Gather connection metrics for your VMware UAG (Unified Access Gateway).
The VMWare Unified Access Gateway (UAG) extension collects metrics from your UAG deployments using the REST API
The Extension must be installed both on an ActiveGate and on the Dynatrace Cluster. See Deploy an extension in our full documentation for more details.
Extract the extension zip file to the plugin_deployment
folder at the root of the remote plugin module.
Linux:
unzip -o -d /opt/dynatrace/remotepluginmodule/plugin_deployment custom.remote.python.vmware_uag.zip
/opt/dynatrace
Windows:
%PROGRAMFILES%\dynatrace\remotepluginmodule\plugin_deployment
Upload the same extension zip file to your tenant. The Extension configuration and upload UI is located at:
Settings > Monitored technologies > Custom extensions > Upload extension
Create an endpoint for every UAG you would like to monitor, the parameters are:
This extension consumes DDUs, the formula is:
7 * 526.5 / <frequency>
DDUs per year
