Software Intelligence Hub
A curated catalogue of supported technologies, integrations and extensions provided by Dynatrace and trusted partners.
OneAgent
All the operational and business performance metrics you need.
  • dynatrace
  • host
ActiveGate
Route traffic, monitor cloud environments, monitor remote technologies with extensions and run synthetic monitors.
  • dynatrace
  • extension
  • http
  • monitoring
  • synthetic
ActiveMQ
Open source message broker written in Java together with a full Java Message Service client.
  • message-queue
Adobe Analytics
Get real-time answers for business anomalies with shared business context from Adobe Analytics
  • adobe
  • adobe analytics
  • analytics
  • business
  • dem
  • digital experience
  • marketing
Adobe PhoneGap
Monitor hybrid mobile apps built with Adobe PhoneGap running on iOS or Android
  • android
  • cross-platform
  • hybrid-app
  • ios
  • mobile
  • mobile-app
  • mobile-app-monitoring
  • web
ADO.NET
Solve ADO.NET performance problems at code level.
  • data-access
  • framework
Akamas
AkamasAkamas
AI-driven full-stack solution for continuous performance optimization.
  • application-performance
  • autonomous-performance-optimization
  • partner
Akka
Powerful reactive, concurrent, and distributed applications in Java and Scala.
  • java
  • jvm
  • virtual-machine
  • vm
amasol
amasol AGamasol AG
Seamlessly organize your IT infrastructure with maximum scalability, security and availability.
  • cloud
  • synthetic
Amazon API Gateway
Service for developers to create, publish, maintain, monitor, and secure APIs.
  • cloud
Amazon AppStream 2.0
Fully managed application streaming service that provides users with instant access to their desktop applications from anywhere.
  • cloud
Amazon Athena
Interactive query service that makes it easy to analyze data directly in Amazon S3 using standard SQL.
  • cloud
Amazon Aurora
Relational database service developed and offered by Amazon Web Services.
  • cloud
Amazon CloudFront
Content delivery network offered by Amazon Web Services.
  • cloud
Amazon CloudSearch
Set up, manage, and scale a search solution for your website or application using CloudSearch.
  • cloud
Amazon Cloudwatch
Monitoring service for AWS cloud resources and the applications you run on AWS.
  • cloud
Amazon CloudWatch Logs
Monitor, store, and access your log files from instances, AWS CloudTrail, Route 53, and other sources.
  • cloud
Amazon Cognito
Add user sign-up, sign-in, and access control to your web and mobile apps quickly and easily.
  • cloud
Amazon Connect
Easy to use omnichannel cloud contact center that helps you to provide superior customer service at a lower cost.
    Amazon DocumentDB
    Amazon DocumentDB (with MongoDB compatibility) is a fast, reliable, and fully managed database service.
    • cloud
    Amazon DynamoDB
    Fully managed NoSQL database service that supports key-value and document data structures.
    • cloud
    Amazon DynamoDB Accelerator (DAX)
    Fully managed, highly available, in-memory cache for your Amazon DynamoDB.
      Amazon EC2
      Web service that provides secure, resizable compute capacity in the cloud.
      • cloud
      Amazon EC2 Auto Scaling
      Amazon EC2 Auto Scaling helps you ensure that you have the correct number of Amazon EC2 instances available.
      • cloud
      Amazon EC2 Spot Fleet
      Spot Instances and On-Demand Instances to meet the target capacity that you specified.
      • cloud
      Amazon ElastiCache
      Fully managed in-memory data store and cache service by Amazon Web Services.
      • cloud
      Amazon Elastic Block Store (EBS)
      Raw block-level storage that can be attached to Amazon EC2 instances.
      • cloud
      Amazon Elastic Container Service (ECS)
      Fully managed container orchestration service.
      • cloud
      Amazon Elastic File Service (EFS)
      Cloud storage service provided by Amazon Web Services.
      • cloud
      Amazon Elastic Inference
      Accelerate deep learning inference workloads by attaching to your Amazon EC2 CPU instances.
      • cloud
      Amazon Elastic Kubernetes Service (EKS)
      Kubernetes service that allows you to run on AWS without managing the control plane.
      • cloud
      • container
      • k8s
      • Kubernetes
      Amazon Elasticsearch Service
      Fully managed service to deploy, secure, and run Elasticsearch cost effectively at scale, without the operational overhead.
      • cloud
      Amazon Elastic Transcoder
      Convert and transcode media files stored in Amazon S3.
      • cloud
      Amazon EMR
      Cloud big data platform for processing vast amounts of data using open source tools.
      • cloud
      Amazon EventBridge
      Serverless event bus to connect applications together using data from your own applications, integrated SaaS applications, and AWS services.
      • cloud
      Amazon FSx for Lustre
      Makes it easy and cost-effective to launch and run the popular, high-performance Lustre file system.
      • cloud
      Amazon FSx for Windows File Server
      Provides a managed Microsoft Windows file servers, backed by a native Windows file system.
      • cloud
      Amazon GameLift
      Enables developers to deploy, operate, and scale dedicated, low-cost servers in the cloud for session-based, multiplayer games.
      • cloud
      Amazon Inspector
      Tests the network accessibility of your EC2 instances and the security state of your applications that run on those instances.
      • cloud
      Amazon Keyspaces for Apache Cassandra
      Scalable, highly available, and managed Apache Cassandra–compatible database service.
      • cloud
      Amazon Kinesis Data Analytics
      Transform and analyze streaming data in real time with open source framework and engine for processing data streams (Apache Flink).
      • cloud
      Amazon Kinesis Data Firehose
      Fully managed service for delivering real-time streaming data.
      • cloud
      Amazon Kinesis Data Streams
      Collect log and event data from sources such as servers, desktops, and mobile devices.
      • cloud
      Amazon Kinesis Video Streams
      Provides you SDKs to install on your devices to make it easy to stream media.
      • cloud
      Amazon Lex
      Service for building conversational interfaces for applications using voice and text.
      • cloud
      Amazon MSK
      Fully managed service that enables you to build and run applications that use Apache Kafka to process streaming data.
      • cloud
      Amazon Neptune
      Fast, reliable, fully managed graph database built for highly connected datasets.
      • cloud
      Amazon Polly
      Cloud service that converts text into lifelike speech.
      • cloud
      Amazon Quantum Ledger Database (QLDB)
      Ledger by a central trusted authority that provides an immutable, and cryptographically verifiable transaction log.
      • cloud
      Amazon Redshift
      Data warehouse product which forms part of the larger cloud-computing platform AWS.
      • cloud
      Amazon Rekognition
      Amazon Rekognition makes it easy to add image and video analysis to your applications.
      • cloud
      Amazon Relational Database Service (RDS)
      Cloud web service designed to simplify the setup, operation, and scaling of a relational database.
      • cloud
      Amazon Route 53
      Effectively connects user requests to infrastructure running in AWS.
      • cloud
      Amazon S3
      Provides object storage through a web service interface.
      • cloud
      Amazon SageMaker
      Build, train, and deploy machine learning (ML) models quickly.
      • cloud
      Amazon Simple Email Service (SES)
      Cloud-based service that helps developers send marketing, notification, and transactional emails.
      • cloud
      Amazon Simple Notification Service (SNS)
      Provides a simple web services interface that can be used to create topics you want to notify apps.
      • cloud
      Amazon Simple Queue Service (SQS)
      Programmatic sending of messages via web service applications.
      • cloud
      Amazon Simple Workflow Service (SWF)
      Makes it easy to build applications that coordinate work across distributed components.
      • cloud
      Amazon Textract
      Makes it easy to add document text detection and analysis to your applications.
      • cloud
      Amazon Transfer Family
      Provides fully managed support for file transfers directly into and out of Amazon S3 using SFTP, FTPS, and FTP
        Amazon Translate
        Text translation service using machine learning to provide high-quality translation on demand.
        • cloud
        Amazon VPC (NAT Gateway)
        Connect to the Internet from instances within a private subnet in an AWS Virtual Private Cloud.
        • cloud
        Amazon WorkMail
        Secure, managed business email and calendaring service with support for existing desktop and mobile email clients.
