Software Intelligence Hub
A curated catalog of supported technologies, integrations and extensions provided by Dynatrace and trusted partners.
OneAgent
All the operational and business performance metrics you need.
Active Directory Services
Monitor health and improve performance of Microsoft Active Directory services
ActiveGate
Route traffic, monitor cloud environments, monitor remote technologies with extensions and run synthetic monitors.
ActiveMQ
Automatic and intelligent observability for ActiveMQ with end-to-end traces of connected producers and consumers.
ActiveMQ Artemis
Automatic and intelligent observability for ActiveMQ Artemis with end-to-end traces of connected producers and consumers.
Adobe Analytics
Get real-time answers for business anomalies with shared business context from Adobe Analytics
Adobe PhoneGap
Monitor hybrid mobile apps built with Adobe PhoneGap running on iOS or Android
ADO.NET
Solve ADO.NET performance problems at code level.
aDSS avodaq Data Snapshot Service
Easily export and retain real user (including session replay) and performance data to address business and technical reporting requirements.
Advanced SSL Certificate Check for Dynatrace
Perform extended SSL certificate checks and integrate seamlessly with your existing synthetic monitors.
Akamas
Akamas AI enables enterprises and online businesses to maximize service quality, resilience and cost savings.
Akka
Automatically and intelligently monitor, analyze, and optimize your applications developed with Akka.
Amazon API Gateway
Service for developers to create, publish, maintain, monitor, and secure APIs.
Amazon AppStream 2.0
Fully managed application streaming service that provides users with instant access to their desktop applications from anywhere.
Amazon Athena
Interactive query service that makes it easy to analyze data directly in Amazon S3 using standard SQL.
Amazon Aurora
Relational database service developed and offered by Amazon Web Services.
Amazon CloudFront
Content delivery network offered by Amazon Web Services.
Amazon CloudSearch
Set up, manage, and scale a search solution for your website or application using CloudSearch.
Amazon Cloudwatch
Monitoring service for AWS cloud resources and the applications you run on AWS.
Amazon CloudWatch Logs
Monitor, store, and access your log files from instances, AWS CloudTrail, Route 53, and other sources.
Amazon Cognito
Add user sign-up, sign-in, and access control to your web and mobile apps quickly and easily.
Amazon Connect
Easy to use omnichannel cloud contact center that helps you to provide superior customer service at a lower cost.
Amazon Corretto
Automatically and intelligently monitor, analyze, and optimize the performance of your virtual machine.
Amazon DocumentDB
Amazon DocumentDB (with MongoDB compatibility) is a fast, reliable, and fully managed database service.
Amazon DynamoDB
Fully managed NoSQL database service that supports key-value and document data structures.
Amazon DynamoDB Accelerator (DAX)
Fully managed, highly available, in-memory cache for your Amazon DynamoDB.
Amazon EC2
Web service that provides secure, resizable compute capacity in the cloud.
Amazon EC2 Auto Scaling
Amazon EC2 Auto Scaling helps you ensure that you have the correct number of Amazon EC2 instances available.
Amazon EC2 Spot Fleet
Spot Instances and On-Demand Instances to meet the target capacity that you specified.
Amazon ElastiCache
Fully managed in-memory data store and cache service by Amazon Web Services.
Amazon Elastic Block Store (EBS)
Raw block-level storage that can be attached to Amazon EC2 instances.
Amazon Elastic Container Service (ECS)
Fully managed container orchestration service.
Amazon Elastic File Service (EFS)
Cloud storage service provided by Amazon Web Services.
Amazon Elastic Inference
Accelerate deep learning inference workloads by attaching to your Amazon EC2 CPU instances.
Amazon Elastic Kubernetes Service (EKS)
Harness automation and AI to simplify Kubernetes observability at scale.
Amazon Elasticsearch Service
Fully managed service to deploy, secure, and run Elasticsearch cost effectively at scale, without the operational overhead.
Amazon Elastic Transcoder
Convert and transcode media files stored in Amazon S3.
Amazon EMR
Cloud big data platform for processing vast amounts of data using open source tools.
Amazon EventBridge
Serverless event bus to connect applications together using data from your own applications, integrated SaaS applications, and AWS services.
Amazon FSx for Lustre
Makes it easy and cost-effective to launch and run the popular, high-performance Lustre file system.
Amazon FSx for Windows File Server
Provides a managed Microsoft Windows file servers, backed by a native Windows file system.
Amazon GameLift
Enables developers to deploy, operate, and scale dedicated, low-cost servers in the cloud for session-based, multiplayer games.
Amazon Inspector
Tests the network accessibility of your EC2 instances and the security state of your applications that run on those instances.
Amazon Keyspaces for Apache Cassandra
Scalable, highly available, and managed Apache Cassandra–compatible database service.
Amazon Kinesis Data Analytics
Transform and analyze streaming data in real time with open source framework and engine for processing data streams (Apache Flink).
Amazon Kinesis Data Firehose
Fully managed service for delivering real-time streaming data.
Amazon Kinesis Data Streams
Collect log and event data from sources such as servers, desktops, and mobile devices.
Amazon Kinesis Video Streams
Provides you SDKs to install on your devices to make it easy to stream media.
Amazon Lex
Service for building conversational interfaces for applications using voice and text.
Amazon Linux 2
Automatic insights of your Amazon Linux 2 CPU, memory, and network health metrics all the way down to the process level.
Amazon Managed Service for Prometheus
Ingest metrics from Amazon Managed Prometheus to Dynatrace.
Amazon MSK
Fully managed service that enables you to build and run applications that use Apache Kafka to process streaming data.
Amazon Neptune
Fast, reliable, fully managed graph database built for highly connected datasets.
Amazon Polly
Cloud service that converts text into lifelike speech.
Amazon Quantum Ledger Database (QLDB)
Ledger by a central trusted authority that provides an immutable, and cryptographically verifiable transaction log.
Amazon Redshift
Data warehouse product which forms part of the larger cloud-computing platform AWS.
Amazon Rekognition
Amazon Rekognition makes it easy to add image and video analysis to your applications.
Amazon Relational Database Service (RDS)
Cloud web service designed to simplify the setup, operation, and scaling of a relational database.
Amazon Route 53
Effectively connects user requests to infrastructure running in AWS.
Amazon S3
Provides object storage through a web service interface.
Amazon SageMaker
Build, train, and deploy machine learning (ML) models quickly.
Amazon Simple Email Service (SES)
Cloud-based service that helps developers send marketing, notification, and transactional emails.
Amazon Simple Notification Service (SNS)
Provides a simple web services interface that can be used to create topics you want to notify apps.
Amazon Simple Queue Service (SQS)
Programmatic sending of messages via web service applications.
