OutSystems is a leading low-code application platform. With this integration, their Cloud API data becomes available inside Dynatrace.
OutSystems‘ cloud offering does not allow the installation of Dynatrace's OneAgent. This integration relies on OutSystems’ Performance API, ingesting the available data into Dynatrace. The data can be aggregated inside Dynatrace, but remains available with a high level of detail. The integration of data is done directly into the Dynatrace environment, so there is no need for an ActiveGate. Metrics and information ingested into Dynatrace may be used as any other metric for example to setup dashboards or define problems.