        • cloud
        Amazon WorkSpaces
        Enables you to provision virtual, cloud-based Microsoft Windows or Amazon Linux desktops, known as WorkSpaces.
        • cloud
        Amazon MQ
        Managed message broker service for Apache ActiveMQ that makes it easy to migrate to a message broker in the cloud.
        • cloud
        AMP
        Accelerated Mobile Pages performance monitoring to ensure perfect user experience.
        • framework
        • web
        Android
        Monitor mobile applications that are running on the popular Android operating system.
        • android
        • application-performance-monitoring
        • full-stack
        • mobile
        • mobile-app
        • monitoring
        • performance
        Android Webkit
        Provides tools for browsing the web.
        • android
        • web
        Angular
        Platform for building mobile and desktop web applications.
        • framework
        • real-user-monitoring
        • web
        AngularJS
        JavaScript-based open-source front-end web framework mainly maintained by Google.
        • apm
        • full-stack-web
        • spa-monitoring
        • web
        • web-monitoring
        Ansible
        The simplest way to automate apps and IT infrastructure.
        • ci/cd
        • devops
        Ansible Tower
        Way to automate apps and IT infrastructure.
        • ci/cd
        • devops
        Apache Axis2
        Core engine for Web services.
        • web-service
        Apache Cordova
        Monitor hybrid mobile apps built with Cordova running on iOS or Android
        • android
        • cross-platform
        • hybrid-app
        • ios
        • mobile
        • mobile-app
        • web
        Apache CXF
        Open-source, fully featured Web services framework.
        • framework
        • web-service
        Apache HTTP Server
        Develop and maintain an open-source HTTP server.
        • full-stack
        • monitoring
        • performance
        • web
        • web-server
        Apache JMeter
        Build management and continuous integration server from JetBrains.
        • load-testing
        Apache Kafka
        Apache Kafka is an open-source, distributed publish-subscribe message bus designed to be fast, scalable, and durable.
        • apache
        • database
        • message-broker
        • message-queue
        • messaging-project
        • stream-processing
        Apache Mesos/Marathon
        Abstracts CPU, memory and storage away from machines, enabling to easily run systems effectively.
        • cluster
        Apache Solr
        Open-source enterprise-search platform, written in Java, from the Apache Lucene project.
        • apache
        • search
        • web
        Apache Spark
        Distributed general-purpose cluster-computing framework for programming entire clusters.
        • apache
        • cluster
        • framework
        Apache Tomcat
        Open source implementation of the Java Servlet, Pages, Expression Language and WebSocket.
        • http
        • java
        Apache TomEE
        Java Enterprise Edition of Apache Tomcat that combines several Java enterprise projects.
        • java
        Apigee Edge
        Design, secure, and analyze APIs across the entire API lifecycle.
        • analytics
        • api
        • gateway
        • security
        Apple Safari
        Graphical web browser developed by Apple, based on the WebKit engine.
        • apple
        • browser
        ASP.NET
        Deep visibility into the code execution of your ASP.NET apps.
        • framework
        • web
        ASP.NET AJAX
        Set of extensions to ASP.NET
        • framework
        • web
        ASP.NET Core
        Deep visibility into the code execution of your ASP.NET Core apps.
        • framework
        • web
        ASP.NET MVC
        Deep visibility into the code execution of your ASP.NET MVC apps.
        • framework
        • web
        ASP.NET Owin/Katana
        Flexible set of components for building and hosting OWIN-based web applications.
        • framework
        • web
        Atlassian
        Atlassian, Dynatrace & DevOps partners - integrating AI and automation for high-caliber orchestration and collaboration.
        • atlassian
        • integration
        Atlassian Bamboo
        Continuous integration and continuous deployment server developed by Atlassian.
        • atlassian
        • ci/cd
        • devops
        Atlassian JIRA
        Issue tracking product that allows bug tracking and agile project management.
        • atlassian
        • project-management
        • tracking
        AWS
        Reliable, scalable, and inexpensive cloud computing services with pay-as-you-go pricing approach.
        • Amazon Web Services
        • apm
        • application-monitoring
        • application-performance-management
        • cloud-and-infrastructure
        • cloud-and-microservices
        • full-stack
        • full-stack-web
        • log-analytics
        AWS AppSync
        Enterprise-level, fully managed GraphQL service with real-time data synchronization and offline programming features.
        • cloud
        AWS Billing and Cost Management
        The service that you use to pay your AWS bill, monitor usage, and analyze and control costs.
        • cloud
        AWS Chatbot
        Enables DevOps to use Amazon Chime and Slack chat rooms to monitor and respond to events.
        • cloud
        AWS CloudHSM
        Hardware security modules (HSM) in the AWS Cloud.
        • cloud
        AWS CodeDeploy
        Fully managed service that automates software deployments to a variety of compute services.
        • ci/cd
        • cloud
        • devops
        AWS CodePipeline
        Continuous delivery service automating release pipelines for application and infrastructure updates.
        • ci/cd
        • cloud
        • devops
        AWS Database Migration Service
        Makes it easy to migrate relational databases, and other types of data stores.
        • cloud
        AWS DataSync
        Transfer service designed to simplify and automate copying large amounts of data to and from AWS services.
        • cloud
        AWS Direct Connect
        Links your internal network to an AWS Direct Connect location over a standard Ethernet fiber-optic cable.
        • cloud
        AWS Elastic Beanstalk
        Quickly deploy and manage applications in the AWS Cloud without having to learn about the infrastructure beneath.
        • cloud
        • devops
        AWS Elastic Load Balancing
        Automatically distributes incoming application traffic across multiple targets.
        • cloud
        AWS Elemental MediaConnect
        Service that makes it easy for broadcasters and other premium video providers to reliably ingest live video into the AWS Cloud.
        • cloud
        AWS Elemental MediaConvert
        File-based video processing service that provides scalable video processing for content owners and distributors.
        • cloud
        AWS Elemental MediaPackage
        Just-in-time video packaging and origination service that runs in the AWS Cloud.
        • cloud
        AWS Elemental MediaTailor
        Scalable ad insertion service that runs in the AWS Cloud.
        • cloud
        AWS Fargate
        Serverless compute for containers. Dynatrace provides automatic monitoring of AWS Fargate containers at scale.
        • cloud
        • ECS
        • EKS
        • serverless
        • serverless containers
        AWS Glue
        Fully managed extract, transform, and load (ETL) service.
        • cloud
        AWS IoT
        Run local compute, messaging, data caching, and machine learning inference capabilities.
        • cloud
        AWS IoT Analytics
        Automates the steps required to analyze data from IoT devices.
        • cloud
        AWS IoT Things Graph
        Orchestration service that simplifies development of IoT applications.
        • cloud
        AWS Lambda
        Automatic and intelligent end-to-end observability for AWS Lambda traces.
        • cloud
        • faas
        • java
        • nodejs
        • python
        • serverless
        • serverless function
        AWS OpsWorks
        Configuration management service that helps you configure and operate applications by using Puppet or Chef.
        • cloud
        AWS Outposts
        Fully managed service that extends AWS infrastructure, AWS services, APIs, and much more.
        • cloud
        AWS PrivateLink
        Provides private connectivity between VPCs, AWS services, and on-premises applications.
        • cloud
        AWS RoboMaker
        Service that makes it easy to create robotics applications at scale.
        • cloud
        AWS Service Catalog
        Enables organizations to create and manage catalogs of IT services that are approved for use on AWS.
        • cloud
        AWS Site-to-Site VPN
        Allows connecting and routing from your VPC to your remote network.
        • cloud
        AWS Step Functions
        Enables you to coordinate the components of distributed applications and microservices using visual workflows.
        • cloud
        AWS Storage Gateway
        Connects an on-premises software appliance with cloud-based storage to provide data security.
        • cloud
        AWS Systems Manager
        View and control your infrastructure on AWS using Systems Manager.
        • cloud
        AWS Transit Gateway
        Network transit hub interconnecting virtual private clouds (VPC) and on-premises networks.
        • cloud
        AWS Trusted Advisor
        Identifies ways to reduce cost, increase performance, and improve security for your AWS account.