Amazon Simple Workflow Service (SWF)
Makes it easy to build applications that coordinate work across distributed components.
Amazon Textract
Makes it easy to add document text detection and analysis to your applications.
Amazon Transfer Family
Provides fully managed support for file transfers directly into and out of Amazon S3 using SFTP, FTPS, and FTP
Amazon Translate
Text translation service using machine learning to provide high-quality translation on demand.
Amazon VPC (NAT Gateway)
Connect to the Internet from instances within a private subnet in an AWS Virtual Private Cloud.
Amazon WorkMail
Secure, managed business email and calendaring service with support for existing desktop and mobile email clients.
Amazon WorkSpaces
Enables you to provision virtual, cloud-based Microsoft Windows or Amazon Linux desktops, known as WorkSpaces.
Amazon MQ
Managed message broker service for Apache ActiveMQ that makes it easy to migrate to a message broker in the cloud.
aMC Synthetic App
Always stay up to date with your Synthetic Monitors from Dynatrace SaaS/Managed and receive push notifications for alerts
AMP
Accelerated Mobile Pages performance monitoring to ensure perfect user experience.
Android
Monitor mobile applications that are running on the popular Android operating system.
Android Webkit
Provides tools for browsing the web.
Angular
Platform for building mobile and desktop web applications.
AngularJS
JavaScript-based open-source front-end web framework mainly maintained by Google.
Ansible
The simplest way to automate apps and IT infrastructure.
Ansible Tower
Way to automate apps and IT infrastructure.
Apache Axis2
Core engine for Web services.
Apache Camel
Extend observability with PurePath® distributed traces to seamlessly integrate OpenTracing data emitted by the Apache Camel framework
Apache Cassandra
Automatically and intelligently observe, analyze and optimize how your the usage, health and performance of your database.
Apache Cassandra (Remote)
Remotely gain insights into your Cassandra cluster health and performance.
Apache Cordova
Monitor hybrid mobile apps built with Cordova running on iOS or Android
Apache CouchDB
Apache CXF
Open-source, fully featured Web services framework.
Apache HTTP Server
Develop and maintain an open-source HTTP server.
Apache JMeter
Build management and continuous integration server from JetBrains.
Apache Kafka
Automatic and intelligent observability for Apache Kafka with end-to-end traces of connected producers and consumers.
Apache OpenEJB
Automatically and intelligently monitor, analyze and optimize your applications based on Apache OpenEJB
Apache Solr
Open-source enterprise-search platform, written in Java, from the Apache Lucene project.
Apache Spark
Distributed general-purpose cluster-computing framework for programming entire clusters.
Apache Storm
ActiveGate extension for monitoring the free and open source distributed realtime computation system Apache Storm.
Apache Tomcat
Automatically and intelligently monitor, analyze, and optimize your application server and all applications deployed anywhere in your stack.
Apache TomEE
Apigee Edge
Design, secure, and analyze APIs across the entire API lifecycle.
Apple Safari
Graphical web browser developed by Apple, based on the WebKit engine.
ASP.NET / ASP.NET Core
Automatically and intelligently monitor, analyze and optimize your ASP.NET / ASP.NET Core apps.
ASP.NET Owin/Katana
Automatically and intelligently monitor, analyze, and optimize your applications developed with ASP.NET Owin/Katana.
Atlassian Bamboo
Continuous integration and continuous deployment server developed by Atlassian.
Atlassian JIRA
Issue tracking product that allows bug tracking and agile project management.
AWS
Reliable, scalable, and inexpensive cloud computing services with pay-as-you-go pricing approach.
AWS AppSync
Enterprise-level, fully managed GraphQL service with real-time data synchronization and offline programming features.
AWS Billing and Cost Management
The service that you use to pay your AWS bill, monitor usage, and analyze and control costs.
AWS Chatbot
Enables DevOps to use Amazon Chime and Slack chat rooms to monitor and respond to events.
AWS CloudHSM
Hardware security modules (HSM) in the AWS Cloud.
AWS CodeDeploy
Fully managed service that automates software deployments to a variety of compute services.
AWS CodePipeline
Continuous delivery service automating release pipelines for application and infrastructure updates.
AWS Database Migration Service
Makes it easy to migrate relational databases, and other types of data stores.
AWS DataSync
Transfer service designed to simplify and automate copying large amounts of data to and from AWS services.
AWS Direct Connect
Links your internal network to an AWS Direct Connect location over a standard Ethernet fiber-optic cable.
AWS Elastic Beanstalk
Quickly deploy and manage applications in the AWS Cloud without having to learn about the infrastructure beneath.
AWS Elastic Load Balancing
Automatically distributes incoming application traffic across multiple targets.
AWS Elemental MediaConnect
Service that makes it easy for broadcasters and other premium video providers to reliably ingest live video into the AWS Cloud.
AWS Elemental MediaConvert
File-based video processing service that provides scalable video processing for content owners and distributors.
AWS Elemental MediaPackage
Just-in-time video packaging and origination service that runs in the AWS Cloud.
AWS Elemental MediaTailor
Scalable ad insertion service that runs in the AWS Cloud.
AWS Fargate
Serverless compute for containers. Dynatrace provides automatic monitoring of AWS Fargate containers at scale.
AWS Glue
Fully managed extract, transform, and load (ETL) service.
AWS IoT
Run local compute, messaging, data caching, and machine learning inference capabilities.
AWS IoT Analytics
Automates the steps required to analyze data from IoT devices.
AWS IoT Things Graph
Orchestration service that simplifies development of IoT applications.
AWS Lambda
Automatic and intelligent end-to-end observability for AWS Lambda traces.
AWS OpsWorks
Configuration management service that helps you configure and operate applications by using Puppet or Chef.
AWS Outposts
Fully managed service that extends AWS infrastructure, AWS services, APIs, and much more.
AWS PrivateLink
Provides private connectivity between VPCs, AWS services, and on-premises applications.
AWS RoboMaker
Service that makes it easy to create robotics applications at scale.
AWS Service Catalog
Enables organizations to create and manage catalogs of IT services that are approved for use on AWS.
AWS Site-to-Site VPN
Allows connecting and routing from your VPC to your remote network.
AWS Step Functions
Enables you to coordinate the components of distributed applications and microservices using visual workflows.
AWS Storage Gateway
Connects an on-premises software appliance with cloud-based storage to provide data security.
AWS Systems Manager
View and control your infrastructure on AWS using Systems Manager.
AWS Transit Gateway
Network transit hub interconnecting virtual private clouds (VPC) and on-premises networks.
AWS Trusted Advisor
Identifies ways to reduce cost, increase performance, and improve security for your AWS account.
