Extend the platform,
empower your team.
Monitor health and performance of Windows Hosts without installing an agent.
ExtensionThis extension leverages the WMI protocol to collect data from Windows hosts, without the need for any agent. This enables agent-less, remote monitoring while providing the same transparency and visibility of Windows hosts as otherwise only offered with a OneAgent installation.
The Remote Windows Host Extension is built on top of the new Extension Framework.
Please find detailed steps on how to get started in the Dynatrace Support Center:
Metric name | Metric key | Description | Unit |
Used processor time | com.dynatrace.extension.host-observability.host.cpu.time.processor | Percent of used processor time | Percent |
Idle processor time | com.dynatrace.extension.host-observability.host.cpu.time.idle | Percent of idle processor time | Percent |
User processor time | com.dynatrace.extension.host-observability.host.cpu.time.user | Percent of user processor time | Percent |
Available memory size | com.dynatrace.extension.host-observability.host.memory.bytes.available | - | Byte |
Commited memory size | com.dynatrace.extension.host-observability.host.memory.bytes.commited | - | Byte |
Used commited memory | com.dynatrace.extension.host-observability.host.memory.bytes.commited.inuse | Percentage of using commited memory | Percent |
Processes | com.dynatrace.extension.host-observability.host.processes | Number of processes | Count |
Threads | com.dynatrace.extension.host-observability.host.threads | Number of threads | Count |
Disk usage/s | com.dynatrace.extension.host-observability.disk.bytes.persec | Disk bytes used per second | BytePerSecond |
Disk read bytes/s | com.dynatrace.extension.host-observability.disk.bytes.read.persec | Disk bytes read per second | BytePerSecond |
Disk reads/s | com.dynatrace.extension.host-observability.disk.read.persec | Number of disk reads per second | PerSecond |
Disk write bytes/s | com.dynatrace.extension.host-observability.disk.bytes.write.persec | Disk bytes write per second | BytePerSecond |
Disk writes/s | com.dynatrace.extension.host-observability.disk.write.persec | Number of disk writes per second | PerSecond |
Disk transfers/s | com.dynatrace.extension.host-observability.disk.transfer.persec | Number of disk transfers per second | PerSecond |
Disk time | com.dynatrace.extension.host-observability.disk.usage.percent | Percent of disk time | Percent |
Disk read time | com.dynatrace.extension.host-observability.disk.usage.read.percent | Percent of disk read time | Percent |
Disk write time | com.dynatrace.extension.host-observability.disk.usage.write.percent | Percent of disk write time | Percent |
Disk idle time | com.dynatrace.extension.host-observability.disk.usage.idle.percent | Percent of disk idle time | Percent |
Disk read bytes | com.dynatrace.extension.host-observability.disk.read.avg.bytes | Average bytes per disk read | Byte |
Disk write bytes | com.dynatrace.extension.host-observability.disk.write.avg.bytes | Average bytes per disk write | Byte |
Disk transfer bytes | com.dynatrace.extension.host-observability.disk.transfer.avg.bytes | Average bytes per disk transfer | Byte |
Disk read queue | com.dynatrace.extension.host-observability.disk.queue.avg.read | Average length of disk read queue | Count |
Disk write queue | com.dynatrace.extension.host-observability.disk.queue.avg.write | Average length of disk write queue | Count |
Disk available | com.dynatrace.extension.host-observability.disk.logical.free.megabytes | Disk available | MegaByte |
Disk available % | com.dynatrace.extension.host-observability.disk.logical.free.percent | Disk available % | Percent |
UDP datagrams/s | com.dynatrace.extension.host-observability.network.udp.datagrams.persec | Number of UDP datagrams per second | PerSecond |
UDP datagrams received/s | com.dynatrace.extension.host-observability.network.udp.datagrams.received.persec | Number of received UDP datagrams per second | PerSecond |
UDP Received invalid datagrams | com.dynatrace.extension.host-observability.network.udp.datagrams.received.errors.count | Number of received invalid UDP datagrams | Count |
UDP datagrams sent/s | com.dynatrace.extension.host-observability.network.udp.datagrams.sent.persec | Number of sent UDP datagrams per second | PerSecond |
Traffic bytes/s | com.dynatrace.extension.host-observability.network.bytes.persec | Network traffic bytes per second | BytePerSecond |
