Collects VCenter triggered alarms into Dynatrace.
This is an ActiveGate extension that connects to VCenter via VMWare's SDK and collects alarms about any entity on the VCenter inventory as long as it was a triggered alarm.
There are two steps to install an Activegate extension:
Environment Activegate server - Extract the extension zip file to the plugin_deployment folder of the remote plugin module
Linux ActiveGate:
unzip -o -d /opt/dynatrace/remotepluginmodule/plugin_deployment custom.remote.python.vcenter_alarms.zip
/opt/dynatrace
Windows ActiveGate:
<DYNATRACE-INSTALLDIR>\remotepluginmodule\plugin_deployment\
directory. Windows likes to create a folder named after the zip file in itself, so make sure you do not end up with two custom.remote.python.vcenter_alarms
folder levels within itself.Browser - Upload the custom.remote.python.vcenter_alarms.zip
file to your tenant
Settings > Monitored technologies > Custom extensions > Upload extension
VCenter showing total triggered alarms (selected and unselected).
Alert collected from VCenter showing which entity triggered it