AWS Web Application Firewall (WAF)
Web application firewall that lets you monitor the HTTP(S) requests.
Azul Platform Core (Zulu)
Azul Platform Prime (Zing)
Azure Analysis Services
Fully managed platform as a service (PaaS) that provides enterprise-grade data models in the cloud.
Azure Anomaly Detector
Detects anomalies in time series data with numerical values that are uniformly spaced in time.
Azure API Management
Create consistent and modern API gateways for existing back-end services.
Azure App Configuration
Service to provide centrally managed application settings and feature flags.
Azure Application Gateway
Web traffic load balancer that enables you to manage traffic to your web applications.
Azure Application Insights
An extensible Application Performance Management (APM) service for developers and DevOps.
Azure App Service
Cloud computing based platform for hosting websites, created and operated by Microsoft.
Azure Automation account
Allows you to automate your Azure management tasks and to orchestrate actions across external systems from right within Azure.
Azure Batch
Get complete picture of jobs, tasks and node tracking, in each state, for operational efficiency.
Azure Bing Autosuggest
Helps users complete queries faster by adding intelligent type-ahead capabilities to your app or website.
Azure Bing Custom Search
An easy-to-use, ad-free, commercial-grade search tool that lets you deliver the results you want.
Azure Bing Entity Search
Bring rich context data to your apps through entity information for a more engaging experience.
Azure Bing Search
Build apps and services that find webpages, images, news, locations, and more.
Azure Bing Spell Check
Correct spelling and word breaks errors, recognize slang, names, homonyms, brands and more.
Azure Blob Storage
Handles stored objects, with millions of requests per second, for customers around the world.
Azure Blockchain
Fully managed ledger service that enables users the ability to grow and operate blockchain networks at scale in Azure.
Azure Cache for Redis
Industry-standard SSL to secure your data in transit and Azure Storage disk encryption at rest.
Azure CDN profiles
Collections of CDN endpoints and each CDN profile contains one or more CDN endpoints.
Azure Cloud Services (Classic)
Deploy web apps (web roles) and background services (worker roles) onto Azure virtual machines.
Azure CloudSimple Virtual Machines
Manage VMware virtual machines (VMs) from the Azure portal.
Azure Cognitive Services
Bring AI within reach of every developer—without requiring machine-learning expertise.
Azure Computer Vision
AI service to boost content discoverability, automate text extraction, analyze video in real time, and more.
Azure Connections
This tool is designed to meet and accomplish your hybrid identity goals.
Azure Container Instance
Deploy and manage serverless containers on the Microsoft Azure cloud, without having to manage any underlying infrastructure.
Azure Container Registries
Managed, private Docker registry service based on the open-source Docker Registry 2.0.
Azure Content Moderator
AI service for content moderation and human review tool for images, text, and videos.
Azure Cosmos DB
Globally-distributed, multi-model database service "for managing data at planet-scale".
Azure Custom Vision Prediction
Customize computer vision for specific domain. No machine learning expertise is required.
Azure Custom Vision Training
Azure Database for Maria DB
Full coverage of performance for critical workloads with AI-problem detection, availability, and more.
Azure Database for MySQL
Full observability of MYSQL servers and database instances to ensure database health and performance.
Azure Database for PostgreSQL
Full insight into database performance for critical workloads with AI-problem detection and more.
Azure Data Box Edge
Rebranded as Azure Stack Edge. ... Azure Stack Edge is a Hardware-as-a-service solution.
Azure Data Catalog
Fully managed cloud service that lets users discover the data sources they need and understand the data sources they find.
Azure Data Explorer Clusters
Engine and data management clusters which uses several Azure resources such as Azure Linux VM's and Storage.
Azure Data Factory
Cloud-based ETL and data integration service for creating data-driven workflows for moving and transforming data at scale.
Azure Data Lake Analytics
Distributed, cloud-based data processing architecture offered by Microsoft in the Azure cloud.
Azure Data Lake Storage
Fully-managed, elastic, scalable, and secure file system that supports HDFS semantics and works with the Hadoop ecosystem.
Azure Data Share
Platform as a Service tool that allows you to share data sets using Azure Services.
Azure Device Provisioning Service
Helper service for IoT Hub that enables just-in-time provisioning to the right IoT hub without human intervention.
Azure DevOps Keptn Extension
Integrate your Azure DevOps pipelines with Keptn to enable features like quality gates
Azure Disk Storage
Cloud storage offering providing multiple solutions for organizations.
Azure DNS Zones
Data resource that contains the DNS records for a domain name.
Azure Event Grid Domains
Simplifies the development of event-based applications and simplifies the creation of serverless workflows.
Azure Event Grid Subscriptions
Support for Azure Event Grid Subscriptions.
Azure Event Grid Topics
Topic based events for serverless and event based workflows.
Azure Event Hub Clusters
Big data streaming platform and event ingestion service. It can receive and process millions of events per second.
Azure Event Hubs
Fully managed data ingestion service that's simple, and scalable.
Azure ExpressRoute
Extend your on-premise networks into the Microsoft cloud over a private connection.
Azure Express Route Circuits
Connect your on-premises infrastructure and Microsoft cloud services through a connectivity provider.
Azure Face
An AI service that analyzes faces in images
Azure File Storage
Fully managed file shareing in the cloud.
Azure Firewall
Managed, cloud-based network security service that protects your Azure Virtual Network resources.
Azure Front Door
Optimize application performance with visibility into requests and latency, ensuring routing efficiency and backend health.
Azure Functions
Intelligent end-to-end observability for serverless and hybrid environments using Azure Functions.
Azure HDInsight
Holistic analytics of HDInsights with integrated metrics from Hadoop, Spark, and Kafka, all in one place.
Azure Immersive Reader
An AI service to embed text reading into applications.
Azure Ink Recognizer
An AI service that provides a cloud-based REST API to analyze and recognize digital ink content.
Azure Integration Service Environment
Allows you to deploy Logic Apps as a service in your Azure Virtual Network.
Azure IoT Central Applications
Fully hosted by Microsoft, which reduces the administration overhead of managing your applications.
Azure IoT Hub
Cloud-hosted solution backend to connect virtually any device.
Azure Key Vault
Cloud service within you can securely store keys, passwords, certificates, and other secrets.
Azure Kubernetes Service
Azure Language Understanding (LUIS)
An AI service that allows users to interact with your applications, bots, and IoT devices by using natural language.
Azure Load Balancer
Layer-4 load balancer that provides high availability by distributing incoming traffic among VMs.
Azure Logic Apps
Cloud service that helps you schedule, automate, and orchestrate tasks across enterprises or organizations.
