Once PowerConnect is set up and feeding Dynatrace, its data will land in the buckets that the app set up for you. OpenPipeline rules, set up by the app, assure that.
Dashboards provided by this app will be populated with data from your SAP systems. You can copy the dashboards and modify them to your needs, or create your own. PowerConnect data, which characterizes your SAP systems operations, is available for you as metrics, logs, traces and business events, like any other observability signals that Dynatrace maintains.
Services app can be used to analyze traces collected from your SAP systems by the PowerConnect agent. Mind that SAP traces may get long, as SAP operations may be comprised of dozens or hundreds of steps (i.e. spans) that together orchestrate SAP transactions or tasks.
Business Flow app lets you organize events monitored by PowerConnect on your SAP systems into the flows that reflect business processes implemented on your system, including specifics of your SAP implementation. Then observe success rate and diagnose anomalies and failures automatically, with troubleshooting data linking down to metrics, logs and traces collected as your business flow has been executing.
Note on license consumption
This application by itself does not incur any consumption, as it is responsible for system set up and configuration for seamless PowerConnect experience. Subscription consumption level incurred by PowerConnect data ingest heavily depends on the monitored SAP systems size and activity. You will store monitored SAP system telemetry data as logs, metric, biz events and traces in Dynatrace, for the time period you define, typically between 90 and 360+ days.
Logs will be translated to essential metrics, for easy reporting purposes, but more advanced reporting may still require DQL queries.
Past experience tells us that you can expect:
Between 5 GB and 500 GB logs ingested by PowerConnect, per day
Check your rating card for costs that such log ingestion will incur on your tenant. See documentation for examples of the consumption calculation approaches and online reporting.
More on PowerConnect
See PowerConnect Compatibility Matrix for details of the SAP systems supported.
Consult PowerConnect documentation for detailed list of metric extractors applied by PowerConnect on SAP systems.
For complete details about the value of monitoring SAP with PowerConnect for Dynatrace, see this blog post and PowerConnect pages.