        • cloud
        AWS Web Application Firewall (WAF)
        Web application firewall that lets you monitor the HTTP(S) requests.
        • cloud
        Azure Analysis Services
        Fully managed platform as a service (PaaS) that provides enterprise-grade data models in the cloud.
        • cloud
        Azure Anomaly Detector
        Detects anomalies in time series data with numerical values that are uniformly spaced in time.
        • ai
        • machine-learning
        • Microsoft Azure
        Azure API Management
        Create consistent and modern API gateways for existing back-end services.
        • cloud
        Azure App Configuration
        Service to provide centrally managed application settings and feature flags.
        • cloud
        Azure Application Gateway
        Web traffic load balancer that enables you to manage traffic to your web applications.
        • cloud
        Azure Application Insights
        An extensible Application Performance Management (APM) service for developers and DevOps.
        • cloud
        Azure App Service
        Cloud computing based platform for hosting websites, created and operated by Microsoft.
        • cloud
        Azure Automation account
        Allows you to automate your Azure management tasks and to orchestrate actions across external systems from right within Azure.
        • cloud
        Azure Batch
        Get complete picture of jobs, tasks and node tracking, in each state, for operational efficiency.
        • cloud
        Azure Bing Autosuggest
        Helps users complete queries faster by adding intelligent type-ahead capabilities to your app or website.
        • ai
        • machine-learning
        • Microsoft Azure
        Azure Bing Custom Search
        An easy-to-use, ad-free, commercial-grade search tool that lets you deliver the results you want.
        • ai
        • machine-learning
        • Microsoft Azure
        Azure Bing Entity Search
        Bring rich context data to your apps through entity information for a more engaging experience.
        • ai
        • machine-learning
        • Microsoft Azure
        Azure Bing Search
        Build apps and services that find webpages, images, news, locations, and more.
        • ai
        • machine-learning
        • Microsoft Azure
        Azure Bing Spell Check
        Correct spelling and word breaks errors, recognize slang, names, homonyms, brands and more.
        • ai
        • machine-learning
        • Microsoft Azure
        Azure Blob Storage
        Handles stored objects, with millions of requests per second, for customers around the world.
        • cloud
        Azure Blockchain
        Fully managed ledger service that enables users the ability to grow and operate blockchain networks at scale in Azure.
        • cloud
        Azure Cache for Redis
        Industry-standard SSL to secure your data in transit and Azure Storage disk encryption at rest.
        • cloud
        Azure CDN profiles
        Collections of CDN endpoints and each CDN profile contains one or more CDN endpoints.
        • cloud
        Azure Cloud Services (Classic)
        Deploy web apps (web roles) and background services (worker roles) onto Azure virtual machines.
        • cloud
        Azure CloudSimple Virtual Machines
        Manage VMware virtual machines (VMs) from the Azure portal.
        • cloud
        early
        Azure Cognitive Services
        Bring AI within reach of every developer—without requiring machine-learning expertise.
        • cloud
        Azure Computer Vision
        AI service to boost content discoverability, automate text extraction, analyze video in real time, and more.
        • ai
        • machine-learning
        • Microsoft Azure
        Azure Connections
        This tool is designed to meet and accomplish your hybrid identity goals.
        • cloud
        soon
        Azure Container Instance
        Deploy and manage serverless containers on the Microsoft Azure cloud, without having to manage any underlying infrastructure.
        • aks
        • azure kubernetes service
        • cloud
        • serverless
        Azure Container Registries
        Managed, private Docker registry service based on the open-source Docker Registry 2.0.
        • cloud
        Azure Content Moderator
        AI service for content moderation and human review tool for images, text, and videos.
        • ai
        • machine-learning
        • Microsoft Azure
        Azure Cosmos DB
        Globally-distributed, multi-model database service "for managing data at planet-scale".
        • cloud
        Azure Custom Vision Prediction
        Customize computer vision for specific domain. No machine learning expertise is required.
        • ai
        • machine-learning
        • Microsoft Azure
        Azure Custom Vision Training
        • ai
        • machine-learning
        • Microsoft Azure
        Azure Database for Maria DB
        Full coverage of performance for critical workloads with AI-problem detection, availability, and more.
        • cloud
        Azure Database for MySQL
        Full observability of MYSQL servers and database instances to ensure database health and performance.
        • cloud
        Azure Database for PostgreSQL
        Full insight into database performance for critical workloads with AI-problem detection and more.
        • cloud
        Azure Data Box Edge
        Rebranded as Azure Stack Edge. ... Azure Stack Edge is a Hardware-as-a-service solution.
        • cloud
        soon
        Azure Data Catalog
        Fully managed cloud service that lets users discover the data sources they need and understand the data sources they find.
        • cloud
        Azure Data Explorer Clusters
        Engine and data management clusters which uses several Azure resources such as Azure Linux VM's and Storage.
        • cloud
        Azure Data Factory
        Cloud-based ETL and data integration service for creating data-driven workflows for moving and transforming data at scale.
        • cloud
        Azure Data Lake Analytics
        Distributed, cloud-based data processing architecture offered by Microsoft in the Azure cloud.
        • cloud
        Azure Data Lake Storage
        Fully-managed, elastic, scalable, and secure file system that supports HDFS semantics and works with the Hadoop ecosystem.
        • cloud
        Azure Data Share
        Platform as a Service tool that allows you to share data sets using Azure Services.
        • cloud
        Azure Device Provisioning Service
        Helper service for IoT Hub that enables just-in-time provisioning to the right IoT hub without human intervention.
        • cloud
        Azure DevOps Keptn Extension
        RealdolmenRealdolmen
        Integrate Dynatrace via Keptn into your Azure DevOps Pipelines to automate SLO-based quality gates & enable performance as a self-service
        • ci/cd
        • delivery
        • devops
        • keptn
        • Microsoft Azure
        • performance
        Azure Disk Storage
        Cloud storage offering providing multiple solutions for organizations.
        • cloud
        Azure DNS Zones
        Data resource that contains the DNS records for a domain name.
        • cloud
        Azure Event Grid Domains
        Simplifies the development of event-based applications and simplifies the creation of serverless workflows.
        • cloud
        Azure Event Grid Subscriptions
        Support for Azure Event Grid Subscriptions.
        • cloud
        soon
        Azure Event Grid Topics
        Topic based events for serverless and event based workflows.
        • cloud
        Azure Event Hub Clusters
        Big data streaming platform and event ingestion service. It can receive and process millions of events per second.
        • cloud
        Azure Event Hubs
        Fully managed data ingestion service that's simple, and scalable.
        • cloud
        early
        Azure ExpressRoute
        Extend your on-premise networks into the Microsoft cloud over a private connection.
        • cloud
        Azure Express Route Circuits
        Connect your on-premises infrastructure and Microsoft cloud services through a connectivity provider.
        • cloud
        Azure Face
        An AI service that analyzes faces in images
        • ai
        • machine-learning
        • Microsoft Azure
        Azure File Storage
        Fully managed file shareing in the cloud.
        • cloud
        Azure Firewall
        Managed, cloud-based network security service that protects your Azure Virtual Network resources.
        • cloud
        Azure Front Door
        Optimize application performance with visibility into requests and latency, ensuring routing efficiency and backend health.
        • cloud
        Azure Functions
        Serverless compute functions. Dynatraces provides full observability for Azure functions end-to-end, at scale.
        • cloud
        • faas
        • serverless
        Azure HDInsight
        Holistic analytics of HDInsights with integrated metrics from Hadoop, Spark, and Kafka, all in one place.
        • cloud
        Azure Immersive Reader
        An AI service to embed text reading into applications.
          Azure Ink Recognizer
          An AI service that provides a cloud-based REST API to analyze and recognize digital ink content.
          • ai
          • machine-learning
          • Microsoft Azure
          Azure Integration Service Environment
          Allows you to deploy Logic Apps as a service in your Azure Virtual Network.
            Azure IoT Central Applications
            Fully hosted by Microsoft, which reduces the administration overhead of managing your applications.
            • cloud
            Azure IoT Hub
            Cloud-hosted solution backend to connect virtually any device.