Azure Machine Learning
Collection of services and tools intended to help developers train and deploy machine learning models.
Azure Maps account
Provides the geospatial capability for mapping the data.
Azure Media Services
Cloud-based platform to build solutions that achieve broadcast-quality video streaming.
Azure NetApp Capacity Pool
Enterprise-class, high-performance, metered file storage service
Azure NetApp files
File-storage service to run your most demanding file-workloads in Azure, without the need for any code modification.
Azure Network Interface
Enables an Azure Virtual Machine to communicate with internet, Azure and on-premises resources.
Azure Network Watcher
Provides tools to monitor, diagnose, view metrics, and enable or disable logs for resources in an Azure virtual network.
Azure Notification Hub Namespaces
Push engine that allows you to send notifications to any platform from any backend (cloud or on-premises).
Azure Peerings
Virtual network peering enables you to seamlessly connect networks in Azure Virtual Network.
Azure Personalizer
An AI service that prioritizes relevant content, layouts, and conversations to deliver personalized user experience.
Azure Private DNS Zone
Hosting service for DNS domains, providing name resolution using the Microsoft Azure infrastructure.
Azure Public IP address
Reserved public IP addresses for your public endpoints in Azure.
Azure QnA Maker
Build, train and publish a sophisticated bot without machine learning experience.
Azure Queue Storage
Service for storing large numbers of messages that can be accessed from anywhere in the world.
Azure Relays
Enables you to securely expose services that run in your corporate network to the public cloud.
Azure Search Services
Fully managed cloud search service that provides a better user experience for customers.
Azure Service Bus
Cloud messaging as a service (MaaS) and simple hybrid integration.
Azure Service-Fabric
Package, deploy, and manage scalable and reliable microservices and containers.
Azure Service Fabric Mesh
Deployment of microservice applications without managing virtual machines, storage, or networking.
Azure Service-Fabric Reliable Services
Simplifies writing and managing stateless and stateful services.
Azure SignalR
Adding real-time communications to your web application is as simple as provisioning a service.
Azure Speech To Text
An AI service that accurately converts spoken audio to text.
Azure Spring Cloud
Brings modern microservice patterns to Spring Boot apps eliminating boilerplate code to quickly develop robust Java apps.
Azure SQL Database
Managed cloud database provided as part of Microsoft Azure.
Azure SQL Managed
Full observability into cloud database performance and automated monitoring for Azure SQL Managed.
Azure SQL Server Stratch
Dynamically stretch warm and cold transactional data from SQL Server 2016 to Azure.
Azure Storage Sync Service
Centralize your file shares in the cloud while keeping the benefits of an on-premise file server.
Azure Stream Analytics Jobs
Serverless job service that eliminates the need for infrastructure, servers, virtual machines, or managed clusters.
Azure Synapse Analytics
Cloud-based, scale-out, relational database capable of processing massive volumes of data.
Azure Table Storage
Stores structured NoSQL data in the cloud, providing a key/attribute store with a schemaless design.
Azure Text Analytics
Uncover insights such as sentiment, entities, and key phrases in unstructured text.
Azure Time Series Insights
Fully managed analytics, storage, and visualization service for managing IoT-scale time-series data in the cloud.
Azure Traffic Manager
Multi-cloud support for improved application performance and availability with distributed tracing.
Azure Translator
AI powered service to translate text in real time across more than 70 languages.
Azure Virtual Machines
Documentation for creating and managing Windows virtual machines in Azure.
Azure Virtual Machine Scale Sets
Scale-out workloads, stateless web front ends, container orchestration, and microservices clusters.
Azure Virtual machines (classic)
Deep observability into Azure cloud service virtual machines and applications.
Azure Virtual Network Gateway
Monitor connecting workloads and performance to ensure Azure network is successfully connected.
Azure Virtual Networks
Fundamental building block for your private network in Azure. VNet enables many types of Azure resources.
Azure Web Apps
Host websites, web apps, RESTful APIs, and mobile back ends in Azure App Service.
Backbone.js
JavaScript library based on the Model–view–presenter application design paradigm.
BellSoft Liberica
Bitbucket
Version control repository service for source code thas use either Mercurial or Git systems.
BizTalk Plugin 2.0
Easy, cheap, reliable and secure way to load Biztalk metrics into Dynatrace, based on the Dynatrace WMI 2.0 standard.
Blazemeter
Commercial, self-service load testing platform as a service.
BOSH bpm
Automated monitoring of platform processes running in BOSH bpm containers.
C
Procedural programming language supporting lexical variable scope, and recursion.
CakePHP
Automatically and intelligently monitor, analyze, and optimize your applications developed with CakePHP.
CentOS
Community-supported computing platform compatible with Red Hat Enterprise Linux.
Chef
Configuration management tool.
Citrix NetScaler ADC
All-in-one web ADC that makes applications run up to five times faster.
Citrix Virtual Apps and Desktops
Complete virtual app and desktop solution to meet all your business needs.
Cloud Automation Control Plane
Extend Dynatrace with an enterprise-grade control plane for lifecycle orchestration, release validation and closed-loop problem remediation.
CloudFlare
Content-delivery-network services, DDoS mitigation, Internet security, and distributed services.
Cloud Foundry
Harness automation and AI to simplify observability on Cloud Foundry at scale.
Composer
Simplify Administration and Configuration Management for Dynatrace
Concourse
Concourse is the automation engine for cloud native CI/CD.
Confluent Cloud (Kafka)
Remotely monitor your Confluent Cloud Kafka Cluster and other resources with this Prometheus based Extension 2.0.
Connection Pools: JBoss
Application server method of pooling and sharing multiple connections to a database.
Connection Pools: Tomcat
Connection Pools: WebLogic
Connection Pools: WebSphere Liberty
Consul Service Mesh (StatsD)
Extend visibility into your Consul Service Mesh instances to monitor health and improve performance.
containerd
Automated distributed tracing and metrics for microservices running in containerd containers in Kubernetes.
Control-M Jobs
ActiveGate extension to monitor your Control-M jobs execution status.
CoreDNS
Detailed visibility of CoreDNS server health state and throughput
Couchbase
Automatically and intelligently observe, analyze and optimize how your the usage, health and performance of your NoSQL database.
cri-o
Automated distributed tracing and metrics for microservices running in cri-o containers in Kubernetes.
Custom Database Queries
Make custom databases queries to your Oracle, Postgres, MSSQL, DB2 or Informix databases and send the metrics to Dynatrace
Databricks
Use this extension to ingest metrics from your Databricks Clusters via the embedded Ganglia metric repository.
Davis Assistant
Immediate actionable answers to complex Dynatrace questions with a simple conversation.