Traffic received bytes/s | com.dynatrace.extension.host-observability.network.bytes.received.persec | Network traffic received bytes per second | BytePerSecond |
Traffic sent bytes/s | com.dynatrace.extension.host-observability.network.bytes.sent.persec | Network traffic sent bytes per second | BytePerSecond |
Traffic packets/s | com.dynatrace.extension.host-observability.network.packets.persec | Network traffic packets per second | PerSecond |
Traffic packets received/s | com.dynatrace.extension.host-observability.network.packets.received.persec | Network traffic received packets per second | PerSecond |
Traffic packets discarded/s | com.dynatrace.extension.host-observability.network.packets.received.discarded.persec | Network traffic discarded received packets per second | PerSecond |
Traffic packets error/s | com.dynatrace.extension.host-observability.network.packets.received.errors.persec | Network traffic error received packets per second | PerSecond |
Traffic packets unknown/s | com.dynatrace.extension.host-observability.network.packets.received.unknown.persec | Network traffic unknown received packets per second | PerSecond |
Traffic packets sent/s | com.dynatrace.extension.host-observability.network.packets.sent.persec | - | PerSecond |
Non-paged memory size | com.dynatrace.extension.host-observability.host.memory.pool.nonpaged | - | Byte |
Paged memory size | com.dynatrace.extension.host-observability.host.memory.pool.paged | - | Byte |
Page faults per second | com.dynatrace.extension.host-observability.host.memory.pagefaults.persec | Number of page faults per second | PerSecond |
Allocated for swap memory | com.dynatrace.extension.host-observability.host.swap.allocated | Allocated disk space for swap memory | MegaByte |
- | com.dynatrace.extension.host-observability.host.swap.current | - | - |
Swap memory used | com.dynatrace.extension.host-observability.host.swap.peak | Disk space used by swap memory | MegaByte |
Total swap memory | com.dynatrace.extension.host-observability.host.swap.total | Total kilobytes that can be stored in the operating system paging files | KiloByte |
Available swap memory | com.dynatrace.extension.host-observability.host.swap.available | Number, in kilobytes, that can be mapped into the paging files without causing any other pages to be swapped out | KiloByte |
Active TCP connections | com.dynatrace.extension.host-observability.network.tcp.connections.active.count | Number of active TCP connections | Count |
Established TCP connections | com.dynatrace.extension.host-observability.network.tcp.connections.established.count | Number of established TCP connections | Count |
Failed TCP connections | com.dynatrace.extension.host-observability.network.tcp.connections.failures.count | Number of failed TCP connections | Count |
Passive TCP connections | com.dynatrace.extension.host-observability.network.tcp.connections.passive.count | Number of passive TCP connections | Count |
TCP connection resets | com.dynatrace.extension.host-observability.network.tcp.connections.resets.count | Number of TCP connection resets | Count |
TCP segments/s | com.dynatrace.extension.host-observability.network.tcp.segments.persec | Number of TCP segments per second | PerSecond |
TCP segments received/s | com.dynatrace.extension.host-observability.network.tcp.segments.received.persec | Number of received TCP segments per second | PerSecond |
TCP segments sent/s | com.dynatrace.extension.host-observability.network.tcp.segments.sent.persec | Number of sent TCP segments per second | PerSecond |
TCP segments transmitted/s | com.dynatrace.extension.host-observability.network.tcp.segments.transmitted.persec | Number of transmitted TCP segments per second | PerSecond |
- | com.dynatrace.extension.host-observability.disk.secper.read.count | - | - |
- | com.dynatrace.extension.host-observability.disk.secper.read_base.count | - | - |
- | com.dynatrace.extension.host-observability.disk.secper.transfer.count | - | - |
- | com.dynatrace.extension.host-observability.disk.secper.transfer_base.count | - | - |
- | com.dynatrace.extension.host-observability.disk.secper.write.count | - | - |
- | com.dynatrace.extension.host-observability.disk.secper.write_base.count | - | - |
- | com.dynatrace.extension.host-observability.disk.frequency_perftime | - | - |
Free disk memory
-> Disk available
Free disk memory %
-> Disk available %
🐛Bug Fixes
✨ Improvements
Version 1.2.1 of this extension raises the minDynatraceVersion
to 1.233
Updated icons Updated UA screens with breadcrumbs
No release notes