            • cloud
            Azure Key Vault
            Cloud service within you can securely store keys, passwords, certificates, and other secrets.
            • cloud
            Azure Kubernetes Service
            Kubernetes based, managed container orchestration service, available on the Microsoft Azure public cloud.
            • cloud
            • container
            • k8s
            • Kubernetes
            Azure Kubernetes Services (AKS)
            Migrate existing application to container(s) and run within the Azure managed Kubernetes service.
            • cloud
            • container
            • k8s
            • Kubernetes
            Azure Language Understanding (LUIS)
            An AI service that allows users to interact with your applications, bots, and IoT devices by using natural language.
            • ai
            • machine-learning
            • Microsoft Azure
            Azure Load Balancer
            Layer-4 load balancer that provides high availability by distributing incoming traffic among VMs.
            • cloud
            Azure Logic Apps
            Cloud service that helps you schedule, automate, and orchestrate tasks across enterprises or organizations.
            • cloud
            Azure Machine Learning
            Collection of services and tools intended to help developers train and deploy machine learning models.
            • cloud
            Azure Maps account
            Provides the geospatial capability for mapping the data.
            • cloud
            Azure Media Services
            Cloud-based platform to build solutions that achieve broadcast-quality video streaming.
            • cloud
            Azure NetApp Capacity Pool
            Enterprise-class, high-performance, metered file storage service
              Azure NetApp files
              File-storage service to run your most demanding file-workloads in Azure, without the need for any code modification.
              • cloud
              Azure Network Interface
              Enables an Azure Virtual Machine to communicate with internet, Azure and on-premises resources.
              • cloud
              Azure Network Watcher
              Provides tools to monitor, diagnose, view metrics, and enable or disable logs for resources in an Azure virtual network.
              • cloud
              Azure Notification Hub Namespaces
              Push engine that allows you to send notifications to any platform from any backend (cloud or on-premises).
              • cloud
              Azure Peerings
              Virtual network peering enables you to seamlessly connect networks in Azure Virtual Network.
              • cloud
              early
              Azure Personalizer
              An AI service that prioritizes relevant content, layouts, and conversations to deliver personalized user experience.
              • ai
              • machine-learning
              • Microsoft Azure
              Azure Private DNS Zone
              Hosting service for DNS domains, providing name resolution using the Microsoft Azure infrastructure.
              • cloud
              Azure Public IP address
              Reserved public IP addresses for your public endpoints in Azure.
              • cloud
              Azure QnA Maker
              Build, train and publish a sophisticated bot without machine learning experience.
              • ai
              • machine-learning
              • Microsoft Azure
              Azure Queue Storage
              Service for storing large numbers of messages that can be accessed from anywhere in the world.
              • cloud
              Azure Relays
              Enables you to securely expose services that run in your corporate network to the public cloud.
              • cloud
              Azure Search Services
              Fully managed cloud search service that provides a better user experience for customers.
              • cloud
              Azure Service Bus
              Cloud messaging as a service (MaaS) and simple hybrid integration.
              • cloud
              Azure Service-Fabric
              Package, deploy, and manage scalable and reliable microservices and containers.
              • cloud
              Azure Service Fabric Mesh
              Deployment of microservice applications without managing virtual machines, storage, or networking.
              • cloud
              Azure Service-Fabric Reliable Services
              Simplifies writing and managing stateless and stateful services.
              • cloud
              Azure SignalR
              Adding real-time communications to your web application is as simple as provisioning a service.
              • cloud
              Azure Speech To Text
              An AI service that accurately converts spoken audio to text.
              • ai
              • machine-learning
              • Microsoft Azure
              Azure Spring Cloud
              Brings modern microservice patterns to Spring Boot apps eliminating boilerplate code to quickly develop robust Java apps.
              • cloud
              Azure SQL Database
              Managed cloud database provided as part of Microsoft Azure.
              • cloud
              Azure SQL Managed
              Full observability into cloud database performance and automated monitoring for Azure SQL Managed.
              • cloud
              Azure SQL Server Stratch
              Dynamically stretch warm and cold transactional data from SQL Server 2016 to Azure.
              • cloud
              Azure Storage Sync Service
              Centralize your file shares in the cloud while keeping the benefits of an on-premise file server.
              • cloud
              Azure Stream Analytics Jobs
              Serverless job service that eliminates the need for infrastructure, servers, virtual machines, or managed clusters.
              • cloud
              Azure Synapse Analytics
              Cloud-based, scale-out, relational database capable of processing massive volumes of data.
              • cloud
              Azure Table Storage
              Stores structured NoSQL data in the cloud, providing a key/attribute store with a schemaless design.
              • cloud
              Azure Text Analytics
              Uncover insights such as sentiment, entities, and key phrases in unstructured text.
              • ai
              • machine-learning
              • Microsoft Azure
              Azure Time Series Insights
              Fully managed analytics, storage, and visualization service for managing IoT-scale time-series data in the cloud.
              • cloud
              Azure Traffic Manager
              Multi-cloud support for improved application performance and availability with distributed tracing.
              • cloud
              Azure Translator
              AI powered service to translate text in real time across more than 70 languages.
              • ai
              • machine-learning
              • Microsoft Azure
              Azure Virtual Machines
              Documentation for creating and managing Windows virtual machines in Azure.
              • cloud
              Azure Virtual Machine Scale Sets
              Scale-out workloads, stateless web front ends, container orchestration, and microservices clusters.
              • cloud
              Azure Virtual machines (classic)
              Deep observability into Azure cloud service virtual machines and applications.
              • cloud
              Azure Virtual Network Gateway
              Monitor connecting workloads and performance to ensure Azure network is successfully connected.
              • cloud
              Azure Virtual Networks
              Fundamental building block for your private network in Azure. VNet enables many types of Azure resources.
              • cloud
              Azure Web Apps
              Host websites, web apps, RESTful APIs, and mobile back ends in Azure App Service.
              • cloud
              Backbone.js
              JavaScript library based on the Model–view–presenter application design paradigm.
              • full-stack
              • spa-monitoring
              • web
              Bitbucket
              Version control repository service for source code thas use either Mercurial or Git systems.
              • ci/cd
              • devops
              • version-control
              Blazemeter
              Commercial, self-service load testing platform as a service.
              • ci/cd
              • devops
              BOSH bpm
              Auto-injection in BOSH bpm container (Deep monitoring)
              • container
              C
              Procedural programming language supporting lexical variable scope, and recursion.
              • performance
              • programming-language
              C++
              High-level, general-purpose programming language as an extension of the C programming language.
              • performance
              CakePHP
              Open-source web framework, model–view–controller approach.
              • php
              • web
              Cassandra
              Right choice when you need scalability and high availability without compromising performance.
              • database
              CentOS
              Community-supported computing platform compatible with Red Hat Enterprise Linux.
              • cloud
              • infrastructure
              • server-monitoring
              Chef
              Configuration management tool.
              • ci/cd
              • devops
              Cisco Adaptive Security Appliance (ASA)
              Platform Extension ServicesPlatform Extension Services
              Monitor your Cisco Adaptive Security Appliance (ASA) devices
              • extension
              • infrastructure
              • network
              Citrix NetScaler ADC
              All-in-one web ADC that makes applications run up to five times faster.
              • extension
              • security
              • virtualization
              Citrix Virtual Apps and Desktops
              Complete virtual app and desktop solution to meet all your business needs.
              • access-control
              • monitoring
              CloudFlare
              Content-delivery-network services, DDoS mitigation, Internet security, and distributed services.
              • web
              Cloud Foundry
              Open source cloud application platform for developing and deploying cloud applications.
              • apm
              • cloud
              • devops
              • full-stack
              • infrastructure
              • log-analytics
              • monitoring
              • web
              Concourse
              Concourse is the automation engine for cloud native CI/CD.
              • ci/cd
              • devops
              Connection Pools: JBoss
              Application server method of pooling and sharing multiple connections to a database.