DC/OS
Monitor application and cluster health in highly-dynamic container environments.
Debian
Association of individuals who have made common cause to create a free operating system.
Disk Analytics
This extension allows more detailed visibility on Linux hosts' local datastores where OneAgent is installed. DDUs required.
Docker
Automated distributed tracing and metrics for microservices running in docker containers in Kubernetes.
Dojo
Modular JavaScript library open source based.
Drupal
Web content management for back-end framework.
Dynatrace API Gateway by ESA
Define and enforce fine-grained policies for using the Dynatrace APIs.
Dynatrace App for Android
The Dynatrace mobile app provides real-time alerts detected in your application environment.
Dynatrace app for iOS
Provides real-time alerts on your iPhone/iPad when performance problems are detected.
Dynatrace ETL Service by ESA
Continuously extract metrics and properties for Dynatrace entities, user sessions and more.
Dynatrace Self-Monitoring (Managed)
This extension enables a dashboard for the self-monitoring environment on the Managed cluster showing cluster utilization and data ingest.
Dynatrace Solution Server by ESA
Seamlessly deploy, manage, and run ESA Solutions and conventional Dynatrace extensions.
Eclipse Jetty
Provides a Web server and javax.servlet container.
Eclipse OpenJ9
Eclipse Temurin (Adoptium)
Elasticsearch
Provides a distributed, multitenant-capable full-text search engine, based on the Lucene library.
Ember.js
Open-source JavaScript web framework, based on the Model–view–viewmodel pattern.
Erlang
General-purpose, concurrent, functional programming language, and a runtime system.
etcd for OpenShift
Get deep insights into your self-managed OpenShift control plane using etcd metrics exposed on your cluster.
Eureka
Used in the AWS cloud for locating services for load balancing and failover of servers.
Express
Fast, unopinionated, minimalist web framework for Node.js.
F5 BIG-IP LTM
Monitor your F5 BIG-IP Local Traffic Manager (LTM) platform remotely and gain insights into the health and performance of these devices.
Fedora
Linux distribution sponsored primarily by Red Hat, a subsidiary of IBM.
Filesystem monitoring
Performs basic file or folder checks on your monitored hosts.
Fluentd
Stream log data to Dynatrace via Fluentd for analysis.
Flutter
Monitor mobile applications built with Flutter on iOS or Android.
Fortinet Fortigate
Monitor your Fortigate devices via the REST API
Fujitsu Interstage
Suite of inter-working software products.
Fujitsu Interstage IHS
Complete suite of software that helps companies continuously visualize and optimize their business.
Fujitsu JVM
Garden-RunC
Automated distributed tracing and metrics for microservices running in garden runc containers in Cloud Foundry.
Gatling
Open-source load and performance testing framework based on Scala, Akka and Netty.
Generic Cisco Device
Monitor Cisco devices using SNMP to feed Dynatrace with metrics and enable alerting.
Generic Linux Commands
Remotely execute commands on your Linux hosts (over SSH). Baseline and alert on your KPIs through metrics created from the command output.
Generic network device
Level up your network infrastructure observability by monitoring your network equipment within the Dynatrace platform.
GlassFish
Go
Automatic and intelligent end-to-end observability for Go applications
Google AI Platform
Get insights into Google AI Platform service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Analytics
Track and optimize marketing campaigns with shared business context from UTM parameters tracked in Google Analytics.
Google Analytics Real-Time
Import your Google Analytics real-time data into Dynatrace and correlate it with all other metrics provided by Dynatrace.
Google Apigee
Get insights into Google Apigee service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google App Engine
Service and cloud computing platform for developing and hosting web applications.
Google App Engine. Monitor with GCP integration
Get insights into Google App Engine service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Assistant Smart Home
Get insights into Google Assistant Smart Home metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google Big Query
Get insights into Google BigQuery service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Chrome
Cross-platform web browser developed by Google.
Google Cloud APIs
Get insights into Google Cloud APIs service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Bigtable
Get insights into Google Cloud Bigtable metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Composer
Get insights into Google Cloud Composer metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Data Loss Prevention
Get insights into Google Data Loss Prevention metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google Cloud DNS
Get insights into Google Cloud DNS service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Filestore
Monitor your Google Cloud Filestore services using metrics ingested to your Dynatrace cluster
Google Cloud Firestore
Get insights into Google Cloud Firestore metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Functions
Intelligent end-to-end observability for serverless and hybrid environments using Google Functions.
Google Cloud IoT Core
Get insights into Google Cloud IoT Core metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Load Balancing
Get insights into Google Load Balancing metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Platform
Meet your business challenges head on with cloud computing services from Google.
Google Cloud Router
Get insights into Google Cloud Router service metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google Cloud Run
Dynatrace provides AI-powered observability into serverless containerized apps running on Google Cloud Run
Google Cloud Run. Monitor with GCP integration
Get insights into Google Cloud Run service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud's operations suite
Get insights into Google Cloud's operations suite metrics collected from the Google Operations API to ensure health of cloud infrastructure.
Google Cloud Spanner
Get insights into Google Cloud Spanner metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud SQL
Get insights into Google Cloud SQL service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Storage
Get insights into Google Cloud Storage metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Storage Transfer
Get insights into Google Cloud Storage Transfer metrics collected from the Google Operations API to ensure health of cloud infrastructure.
Google Cloud Tasks
Get insights into Google Cloud Tasks service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Tensor Processing Unit (TPU)
Train and run machine learning models.
Google CloudTrace
Distributed tracing system that collects latency data from your apps and displays it in the GCP.
Google Compute Engine
Service component of Google Cloud Platform, built on the global infrastructure.
Google Compute Engine. Monitor with GCP integration
Get insights into Google Compute Engine metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Container-optimized OS
Dynatrace OneAgent monitors Kubernetes nodes with Google's secure Container-optimized OS quickly, efficiently, and securely.
Google Dataflow
Get insights into Google Dataflow service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Dataproc
Get insights into Google Dataproc service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Firebase
Get insights into Google Firebase service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Firestore in Datastore mode
Get insights into Google Firestore in Datastore mode metrics collected from the Google Operations API to ensure health of infrastructure
Google Hybrid Connectivity
Get insights into Google Hybrid Connectivity metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Kubernetes Engine
Google Kubernetes Engine (GKE). Monitor with GCP integration
Get insights into Google Kubernetes Engine metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Managed Microsoft AD
Get insights into Google Managed Microsoft AD metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google Memorystore
Get insights into Google Memorystore service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Network Security
Get insights into Google Network Security metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Network Topology
Get insights into Google Network Topology metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Pub/Sub
Get insights into Google Pub/Sub service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Pub/Sub Lite
Get insights into Google Pub/Sub Lite service metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google reCAPTCHA Enterprise
Get insights into Google reCAPTCHA Enterprise metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google Virtual Private Cloud
Get insights into Google Virtual Private Cloud metrics collected from the Google Operations API to ensure health of cloud infrastructure.
