OpenStack monitoring for enterprises
Dynatrace announces OpenStack support at Barcelona Summit
In today’s world, applications are the lifeblood of your business. When problems arise, reactive troubleshooting is no longer good enough. You can take control with 24/7 visibility into applications and cloud platform, even in the most demanding and dynamic environments. With OpenStack monitoring from Dynatrace, you get a single pane of glass that gives you deep insights into OpenStack and allows for taming unruly applications before they become problems, moving you from reactive crisis mode to proactive management.
Figure 1 OpenStack monitoring – cluster summary
Day 2 challenges
While deploying OpenStack has become easier over the years, operating OpenStack can still be a challenge. As the OpenStack environment grows, the complexity of managing it grows with it. Getting insights into the performance of the cloud platform is mandatory; otherwise you won’t be able to uniquely identify the root cause of performance degradations. Large scale and dynamics on cluster level as well as on application level make the use of a digital performance monitoring tool inevitable.
Figure 2 VM resource utilization on a hypervisor
Benefits of using Dynatrace for your OpenStack environment
Enterprise cloud platform monitoring
With our many years of enterprise experience and many happy customers, we‘re glad to provide you with a solution that serves all your needs. Dynatrace digital performance monitoring fills a gap – finally, there is an enterprise solution for cloud platform monitoring that also provides insights into OpenStack.
Reduce operational costs
Don’t spend countless hours with configuration, setup, and maintenance of tools that pretend to help you reduce costs. Dynatrace has one agent and zero configuration. Save time and money and focus on what’s really important. Dynatrace works out-of-the-box, is configurable to your needs, and integrates with all common deployment automation mechanisms and package managers (Puppet, Chef, Ansible, Salt, Fuel, etc.).
Capacity planning
With automatic discovery of hosts, processes, services, applications, and their interdependencies, Dynatrace provides you all the information of your baseline environment and delivers supporting parameters for the appropriate sizes of your instances.
Reduce down time, increase business continuity
Know exactly how your cloud resources are utilized and streamline them in an optimal way to save money. Identify and fix problems before your customers notice – maintaining business continuity without interruptions is the key to your success.
One tool to satisfy all teams and setups
Focus your team on your core business functionalities and let Dynatrace do the monitoring. Bring your development and operations teams closer together by working with one monitoring platform. Dynatrace supports common use cases for OpenStack, no matter if you have a public cloud offering, a private cloud with projects for your business units, or even an all-in-one setup.
Cloud migration
Dynatrace provides monitoring products that make your cloud journey not only smoother, quicker, and more transparent, but also more successful, faster, and cheaper. With an intuitive and easy to read UI enhanced with Artificial Intelligence, Dynatrace provides you answers instead of data.
Seamless integration with your application environment
No matter which technology stack you build on or which container-based technology you‘re using to orchestrate and manage your dynamic application environments on top of OpenStack; Dynatrace seamlessly integrates with almost all technologies out there, providing a holistic overview of your application, the technology stack, and OpenStack.
Figure 3 Excerpt of supported technologies
If you want to get a complete overview of all supported technologies, look here. For more detailed information about the OpenStack monitoring support of Dynatrace, check out the OpenStack monitoring page.
Dirk Wallerstorfer is Global Head of Innovation at Dynatrace. He has 15+ years of deep, hands-on experience in networking, security, and software engineering. Dirk's job is to know everything that is going on around virtualization of infrastructure and application environments. He spends his days on researching new and emerging technologies, profoundly understanding them, and sharing his experiences and findings through blog posts and during his frequent speaking engagements at conferences and meetups around the world. Dirk is from Austria, son of two, husband of one, and father of two.
