AMQP Receive Entry Point sensor
In AppMon 2017 May the AppMon Agent does not support this sensor.
The AMQP Receive Entry Point Sensor enables you to define methods that are responsible for processing AMQP messages after they have been received. These processing methods cannot be recognized automatically, so they have to be specified.
Define a custom method as receive entry point
  1. Configure a custom sensor rule for the custom method.
    This allows the custom method to appears in the path if a Path is active.
  2. Activate the Sensor Group in the correct Agent Group where the method is actually executed.
  3. Check that the Sensor Group is activated.
  4. Configure the custom method also in the Receive Entry Point Sensor.
    This links the method into the JMS Path.