Google VPC access
Provides support for Google VPC access.
GraalVM
Grails
Automatically and intelligently monitor, analyze, and optimize your applications developed with Grails.
Gremlin for Dynatrace
Gremlin for Dynatrace enables engineers to build more reliable software by running Chaos Engineering experiments with confidence.
gRPC
Open source remote procedure call (RPC) system.
GWT Web Toolkit
Set of tools that allows web developers to create and maintain JavaScript front-end applications.
Hadoop HDFS
The Hadoop Distributed File System (HDFS) is a distributed file system designed for high throughput, large application data sets.
Hadoop YARN
Collection of utilities that allows to solve problems involving massive amounts of data.
HAProxy
Load balancer and proxy server for applications that spreads requests across multiple servers.
HAProxy (Prometheus)
Monitor HAProxy Load balancer using prometheus to feed Dynatrace with metrics.
HashiCorp Terraform
Leverage Terraform to automate deployment of dashboards, custom services, management zones etc. across your complete Dynatrace instance.
Hazelcast
Dynatrace PurePath® technology seamlessly integrates OpenTracing data for Java emitted by the Hazelcast in-memory computing platform.
Heroku
Platform as a service that enables developers to build, run, and operate applications in the cloud.
Hitachi JVM
How fast is your app?
Measure your native mobile app performance and availability on real Android and iPhone devices, with no instrumentation.
HTML5
Markup language used for structuring and presenting content on the web.
HTTP
Application protocol for distributed, collaborative, hypermedia information systems.
HTTP2
Binary protocol that brings push, multiplexing streams and frame control to the web.
Huawei JVM
Hystrix
Isolate points of access to remote systems, services, and third-party libraries.
IBM AIX
Series of proprietary Unix operating systems developed and sold by IBM.
IBM App Connect Enterprise
Allows business information to flow between applications across multiple platforms.
IBM Bluemix
Architecture diagram templates to create your own architectures using simple icons.
IBM CICS Transaction Gateway for z/OS
Trace your transactions end-to-end and understand the performance of your z/OS Transaction Gateways.
IBM CICS Transaction Server
Trace your transactions end-to-end and understand the performance of your CICS regions.
IBM Cloud Foundry
Set of cloud computing services for business offered by the information technology company IBM.
IBM Cloud Kubernetes Service
IBM DataPower
Enables the classification of data requests based on service and application-level information.
IBM DB2
Data management products, including database servers, developed by IBM.
IBM DB2 LUW
Extend IBM DB2 for Linux, UNIX and Windows (LUW) monitoring capabilities with a deeper look into performance metrics.
IBM Event Streams
Monitor your IBM Event Streams, a Kafka offering by IBM.
IBM HTTP Server
Automatically and intelligently monitor, analyze, and optimize your applications developed with IBM HTTP Server.
IBM i
Versatile, Multi-Environment H2Servers for the Era of e-business on demand.
IBM IMS
Trace your transactions end-to-end and understand the performance of your IMS regions.
IBM IMS SOAP Gateway
Trace your transactions end-to-end and understand the performance of your IMS SOAP Gateways.
IBM Informix
Remotely monitor your Informix databases and get insight into crucial Informix metrics
IBM Integration Bus
IBM JVM
IBM MQ
Automatic and intelligent observability for IBM MQ with end-to-end traces of connected producers and consumers.
IBM MQ - ActiveGate
ActiveGate extension that allows monitoring of IBM MQ performance remotely.
IBM Semeru
IBM WebSphere Application Server
IBM WebSphere Application Server for z/OS
Trace your transactions end-to-end and understand the performance of your WebSphere Application Server instances.
IBM WebSphere Liberty
IBM WebSphere Liberty for z/OS
Automatically and intelligently monitor, analyze and optimize your application server and all applications deployed on your entire stack.
IBM WebSphere Message Broker
Allows information to flow between disparate applications across multiple platforms.
IBM z/Linux
Collective term for the Linux operating system compiled to run on IBM mainframes.
IBM z/OS
Understand the performance and availability of your LPARs.
IBM z/OS Connect Enterprise Edition
Trace your transactions end-to-end and understand the performance of your z/OS Connect instances.
ICEFaces
Open-source Rich Internet Application (RIA) development framework for Java EE.
InterSystems IRIS (Remote)
ActiveGate extension that collects metrics and events from the InterSystems IRIS APIs for use in Dynatrace.
Ionic
Monitor hybrid mobile apps built with the Ionic framework running on iOS or Android
iOS
Monitor mobile applications that are running on Apple's popular iOS operating system.
iOS Safari
ISAM
Collect metrics about IBM Security Access Manager (ISAM)
Istio
Open platform to connect, manage, and secure microservices.
Istio and Envoy Service Mesh (Prometheus)
Istio service mesh helps managing distributed microservices architectures, especially in Kubernetes.
Java
Automatic and intelligent end-to-end observability for Java applications
Java JDBC
Application programming interface for the Java, defines access to a database.
Java JMS
Java message-oriented middleware API for sending messages between two or more clients.
JavaScript
Programming language that conforms to the ECMAScript specification.
JBoss Enterprise Application Platform
Joomla
Management system for publishing web content.
jQuery
JavaScript library designed to simplify HTML DOM tree traversal and manipulation.
Juniper Networks (SNMP)
Start monitoring your Juniper Network devices to collect metrics and enable alerting on top of them.
Jython
Implementation of the Python programming language designed to run on the Java platform.
Keptn
Event-based control plane for continuous delivery and automated operations.
Kestrel for ASP.NET Core
Automatically and intelligently monitor, analyze and optimize your ASP.NET Core apps running on a Kestrel web server.
Kubernetes
Kubernetes Monitoring Statistics
Effective troubleshooting of your Dynatrace Kubernetes monitoring and Prometheus integration setup.
Kubernetes persistent volume claims
Monitor your Kubernetes persistent volume claims and alert on capacity limits.
KVM
Monitor health and performance of KVM virtual machines from the system’s perspective.
Laravel
Automatically and intelligently monitor, analyze, and optimize your applications developed with Laravel.
LDAP
Vendor-neutral protocol for accessing and maintaining distributed directory information services.
LDAP Synthetic
Execute synthetic LDAP searches to monitor the availability of your LDAP servers
Lightrun Developer Observability Platform
Troubleshoot and understand the behavior of live, cloud-native apps by adding logs metrics and snapshots in real-time directly from your IDE
LinkerdD
Observability, reliability, and security without requiring any code changes for Kubernetes.