              • connection pool
              • database
              • jboss
              • pool
              • red-hat
              • wildfly
              Connection Pools: Tomcat
              • apache
              • connection pool
              • database
              • pool
              • tomcat
              Connection Pools: WebLogic
              • connection pool
              • database
              • pool
              • weblogic
              Connection Pools: WebSphere Liberty
              • connection pool
              • database
              • liberty
              • pool
              • websphere
              containerd
              Automated deep monitoring w/o code-changes for apps and microservices running in containerd containers in Kubernetes.
              • container
              • k8s
              • Kubernetes
              Control-M Jobs
              Monitor your Control-M jobs execution status
              • extension
              • infrastructure
              • server
              CoreDNS
              Detailed visibility of CoreDNS server health state and throughput
              • OneAgent
              • plugin
              CoreOS
              Open-source lightweight OS based on the Linux, providing infrastructure to clustered deployments.
              • cloud
              • infrastructure
              • k8s
              • Kubernetes
              • server-monitoring
              Couchbase
              NoSQL document-oriented database software package optimized for interactive applications.
              • database
              CouchDB
              Open-source document-oriented NoSQL database, implemented in Erlang.
              • database
              cri-o
              Automated deep monitoring w/o code-changes for apps and microservices running in cri-o containers in Kubernetes.
              • container
              • k8s
              • Kubernetes
              Custom Database Queries
              Make custom databases queries to your Oracle, Postgres, MSSQL or DB2 databases and send the metrics to Dynatrace
              • database
              • extension
              • monitoring
              Davis Assistant
              Immediate actionable answers to complex questions with a simple conversation.
              • ai
              • virtual assistant
              • voice assistant
              • voice navigation
              DC/OS
              Monitor application and cluster health in highly-dynamic container environments.
              • apm
              • cloud
              • full-stack
              • infrastructure
              • microservices
              • monitoring
              • performance
              • web
              Debian
              Association of individuals who have made common cause to create a free operating system.
              • cloud
              • infrastructure
              • server-monitoring
              Deploy OneAgents with Ansible
              Ansible collection for OneAgent deployment is an official and supported method for rolling out OneAgents in large environments.
              • deployment
              • OneAgent
              soon
              Docker
              OS-level virtualization to deliver software in packages called containers.
              • apm
              • ci/cd
              • cloud
              • devops
              • full-stack
              • infrastructure
              • k8s
              • Kubernetes
              • log-analytics
              • microservices
              • monitoring
              • performance
              • web
              Dojo
              Modular JavaScript library open source based.
              • full-stack
              • web
              Drupal
              Web content management for back-end framework.
              • php-monitoring
              • web
              Dynatrace App for Android
              The Dynatrace mobile app provides real-time alerts detected in your application environment.
              • messaging-alerting-integration
              Dynatrace app for iOS
              Provides real-time alerts on your iPhone/iPad when performance problems are detected.
              • full-stack
              • web
              Eclipse
              Integrated development environment.
              • ci/cd
              • devops
              Eclipse Jetty
              Provides a Web server and javax.servlet container.
              • container
              • Eclipse
              • http
              • java
              Elasticsearch
              Provides a distributed, multitenant-capable full-text search engine, based on the Lucene library.
              • ci/cd
              • database
              • devops
              • performance
              • search
              Electric Cloud
              DevOps software by Cloudbees.
              • ci/cd
              • devops
              Ember.js
              Open-source JavaScript web framework, based on the Model–view–viewmodel pattern.
              • full-stack
              • spa-monitoring
              • web
              Erlang
              General-purpose, concurrent, functional programming language, and a runtime system.
              • garbage-collector
              • performance
              Eureka
              Used in the AWS cloud for locating services for load balancing and failover of servers.
              • cloud
              • infrastructure
              Express
              Fast, unopinionated, minimalist web framework for Node.js.
              • framework
              • nodejs
              F5 BIG-IP LTM
              Intelligently manages network traffic so applications are always fast, available, and secure.
              • plugin
              Fedora
              Linux distribution sponsored primarily by Red Hat, a subsidiary of IBM.
              • cloud
              • infrastructure
              • server-monitoring
              Files checks
              Check for files existence, size, modification date, content or permissions
              • extension
              • infrastructure
              Fluentd
              Stream your logs via Fluentd to Dynatrace and analyze them
              • data-collection
              • Kubernetes
              soon
              Flutter
              Monitor mobile applications built with Flutter on iOS or Android.
              • android
              • cross-platform
              • hybrid-app
              • ios
              • mobile
              • mobile-app
              Fortinet Fortigate
              Monitor your Fortigate devices via the REST API
              • extension
              • infrastructure
              • monitoring
              • network
              Fujitsu Interstage
              Suite of inter-working software products.
              • business-collaboration-platform
              Fujitsu Interstage IHS
              Complete suite of software that helps companies continuously visualize and optimize their business.
              • business collaboration platform
              Garden-RunC
              Auto-injection in Garden-RunC container (Deep monitoring)
              • container
              Gatling
              Open-source load and performance testing framework based on Scala, Akka and Netty.
              • ci/cd
              • devops
              GlassFish
              Open source Java EE reference implementation.
              • java
              • performance
              Go
              Open source language that makes it easy to build simple, reliable, and efficient software.
              • log-analytics
              • performance
              Google Analytics
              Track and optimize marketing campaigns with shared business context from UTM parameters tracked in Google Analytics.
              • analytics
              • business
              • dem
              • marketing
              Google App Engine
              Service and cloud computing platform for developing and hosting web applications.
              • cloud
              Google Big Query
              Enterprise data warehouse.
              • cloud
              soon
              Google Bigtable
              NoSQL Big Data database service.
              • cloud
              soon
              Google Chrome
              Cross-platform web browser developed by Google.
              • browser
              • web
              Google Cloud APIs
              Programmatic interfaces for Google Cloud services.
              • cloud
              Google Cloud Composer
              A fully managed workflow orchestration service.
              • cloud
              soon
              Google Cloud Dataflow
              Streaming analytics service.
              • cloud
              soon
              Google Cloud Dataproc
              A cloud service for running Apache Spark and Apache Hadoop clusters.
              • cloud
              soon
              Google Cloud DNS
              Support for Google Cloud DNS.
              • cloud
              soon
              Google Cloud Filestore
              High-performance, fully managed file storage.
              • cloud
              Google Cloud Firestore
              A flexible, scalable database for mobile, web, and server development.
              • cloud
              soon
              Google Cloud Interconnect
              Get direct physical connections between your on-prem network and Google Cloud.
              • cloud
              soon
              Google Cloud IoT
              Secure device connection and management.
              • cloud
              soon
              Google Cloud Load Balancing
              High performance, scalable load balancing across multiple targets.
              • cloud
              Google Cloud Memorystore for Redis
              A fully managed in-memory data store service.
              • cloud
              soon
              Google Cloud Platform
              Meet your business challenges head on with cloud computing services from Google.
              • cloud
              • infrastructure
              • log-analytics
              • microservices
              Google Cloud Router
              Exchange routes between your VPC and on-premises networks by using BGP.
              • cloud
              soon
              Google Cloud Run
              Dynatrace provides AI-powered observability into serverless containerized apps running on Google Cloud Run
              • cloud
              • serverless
              Google Cloud SQL
              MySQL database service.
              • cloud
              Google Cloud Storage
              Reliable and secure object storage for any amount of data.
              • cloud
              Google Cloud Tasks
              Distributed task queues.
              • cloud
              soon
              Google Cloud Tensor Processing Unit (TPU)
              Train and run machine learning models.
              • cloud
              soon
              Google CloudTrace
              Distributed tracing system that collects latency data from your apps and displays it in the GCP.
              • cloud
              soon
              Google Compute Engine
              Service component of Google Cloud Platform, built on the global infrastructure.
              • cloud
              Google Container-optimized OS
              Dynatrace OneAgent monitors Kubernetes nodes with Google's secure Container-optimized OS quickly, efficiently, and securely.
              • cloud
              • k8s
              • Kubernetes
              Google Data Loss Prevention (DLP)
              Provides fast, scalable classification and redaction for sensitive data elements.
              • cloud
              soon
              Google Datastore
              NoSQL database.
              • cloud
              Google Firebase Storage, Hosting, Database
              Mobile platform for application development.
              • cloud
              soon
              Google Functions
              Serverless platform for building event-based microservices.
