Requirements
The Extension must be installed both on a OneAgent-monitored Host and on the Dynatrace Cluster. See Deploy the extension in our full documentation for more details.
1. Install the Extension on a OneAgent-monitored Host
Extract the extension zip file to the plugin_deployment
folder at the root of the OneAgent installation.
Linux:
- A default installation can be done with the following command:
unzip -o -d /opt/dynatrace/remotepluginmodule/plugin_deployment custom.python.vmware_horizon.zip
- Adjust the path if the OneAgent was installed somewhere other than
/opt/dynatrace
Windows:
- Unzip the Extension to:
C:\Program Files (x86)\dynatrace\oneagent\plugin_deployment
2. Upload the Extension to the Dynatrace Cluster via UI in the browser
Upload the same extension zip file to your tenant. The Extension configuration and upload UI is located at:
Settings > Monitored technologies > Custom extensions > Upload extension
Configuration
VMWare Horizon monitoring will not collect metrics until you enter credentials for either a global or host configuration.
The required properties are:
- API URL
- API Username
- API Password
- API Domain
Optionally collect:
- AD Domain metrics
- Connection Server metrics
- Event Database metrics
- Farms metrics
- RDS Servers metrics
- Gateway metrics