Linkerd Service Mesh (Prometheus)
LInkerd service mesh provides runtime debugging, observability, reliability, and security with zero code changes.
Linux
Family of open source Unix-like operating systems based on the Linux kernel.
LoadRunner
Load testing tool for project teams.
Logstash
Stream log data from Logstash and analyze it in Dynatrace.
Machine Learning on AWS
Robust, cloud-based service that makes it easy for developers of all skill levels to use machine learning technology.
Magento
Deep insight into user experience, top landing & exit pages and bounce rates.
MariaDB
Maven
Muild automation tool used primarily for Java projects.
Memcached
Distributed memory-caching system often used to speed up dynamic database-driven websites.
Micrometer
Automatically ingest Spring Application metrics and analyze them end-to-end in context of your trace, log and diagnostics data.
Microsoft Active Directory replication
Monitors the sync status of your Active Directory servers as well as the file shares status.
Microsoft Azure
Cloud computing service for building, testing, deploying, and managing applications and services.
Microsoft Edge
Real user monitoring - visibility and monitoring starting on you clients browser (desktop, tablet, mobile)
Microsoft Exchange Server
Monitor health and improve performance of your Microsoft Exchange mail server and calendaring server.
Microsoft Hyper-V
Monitor health and performance of Microsoft Hyper-V virtual machines from the system’s perspective.
Microsoft Hyper-V (WMI)
Monitor health and performance of native Windows virtual machines from the host’s perspective
Microsoft IIS
Flexible, secure and manageable Web server for hosting anything on the Web for Windows® Server.
Microsoft Internet Explorer
Series of graphical web browsers.
Microsoft Message Queuing (MSMQ)
Automatic and intelligent observability for MSMQ with end-to-end traces of connected producers and consumers.
Microsoft SQL Server
Expand visibility to improve the health and performance monitoring of your Microsoft SQL Servers!
Microsoft Teams
Hub for team collaboration in Microsoft 365 that integrates the people, content, and tools.
Microsoft Visual Studio
Integrated development environment from Microsoft.
MongoDB
Mongo DB Atlas
Monitoring of your SaaS installation of Mongo DB (Atlas)
MongoDB (Prometheus)
Monitor MongoDB server using prometheus to feed Dynatrace with metrics.
MooTools
Object-oriented JavaScript framework. Released under the free, open-source MIT License.
Mozilla Firefox
Free, open source web browser that uses the Gecko layout engine.
MuleSoft
Event source enabling you to set up an HTTP server and trigger flows when requests are received.
MuleSoft (Cloudhub)
Gather metrics about your Workers and Applications running in MuleSoft Cloudhub
MySQL
MySQL (remote monitoring)
Expand visibility to improve the health and performance monitoring of your MySQL databases!
Nagios Integration
Monitoring consolidation - eliminate event storms, reduce MTTR using Nagios hosts data and problems in Dynatrace leveraging Davis AI engine.
Neo4j
Extend observability with PurePath® distributed traces by seamlessly integrating OpenTracing data emitted by the Neo4j graph database.
NeoLoad
Automated Load Testing tool enabling you to run Continuous Performance Testing.
NetApp on Google Cloud
Get insights into NetApp on Google Cloud metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
NetApp OnTap (Remote)
ActiveGate extension that collects important NetApp OnTap metrics from the OnTap 9.6+ REST API for use in Dynatrace.
Netbackup Jobs
Monitor your Veritas Netbackup jobs execution status
.NET Core
Deep insights into the your .NET Core framework and optimize the overall performance.
.NET Framework
Software framework developed by Microsoft that runs primarily on Microsoft Windows.
.NET/.NET Core
Automatic and intelligent end-to-end observability for .NET/.NET Core applications
Netty
I/O client-server framework for the development of Java network applications.
NGINX
Accelerates application delivery, improves security, facilitates availability & scalability.
NGINX Plus
All‑in‑one load balancer, content cache, and web server.
Nobl9 SLO Platform
Nobl9 simplifies SLO usage with an integrated approach that enables SLI collection, SLO calculation, and error budget alerts.
Node.js
Automatic and intelligent end-to-end observability for Node.js applications
NTP sync check
Network Time Protocol assures host clocks are in sync with a trusted time source
Nutanix AHV
Monitor health and performance of Nutanix AHV virtual machines from the system’s perspective.
NVIDIA GPUs
Monitor the utilization and temperature of your NVIDIA GPUs
Omniscopy
User Journey analytics for Dynatrace DEM to understand and reduce friction points affecting user engagement and end-user productivity.
OpenJDK
OpenMetrics
Use OpenMetrics to ingest, store and analyze metrics at scale
OpenShift Control Plane
Get deep insights into your OpenShift control plane using metrics exposed by various control plane components.
openSUSE
The openSUSE project is a community program sponsored by SUSE Linux and other companies.
OpenTelemetry Metrics
Ingest and chart custom OpenTelemetry metrics, set alerts, and analyze them in the context of trace, log, and diagnostics data.
OpenTelemetry Tracing
Ingest OpenTelemetry traces, pin them to your dashboard, set alerts, and analyze them in the context of metrics, log, and diagnostics data.
OpenTracing
Ingest and chart OpenTracing data, set alerts, and analyze everything in the context of traces, metrics, logs, and diagnostics data.
Opera
Freeware web browser for Microsoft Windows, Android, iOS, macOS, and Linux operating systems.
Opsgenie
Alerting and on-call management platform for operating always-on services.
Oracle Cloud
Cloud computing serviceproviding servers, storage, network, applications and services.
Oracle Database
Automatically and intelligently observe, analyze and optimize the usage, health and performance of your Oracle database.
Oracle Hotspot VM
Oracle HTTP Server
Web server component for Oracle Fusion Middleware.
Oracle JRockit
Oracle Solaris
Provides proven, enterprise-class security, reliability, and performance for SPARC and x86 systems.
Oracle WebLogic
OutSystems Cloud Metrics
OutSystems is a leading low-code application platform. With this integration, their Cloud API data becomes available inside Dynatrace.
PagerDuty
SaaS incident response platform for IT departments.
Palo Alto firewalls
Monitor Palo Alto firewalls using SNMP to feed Dynatrace with metrics to allow alerting and Davis problem detection
Payara
Perl
Perl is a family of two high-level, general-purpose, interpreted, dynamic programming languages.
PHP
Automatic and intelligent end-to-end observability for PHP applications
PHPUnit
Unit testing framework for the PHP programming language.
Ping Every Second
Measure your network latency every second, understand the performance level and receive more details about network availability.