              • cloud
              Google Kubernetes Engine (GKE)
              Dynatrace provides AI powered observability for Google Kubernetes Engine pods, nodes, and clusters.
              • cloud
              • container
              • k8s
              • Kubernetes
              Google Machine Learning
              Machine learning services.
              • cloud
              soon
              Google Managed Service for Microsoft Active Directory
              Service running Microsoft AD that enables you to manage authentication and authorization.
              • cloud
              soon
              Google Network Topology
              Visualization tool for viewing the topology of your VPC networks and the metrics.
              • cloud
              soon
              Google Pub/Sub
              Real-time messaging service.
              • cloud
              Google reCAPTCHA Enterprise
              Help protect your website from fraudulent activity, spam, and abuse.
              • cloud
              soon
              Google Spanner
              Horizontally scalable, globally consistent, relational database service.
              • cloud
              soon
              Google Storage transfer
              Complete large-scale online data transfers from online and on-premises sources to Cloud Storage.
              • cloud
              soon
              Google VPC access
              Provides support for Google VPC access.
              • cloud
              soon
              GraalVM
              Java VM and JDK based on HotSpot/OpenJDK, implemented in Java.
              • cloud
              • infrastructure
              Gradle
              Build automation system that introduces a language for declaring the project configuration.
              • ci/cd
              • devops
              Grails
              Groovy-based web application framework for the JVM built on top of Spring Boot.
              • java
              • performance
              gRPC
              Open source remote procedure call (RPC) system.
              • procedure-call
              GWT Web Toolkit
              Set of tools that allows web developers to create and maintain JavaScript front-end applications.
              • application
              • front-end
              • web-tool
              Hadoop
              Collection of utilities that allows to solve problems involving massive amounts of data.
              • apache
              • performance
              HAProxy
              Load balancer and proxy server for applications that spreads requests across multiple servers.
              • Kubernetes
              • load-balancing
              HashiCorp Terraform
              Leverage Terraform to automate deployment of dashboards, custom services, management zones etc. across your complete Dynatrace instance.
              • devops
              • infrastructure as code
              Hazelcast
              Dynatrace PurePath 4 seamlessly integrates OpenTracing data for Java emitted by the Hazelcast in-memory computing platform.
              • hazelcast
              • java
              • opentracing
              early
              Heroku
              Platform as a service that enables developers to build, run, and operate applications in the cloud.
              • cloud
              • microservices
              HornetQ
              Open-source asynchronous messaging project from JBoss.
              • jboss
              • message-queue
              • messaging-project
              HTML5
              Markup language used for structuring and presenting content on the World Wide Web.
              • markup-language
              • web
              HTTP
              Application protocol for distributed, collaborative, hypermedia information systems.
              • dcrum
              • http
              • web
              HTTP2
              Binary protocol that brings push, multiplexing streams and frame control to the web.
              • http2
              • web-tech
              Hystrix
              Isolate points of access to remote systems, services, and 3rd-party libraries.
              • cloud
              • infrastructure
              IBM AIX
              Series of proprietary Unix operating systems developed and sold by IBM.
              • cloud
              • ibm
              • infrastructure
              • server-monitoring
              IBM App Connect Enterprise
              Allows business information to flow between applications across multiple platforms.
              • ibm
              • integration
              IBM Bluemix
              Architecture diagram templates to create your own architectures using simple icons.
              • cloud
              • infrastructure
              IBM CICS
              General-purpose transaction processing subsystem for the z/OS® operating system.
              • ibm
              • mainframe
              • z/OS
              IBM Cloud
              Set of cloud computing services for business offered by the information technology company IBM.
              • cloud
              • ibm
              • infrastructure
              • Kubernetes
              • microservices
              • server-monitoring
              IBM Cloud Kubernetes Service (IKS)
              Dynatrace provides AI powered observability for IBM Cloud Kubernetes Service pods, nodes, and clusters.
              • ibm
              • k8s
              • Kubernetes
              IBM DataPower
              Enables the classification of data requests based on service and application-level information.
              • datapower
              • ibm
              IBM DB2
              Data management products, including database servers, developed by IBM.
              • database
              • ibm
              • mainframe
              • z/OS
              IBM HTTP Server
              Web server that runs on AIX, HP-UX, Linux, Solaris, JADE, Windows NT, IBM i and z/OS.
              • httpserver
              • ibm
              • server
              • web
              IBM i
              Versatile, Multi-Environment H2Servers for the Era of e-business on demand.
              • extension
              • ibm
              IBM IMS
              Database and information management system with extensive transaction processing capabilities.
              • ibm
              • mainframe
              • z/OS
              IBM Integration Bus
              • ibm
              • integration
              IBM JVM
              Platform-specific component that runs a Java program.
              • ibm
              IBM MQ
              Enterprise-grade messaging capabilities that safely move information between applications.
              • extension
              • ibm
              • mainframe
              • z/OS
              IBM Watson Explorer Engine
              Monitor issues in your Watson Explorer Engine collections
              • extension
              • infrastructure
              IBM WebSphere
              Application and integration middleware allowing end-users to create and integrate applications.
              • ibm
              • java
              • monitoring
              • performance
              IBM WebSphere Application Server
              Java server runtime environment for enterprise applications.
              • ibm
              • mainframe
              • z/OS
              IBM WebSphere Liberty
              Application server for modernizing and building applications and cloud-native services.
              • ibm
              • mainframe
              • z/OS
              IBM WebSphere Message Broker
              Allows information to flow between disparate applications across multiple platforms.
              • ibm
              IBM WebSphere Portal
              Enterprise software used to build and manage web portals.
              • ibm
              IBM z/Linux
              Collective term for the Linux operating system compiled to run on IBM mainframes.
              • ibm
              • infrastructure
              • linux
              • mainframe
              • server
              IBM z/Linux Java
              Monitor your entire stack with a single solution, and control the sprawl.
              • ibm
              • java
              • linux
              • mainframe
              IBM z/OS
              Mainframe operating system that offers a stable, secure, and continuously available environment.
              • ibm
              • mainframe
              • os
              • z/OS
              ICEFaces
              Open-source Rich Internet Application (RIA) development framework for Java EE.
              • full-stack
              • web
              IntelliJ
              • ci/cd
              • devops
              Ionic
              Monitor hybrid mobile apps built with the Ionic framework running on iOS or Android
              • android
              • cross-platform
              • hybrid-app
              • ios
              • mobile
              • mobile-app
              • web
              iOS
              Monitor mobile applications that are running on Apple's popular iOS operating system.
              • mobile
              • mobile-app
              iOS Safari
              • browser
              • web
              ISAM
              Collect metrics about IBM Security Access Manager (ISAM)
              • access-control
              • extension
              • ibm
              • security
              Istio
              Open platform to connect, manage, and secure microservices.
              • ci/cd
              • container
              • devops
              • Kubernetes
              Java
              The #1 programming language for IoT, enterprise architecture, and cloud.
              • apm
              • full-stack
              • log-analytics
              • retail-ecommerce
              • web
              Java JDBC
              Application programming interface for the Java, defines access to a database.
              • java
              Java JMS
              Java message-oriented middleware API for sending messages between two or more clients.
              • java
              Javascript
              Programming language that conforms to the ECMAScript specification.
              • javascript
              • web
              JBoss
              Delivers enterprise-grade security, performance, and scalability in any environment.
              • application
              • java
              • server
              • wildfly
              Jenkins
              Open source server which enables developers to reliably build, test, and deploy their software.
              • ci/cd
              • devops
              Joomla
              Management system for publishing web content.
              • php-monitoring
              • web
              jQuery
              JavaScript library designed to simplify HTML DOM tree traversal and manipulation.
              • full-stack
              • web
              Juniper Networks
              Networking & cybersecurity solutions to service providers, enterprise companies & public sector.
              • network
              Junit
              Unit testing framework for the Java programming language.
              • ci/cd
              • devops
              Jython
              Implementation of the Python programming language designed to run on the Java platform.
              • java
              Keptn
              Event-based control plane for continuous delivery and automated operations.
