PurePath analytics web view
The PurePath analytics web view graphically represents PurePaths data in retrospective in the current time scope for the selected System Profile. You can select one particular application, or view data for all applications in the System Profile.
Each chart contains marks for the application deployment, allowing you to easily see how the new version of your app affects performance. Hover over the mark to see which application and which version of it was deployed.
Each chart divides data by problem patterns. See the color legend below the chart. Click the bar to filter data by this problem pattern. Problem patterns are also listed in listed in the left side panel, and can be used for filtering as well. Hover over the pattern to view a pop-up tip. See problem patterns detection for more information.
By clicking Analyze PurePaths, you'll switch to the PupePath web view with the same filtering criteria applied.
