Consolidate and integrate your monitoring tools. Alanata Zabbix Integration enables you to connect existing Zabbix monitoring into Dynatrace. Enrich Dynatrace topology model with Zabbix hosts, ingest Zabbix problems, and let Davis AI engine process the problems together with native Dynatrace events in an integrated AIOps solution. With this extension, you can use Dynatrace as a unifying platform for data from external monitoring solutions, eliminate event storms, and minimize the effort spent on the investigation.