              • automation
              • ci/cd
              • continuous
              • delivery
              • deployment
              • Kubernetes
              Kubernetes
              Open-source system for automating deployment, scaling, and management of containerized applications.
              • apm
              • ci/cd
              • cloud
              • devops
              • full-stack
              • infrastructure
              • k8s
              • log-analytics
              • microservices
              KVM
              Virtualization module in the Linux kernel that allows the kernel to function as a hypervisor.
              • cloud
              • infrastructure
              • server-monitoring
              • virtual-infrastructure
              Laravel
              PHP web framework, intended for the development of web applications.
              • php-monitoring
              • web
              LDAP
              Vendor-neutral protocol for accessing and maintaining distributed directory information services.
              • dcrum
              • enterprise-tech
              • ldap
              LDAP Synthetic
              Execute synthetic LDAP searches to monitor the availability of your LDAP servers
              • extension
              • ldap
              LinkerdD
              Observability, reliability, and security without requiring any code changes for Kubernetes.
              • container
              • Kubernetes
              Linux
              Family of open source Unix-like operating systems based on the Linux kernel.
              • cloud
              • infrastructure
              • os
              • server-monitoring
              LoadRunner
              Load testing tool for project teams.
              • devops
              Machine Learning on AWS
              Robust, cloud-based service that makes it easy for developers of all skill levels to use machine learning technology.
              • cloud
              soon
              Magento
              Deep insight into user experience, top landing & exit pages and bounce rates.
              • retail-ecommerce
              Maven
              Muild automation tool used primarily for Java projects.
              • ci/cd
              • devops
              Memcached
              Distributed memory-caching system often used to speed up dynamic database-driven websites.
              • database
              Microsoft Active Directory replication
              Monitors the sync status of your Active Directory servers
              • extension
              • ldap
              • microsoft
              • monitoring
              • server
              Microsoft Azure
              Cloud computing service for building, testing, deploying, and managing applications and services.
              • cloud
              Microsoft Biztalk
              Gather metrics from your Biztalk Server deployments
              • extension
              • infrastructure
              • microsoft
              • monitoring
              Microsoft Edge
              Real user monitoring - visibility and monitoring starting on you clients browser (desktop, tablet, mobile)
              • browser
              • web
              Microsoft Exchange Server
              Mail server and calendaring server developed by Microsoft.
              • dcrum
              • exchange-server
              • microsoft
              Microsoft Hyper-V
              Native hypervisor that can create virtual machines on x86-64 systems running Windows.
              • microsoft
              • server
              Microsoft IIS
              Flexible, secure and manageable Web server for hosting anything on the Web for Windows® Server.
              • full-stack
              • microsoft
              • performance
              • web
              • web-server
              Microsoft Internet Explorer
              Series of graphical web browsers.
              • browser
              • web
              Microsoft Message Queuing (MSMQ)
              Gather metrics about your MSMQ queues
              • extension
              • infrastructure
              • microservices
              • monitoring
              Microsoft SQL Server
              Database management system - store and retrieve data as requested by other software applications.
              • apm
              • database
              • full-stack
              • full-stack-web
              Microsoft Teams
              Hub for team collaboration in Microsoft 365 that integrates the people, content, and tools.
              • collaboration
              • communication
              • platform
              Microsoft Visual Studio
              Integrated development environment from Microsoft.
              • application
              • mobile-apps
              • web
              MongoDB
              Distributed database built for modern application developers and for the cloud era.
              • apm
              • database
              • full-stack
              • full-stack-web
              • monitoring
              MooTools
              Object-oriented JavaScript framework. Released under the free, open-source MIT License.
              • full-stack
              • web
              Mozilla Firefox
              Free, open source web browser that uses the Gecko layout engine.
              • browser
              • web
              Mule (HTTP Listener)
              Event source enabling you to set up an HTTP server and trigger flows when requests are received.
              • http
              Mulesoft (Cloudhub)
              Gather metrics about your Workers and Applications running in Mulesoft Cloudhub
              • api
              • extension
              MySQL
              Open-source relational database management system.
              • database
              • full-stack
              • monitoring
              • performance
              • web
              NeoLoad
              NeotysNeotys
              Automated Load Testing tool enabling you to run Continuous Performance Testing.
              • performance
              • testing
              Neotys
              NeotysNeotys
              Automated performance testing platform that helps enterprises to implement continuous testing.
              • ci/cd
              • devops
              .NET
              Developer platform for building apps: web, mobile, desktop, gaming, IoT, cloud, and microservices.
              • apm
              • dotnet
              • framework
              • full-stack
              • full-stack-web
              • log-analytics
              • monitoring
              • performance
              • retail-ecommerce
              Netbackup Jobs
              Monitor your Veritas Netbackup jobs execution status
              • extension
              • infrastructure
              .NET Core
              Deep insights into the your .NET Core framework and optimize the overall performance.
              • dotnet
              • framework
              Netflix OSS
              Provides runtime containers, libraries and services that power microservices.
              • apm
              • cloud
              • infrastructure
              • microservices
              .NET Framework
              Software framework developed by Microsoft that runs primarily on Microsoft Windows.
              • framework
              .NET PCL
              Portable Class Libraries enalbes you to share code across various platform-specific projects.
              • app
              • portable-class-library
              .NET RabbitMQ
              Lightweight and easy to deploy queueing system on premises and in the cloud.
              • cloud
              • message-broker
              • open-source
              .NET Remoting
              Application programming interface for interprocess communication.
              • api
              .NET Standard
              Formal specification of .NET APIs that are intended to be available on all .NET implementations.
              • api
              Netty
              I/O client-server framework for the development of Java network applications.
              • java
              • performance
              .NET UWP
              Computing platform created by Microsoft and first introduced in Windows 10.
              • platform
              NGINX
              Accelerates application delivery, improves security, facilitates availability & scalability.
              • full-stack
              • Kubernetes
              • monitoring
              • performance
              • web
              • web-server
              NGINX Plus
              All‑in‑one load balancer, content cache, and web server.
              • application
              • full-stack
              • monitoring
              • performance
              • web
              • web-server
              Node.js
              JavaScript runtime built on Chrome's V8 JavaScript engine.
              • runtime-environment
              NTP sync check
              Network Time Protocol assures host clocks are in sync with a trusted time source
              • clock
              • host
              • NTP
              • time
              Nunit
              Open-source unit testing framework for the .NET Framework and Mono.
              • ci/cd
              • devops
              OCSP Monitoring
              Monitor your OCSP certificates and validate them against an OCSP Responder
              • security
              OpenMetrics
              Use OpenMetrics to ingest, store and analyze metrics at scale
              • cncf
              • metrics
              soon
              openSUSE
              The openSUSE project is a community program sponsored by SUSE Linux and other companies.
              • cloud
              • infrastructure
              • server-monitoring
              OpenTelemetry
              Dynatrace seamlessly integrates OpenTelemetry data to provide end-to-end distributed tracing, analysis, and actionable answers at scale.
              • agents
              • api
              • libraries
              early
              OpenTracing
              Dynatrace PurePath 4 seamlessly integrates OpenTracing data emitted by auto- and custom-instrumentation of Java source code.
              early
              Opera
              Freeware web browser for Microsoft Windows, Android, iOS, macOS, and Linux operating systems.
              • browser
              • web
              Opsgenie
              Alerting and on-call management platform for operating always-on services.
              • ci/cd
              • devops
              Oracle ASM Disks
              Monitor the utilization of your Oracle ASM (Automatic Storage Management) disks
              • database
              • extension
              • infrastructure
              • oracle
              Oracle Cloud
              Cloud computing serviceproviding servers, storage, network, applications and services.
              • cloud
              • full-stack
              • infrastructure
              • microservices
              • web
              Oracle Database
              Database management system used for running online transaction processing and data warehousing.
              • database
              • oracle
              Oracle GoldenGate Veridata
              Monitor the synchronization of your Oracle GoldenGate Veridata tables
              • extension
              • infrastructure
              • oracle
              Oracle Grid Control
              Gather CPU, memory and filesystem metrics from Oracle GridControl
              • database
              Oracle HTTP Server
              Web server component for Oracle Fusion Middleware.
