
ENV DT                     "/dynatrace"
# Install the Agent
RUN wget -O /tmp/`basename ${DT_AGENT_INSTALLER_URL}` ${DT_AGENT_INSTALLER_URL} && \
If you need an application server like Apache Tomcat on top, see one of their (glibc-based) Dockerfiles and augment the previous example as needed, for example with Apache Tomcat 7 on Java 8.
Can I monitor dockerized applications on kubernetes or OpenShift?
Yes. See the second part of this series.
Can I run easyTravel in docker?
EasyTravel has been fully Dockerized and is available at the easyTravel in Docker GitHub project. You can easily instrument it using Dynatrace in Docker.
