Extend the platform,
empower your team.
Level up your network infrastructure observability by monitoring your network equipment within the Dynatrace platform.
ExtensionThis extension leverages the SNMP protocol to provide a complete solution to monitor network infrastructure. The complete configuration is provided out-of-the-box.
This is intended for users, who:
This enables you to:
Compatibility Requirements
This extension is built on top of the new Extension 2.0 Framework.
The extension package contains:
More information can be found in the Product News Blog:
Simply activate the extension in your environment using in-product Hub, provide device configuration and you’re all set up.
More can be found in the SNMP Extension Documentation
Metric name | Metric key | Description | Unit |
Time since the last re-start | com.dynatrace.extension.snmp-generic-device.sys.uptime | The time (in hundredths of a second) since the network management portion of the system was last re-initialized | Unspecified |
Messages delivered | com.dynatrace.extension.snmp-generic-device.snmp.in.pkts.count | Total number of messages delivered from the transport service | Count |
Messages passed | com.dynatrace.extension.snmp-generic-device.snmp.out.pkts.count | Total number of messages passed to the transport service | Count |
Silently dropped PDUs | com.dynatrace.extension.snmp-generic-device.snmp.silentdrops.count | Number of silently dropped PDUs due to the large reply size | Count |
Proxy dropped PDUs | com.dynatrace.extension.snmp-generic-device.drops.proxy.count | Number of silently dropped PDUs due to the other than a time-out | Count |
Unsupported SNMP version messages | com.dynatrace.extension.snmp-generic-device.in.bad.versions.count | Total number of messages delivered with an unsupported SNMP version | Count |
Messages with bad community names | com.dynatrace.extension.snmp-generic-device.in.bad.community.names.count | Number of messages with an unknown SNMP community | Count |
Messages not allowed in community | com.dynatrace.extension.snmp-generic-device.in.bad.community.uses.count | Number of messages not allowed for the used SNMP community | Count |
'noSuchName' errors | com.dynatrace.extension.snmp-generic-device.in.nosuchnames.count | Number of PDUs delivered PDUs with 'noSuchName' error | Count |
'badValue' errors | com.dynatrace.extension.snmp-generic-device.in.bad.values.count | Number of PDUs delivered with 'badValue' error | Count |
Traps processed | com.dynatrace.extension.snmp-generic-device.snmp.in.traps.count | Total number of SNMP Trap PDUs accepted and processed | Count |
Traps generated | com.dynatrace.extension.snmp-generic-device.snmp.out.traps.count | Total number of SNMP Trap PDUs generated | Count |
TCP active opens | com.dynatrace.extension.snmp-generic-device.tcp.activeopens.count | Number of transitions of TCP connections from CLOSED to SYN-SENT | Count |
TCP passive opens | com.dynatrace.extension.snmp-generic-device.tcp.passiveopens.count | Number of transitions of TCP connections from CLOSED to SYN-RCVD | Count |
TCP failed attempts | com.dynatrace.extension.snmp-generic-device.tcp.attemptfails.count | Number of transitions of TCP connections from SYN-SENT/SYN-RCVD to CLOSED and from SYN-RCVD to LISTEN | Count |
TCP resets | com.dynatrace.extension.snmp-generic-device.tcp.estab.resets.count | Number of transitions of TCP connections from ESTABLISHED/CLOSE-WAIT to CLOSED | Count |
TCP connections | com.dynatrace.extension.snmp-generic-device.tcp.curr.estab | Number of TCP connections in the ESTABLISHED/CLOSE-WAIT state | Count |
TCP segments received | com.dynatrace.extension.snmp-generic-device.tcp.hc.in.segs.count | Total number of segments received (including errors) | Count |
TCP segments sent | com.dynatrace.extension.snmp-generic-device.tcp.hc.out.segs.count | Total number of segments sent (excluding retransmissions) | Count |
TCP segments retransmitted | com.dynatrace.extension.snmp-generic-device.tcp.retrans.segs.count | Total number of segments retransmitted | Count |
TCP segment errors | com.dynatrace.extension.snmp-generic-device.tcp.in.errs.count | Total number of segments received in error | Count |
TCP segment resets | com.dynatrace.extension.snmp-generic-device.tcp.out.rsts.count | Number of TCP segments sent containing the RST flag | Count |
UDP datagrams delivered | com.dynatrace.extension.snmp-generic-device.udp.hc.in.datagrams.count | Total number of UDP datagrams delivered | Count |
UDP datagrams received without port | com.dynatrace.extension.snmp-generic-device.udp.noports.count | Number of received UDP datagrams (no application at the destination port) | Count |
UDP datagram errors | com.dynatrace.extension.snmp-generic-device.udp.in.errors.count | Number of received and not delivered UDP datagrams (other than no application at the destination port) | Count |
UDP datagrams sent | com.dynatrace.extension.snmp-generic-device.udp.hc.out.datagrams.count | Total number of UDP datagrams sent | Count |
Octets received | com.dynatrace.extension.snmp-generic-device.if.in.octets.count | The total number of octets received on the interface including framing characters | Count |
Octets transmitted | com.dynatrace.extension.snmp-generic-device.if.out.octets.count | The total number of octets transmitted out of the interface including framing characters | Count |
Octets received (high capacity) | com.dynatrace.extension.snmp-generic-device.if.hc.in.octets.count | The total number of octets received on the interface including framing characters. This metric uses 64 bit counter and should be used for highspeed devices. | Count |
Octets transmitted (high capacity) | com.dynatrace.extension.snmp-generic-device.if.hc.out.octets.count | The total number of octets transmitted out of the interface including framing characters. This metric uses 64 bit counter and should be used for highspeed devices. | Count |
Last interface status change | com.dynatrace.extension.snmp-generic-device.if.lastchange | Value of 'sysUpTime' when the interface entered its current state | Count |
Interface speed | com.dynatrace.extension.snmp-generic-device.if.highspeed | Speed of the network interface in MegaBits per second. | MegaBitPerSecond |
Inbound errors | com.dynatrace.extension.snmp-generic-device.if.in.errors.count | Number of inbound packets/transmission units with errors | Count |
Inbound discards | com.dynatrace.extension.snmp-generic-device.if.in.discards.count | Number of inbound packets discarded | Count |
Outbound errors | com.dynatrace.extension.snmp-generic-device.if.out.errors.count | Number of outbound packets/transmission units with errors | Count |
Outbound discards | com.dynatrace.extension.snmp-generic-device.if.out.discards.count | Number of outbound packets discarded | Count |
Device screen - added filtering for list of network interfaces.
Interval for sending the data is changed from 5 minutes to 1 minute.
Dashboard improvements - tile with errors contains a links to device screens.
No release notes