              • httpserver
              • oracle
              • web
              • web-server
              Oracle Solaris
              Provides proven, enterprise-class security, reliability, and performance for SPARC and x86 systems.
              • cloud
              • infrastructure
              • oracle
              • server-monitoring
              Oracle WebLogic
              Allows building enterprise applications using Java EE, and deploying them.
              • java-monitoring
              • oracle
              PagerDuty
              SaaS incident response platform for IT departments.
              • ci/cd
              • devops
              Palo Alto firewalls
              Gather metrics from your Palo Alto firewalls using SNMP
              • extension
              • infrastructure
              • network
              Perfmon metrics
              Gather any perfmon (performance monitor) metrics from your windows hosts
              • extension
              • monitoring
              • windows
              Perl
              Perl is a family of two high-level, general-purpose, interpreted, dynamic programming languages.
              PHP
              Popular general-purpose scripting language that is especially suited for web development.
              • apm
              • full-stack
              • scripting-language
              PHP-FPM
              FPM (FastCGI Process Manager) is an alternative PHP FastCGI implementation for heavy-loaded sites.
              • php
              PHPUnit
              Unit testing framework for the PHP programming language.
              • ci/cd
              • php
              Pivotal Platform
              Multi-cloud platform for the deployment, management, and continuous delivery of applications. Pivotal is now VMware Tanzu.
              • cloud
              • infrastructure
              • microservices
              Play Framework
              Open-source web application framework which follows the model–view–controller architectural pattern.
              • framework
              • java-monitoring
              PostgreSQL
              Relational database management system emphasizing extensibility and SQL compliance.
              • database
              • full-stack
              • web
              Process connections
              Gather data about the number of connections and their state for any process
              • extension
              • infrastructure
              • monitoring
              Prometheus
              Collect metrics from Prometheus exporters in Kubernetes and analyze them with Dynatrace.
              • Kubernetes
              • metrics
              prototype
              Web JavaScript framework, implemented as a single file of JavaScript code.
              • full-stack
              • prototype
              • web
              Python
              Python is an interpreted, high-level, general-purpose programming language.
              QEMU
              Open-source emulator that performs hardware virtualization.
              • emulator
              • virtualizer
              RabbitMQ
              • message-queue
              RadiantOne Logic VDS
              Monitor your RadiantOne Federated Identity and Directory Service clusters health
              • infrastructure
              • security
              React.js
              JavaScript library for building user interfaces.
              • full-stack
              • spa-monitoring
              • web
              React Native
              Monitor mobile applications built with React Native running on iOS or Android.
              • android
              • cross-platform
              • framework
              • hybrid-app
              • ios
              • mobile
              • mobile-app
              Red Hat
              Provides open source software products to the enterprise community.
              • cloud
              • infrastructure
              • server-monitoring
              • vm
              Scale existing apps across bare-metal, virtual, container, and all types of cloud environments.
              • linux
              • red-hat
              Red Hat OpenShift
              Consistent hybrid cloud foundation for building and scaling containerized applications.
              • container
              • k8s
              • Kubernetes
              • openshift
              • red-hat
              Red Hat OpenStack
              Free open standard cloud computing platform, infrastructure-as-a-service in clouds.
              • openstack
              • red-hat
              Redis
              Open source, in-memory data structure store, used as a database, cache and message broker.
              • database
              restify
              Framework for building semantically correct RESTful web services ready for use at scale.
              • frameworkj
              • nodejs
              • web-serivce
              Riak
              NoSQL data store that offers high availability, operational simplicity, and scalability.
              • database
              Richfaces
              Ajax-enabled component library for JavaServer Faces (open source).
              • full-stack
              • web
              Ruby
              Dynatrace monitors your Ruby applications and services on the process level.
              Runtime vulnerability detection
              Detect vulnerabilities in loaded libraries in real-time, with full context and automated risk assessment.
              • application
              • cve
              • java
              • libraries
              • risk
              • runtime
              • security
              • vulnerabilities
              Salt Stack
              Infrastructure automation software that is used to drive security and reliability.
              • ci/cd
              • devops
              SAP ABAP
              The default programming language for SAP applications.
              • sap
              SAP Cloud Platform
              Interpreted, high-level, general-purpose programming language.
              • cloud
              • infrastructure
              • microservices
              • sap
              SAP Commerce Cloud
              SAP Cloud Platform integrates data and business processes.
              • cloud
              • sap
              SAP HANA Database
              Easily understand the health and performance of your SAP HANA databases!
              • ActiveGate
              • database
              • infrastructure
              • sap
              early
              SAP Hybris
              Cloud based CRM (customer relationship management) Suite.
              • full-stack
              • retail-ecommerce
              • sap
              Scala
              Programming language providing support for functional programming and a strong static type system.
              SCOM
              Retrieve alerts and metrics from SCOM to augment Davis, the Dynatrace AI
              • infrastructure
              • microsoft
              Selenium WebDriver
              Web automation framework that allows you to execute your tests against different browsers.
              • ci/cd
              • web
              Sencha ExtJS
              JavaScript application framework for building interactive cross platform web applications.
              • application
              • framework
              Sencha Touch
              User interface JavaScript library, or web framework, specifically built for the Mobile Web.
              • user-interface
              • web
              ServiceNow
              IT service management for large corporations, including help desk functionality.
              • ci/cd
              • devops
              servicetrace
              ServicetraceServicetrace
              Monitor the performance of any application from an end user‘s perspective.
              • end-user-monitoring
              Siebel
              Gathers metrics from the Siebel SARM logs to provide aggregated task information
                Slack
                Where the people you need, the information you share, and the tools you use come together.
                • ci/cd
                • devops
                SNMP (Generic)
                Monitoring devices using SNMP feeds Dynatrace with metrics to allow alerting and Davis problem detection
                • network
                soon
                SNMP Traps
                Receive SNMP traps and create Dynatrace Problems from them.
                • extension
                • infrastructure
                • network
                Snyk
                Snyk is integrated with Dynatrace to provide precise vulnerability matches, actionable descriptions, and detailed remediation guidance.
                • remediation
                • security
                • snyk
                • vulnerabilities
                Solarwinds
                Monitor events and node performance
                • extension
                • infrastructure
                • monitoring
                • plugin
                Spring
                Application framework and inversion of control container for the Java platform.
                • framework
                • java
                SQL Server Always On
                Gather metrics about your Always On availability groups, availability databases and replicas
                • database
                • extension
                • microsoft
                StatsD
                The easiest way to get you custom application metrics into Dynatrace.
                • agents
                • metrics
                • plugin
                Subversion
                Software versioning and revision control system distributed under the Apache License.
                • devops
                SUSE Linux
                Distributed system and application software from other open source projects.
                • cloud
                • infrastructure
                • linux
                • server-monitoring
                Suse Pacemaker
                Monitor the health of your Suse Pacemaker clusters
                • extension
                • linux
                Sybase ASE
                Gathers performance and utilization metrics from Sybase ASE
                  Sybase IQ
                  Gathers performance and utilization metrics from Sybase IQ
                  • database
                  Symfony
                  PHP web application framework and a set of reusable PHP components/libraries.
                  • php-monitoring
                  • web
                  Synthetic monitor database queries
                  Make sure that your databases always are responding timely by using a synthetic monitor
                  • database
                  • synthetic
                  Synthetic monitor DNS
                  Synthetically monitor your DNS servers to be proactively alerted when they go down.
                  • ActiveGate
                  • DNS
                  • extension
                  • synthetic
                  Synthetic monitor Ping
                  Synthetically monitor that your devices are available using ping. This allows you to be proactively alerted when they are unavailable.
                  • ActiveGate
                  • extension
                  • network
                  • synthetic
                  Synthetic monitor Ports
                  Synthetically monitor that ports on your servers are available. This allows you to be proactively alerted when they are unavailable.
                  • ActiveGate
                  • extension
                  • synthetic
                  Synthetic SFTP monitor
                  Monitor SFTP availability and performance
                  • extension
                  • monitoring
                  • synthetic
                  TeamCity
                  Powerful continuous integration out of the box.
                  • ci/cd
                  • devops
