End-to-end trace your applications when the Reactor Core publishers Mono and Flux are used.
Dynatrace automatically detects all applications and microservices deployed in your application server and provides automatic end-to-end tracing when the Reactor Core publishers Mono and Flux are used. Deep code-level insights combined with market-leading profiling capabilities like method hotspots, error/exception analysis, memory profiling, and thread analysis will help you leverage the robustness of your production environment.
If your application is running directly on a virtual machine, install OneAgent on that virtual machine to get started.
If your application is running as a workload in Kubernetes, set up Dynatrace on Kubernetes.
If your application is running as a workload in OpenShift, set up Dynatrace on OpenShift.
Activate the following OneAgent feature to get full tracing insight:
Activate log monitoring to get full log insight.