Pivotal Platform
Multi-cloud platform for the deployment, management, and continuous delivery of applications. Pivotal is now VMware Tanzu.
Play Framework
Automatically and intelligently monitor, analyze, and optimize your applications developed with Play Framework.
PostgreSQL
Process connections
Gather data about the number of connections and their state for any process
Prometheus
Prometheus is an open-source monitoring toolkit for collecting and alerting on infrastructure and platform metrics.
Prometheus Alertmanager
Integrate alerts from Prometheus Alertmanager into Dynatrace
Prometheus in Kubernetes
Collect metrics from Prometheus exporters in Kubernetes for Dynatrace analysis and alerting.
prototype
Web JavaScript framework, implemented as a single file of JavaScript code.
Python
End-to-end observability for your Python applications
QEMU
Monitor health and performance of QEMU virtual machines from the system’s perspective.
RabbitMQ
Automatic and intelligent observability for RabbitMQ with end-to-end traces of connected producers and consumers.
RabbitMQ (Prometheus)
Start monitoring the most widely deployed open source message broker within minutes
React.js
JavaScript library for building user interfaces.
React Native
Monitor mobile applications built with React Native running on iOS or Android.
Scale existing apps across bare-metal, virtual, container, and all types of cloud environments.
Red Hat Enterprise Linux CoreOS
Open-source lightweight OS based on the Linux, providing infrastructure to clustered deployments.
Red Hat OpenShift
Harness automation and AI to simplify observability on OpenShift at scale.
Red Hat OpenStack
Free open standard cloud computing platform, infrastructure-as-a-service in clouds.
Redis
Automatically and intelligently observe, analyze and optimize how your the usage, health and performance of your Redis in memory store.
Redis Enterprise
Provides deep visibility into Redis Enterprise software installations. Auto-detects Redis Enterprise features and monitors automatically.
Remote Desktop Protocol
Monitor the performance of user sessions for Windows RDP, and gain insights into the health of your Virtual Desktop solution.
Remote Linux Monitoring
ActiveGate extension that remotely monitors Linux OS and process metrics by connecting via SSH and executing commands.
Remote Windows Host Monitoring
Monitor health and improve performance of Microsoft Windows Hosts without installing an agent
restify
Framework for building semantically correct RESTful web services ready for use at scale.
Riak
NoSQL data store that offers high availability, operational simplicity, and scalability.
Richfaces
Ajax-enabled component library for JavaServer Faces (open source).
Ruby
Dynatrace monitors your Ruby applications and services on the process level.
Runtime vulnerability detection
Detect vulnerabilities in your environment in real-time, with full context and automated risk assessment.
Salesforce Streaming API
Activegate extension, uses Openkit to create user sessions based on Salesforce Event Stream events
Salt Stack
Infrastructure automation software that is used to drive security and reliability.
SAP Business Technology Platform
SAP Business Technology Platform (SAP BTP) is the technological foundation for the intelligent enterprise
SAP Commerce Cloud
SAP Cloud Platform integrates data and business processes.
SAP GUI and ABAP platform
Automatic problem detection and visibility into every user transaction, and insight into the performance of RFC without changing any code.
SAP HANA Database
Easily understand the health and performance of your SAP HANA databases!
SAP Hybris
Cloud based CRM (customer relationship management) Suite.
SAP JVM
Scala
Programming language providing support for functional programming and a strong static type system.
Selenium WebDriver
Web automation framework that allows you to execute your tests against different browsers.
Sencha ExtJS
JavaScript application framework for building interactive cross platform web applications.
Sencha Touch
Automatically and intelligently monitor, analyze, and optimize your applications developed with Sencha Touch.
ServiceNow
IT service management for large corporations, including help desk functionality.
servicetrace
Monitor the performance of any application from an end user‘s perspective.
Siebel
Gathers metrics from the Siebel SARM logs to provide aggregated task information
SIGNL4 – Critical Mobile Alerting
For a 10x faster response to critical incidents.
Slack
Where the people you need, the information you share, and the tools you use come together.
SNMP Traps
Supplement network device statistics with event-based data reported via SNMP Traps
Snyk
Snyk is integrated with Dynatrace to provide precise vulnerability matches, actionable descriptions, and detailed remediation guidance.
Solarwinds
Monitor events and node performance
Spring
Application framework and inversion of control container for the Java platform.
SSL Checker
Detects expired SSL certificates
StatsD
The easiest way to get you custom application metrics into Dynatrace.
SUSE Linux Enterprise Server
Distributed system and application software from other open source projects.
Symfony
Automatically and intelligently monitor, analyze, and optimize your applications developed with Symfony.
Synthetic monitor DNS
Synthetically monitor your DNS servers to be proactively alerted when they go down.
Synthetic monitor Ping
Synthetically monitor your device availability using ping. This allows you to be proactively alerted when they are unavailable.
Synthetic monitor Ports
Synthetically monitor port availability on your servers. This allows you to be proactively alerted when they are unavailable.
Synthetic Monitor SSH
Report on KPIs through Synthetic monitors that execute Linux commands over SSH and interpret results numerically or by regular expressions.
Synthetic SFTP monitor
Monitor SFTP availability and performance. Visualize the data as Synthetic tests in Dynatrace.
TeamCity
Powerful continuous integration out of the box.
Telegraf
Automatically analyze and monitor hundreds of Telegraf provided plugins and metrics with Dynatrace
Tempest - Dynatrace for Jira
Accelerate service operations and reduce MTTR using automated problems integration and Smartscape for CMDB synchronization into Jira
TIBCO ActiveMatrix BusinessWorks
Complete observability of applications and technologies across BusinessWorks processes.
TIBCO EMS
Automatic and intelligent observability for Tibco EMS with end-to-end traces of connected producers and consumers.
Timeseries Streamer
Export any Dynatrace metric to external timeseries databases for advanced processing, analytics and visualization.
Trello
Easy, free, flexible, and visual way to manage your projects and organize anything.
T-Systems / Jenkins
Self-contained Java-based program, ready to run out-of-the-box.
tvOS
Monitor mobile apps running on Apple TV.
Ubuntu
Open-source, free Linux distribution based on Debian.
Varnish
HTTP accelerator designed for content-heavy dynamic web sites as well as APIs.
Varnish Cache
versio.io
Change detection and processing platform for business and IT with real-time CMDB
Vert.x
Extend observability by seamlessly integrating OpenTracing data emitted by the Vert.x web framework into PurePath® distributed traces.
VictorOps
Incident management platform that combines the power of people and data to embolden DevOps teams.
VMware
Monitor health and performance of VMware virtual machines from the system’s perspective.
VMware Cloud on AWS
Integrated cloud offering jointly developed by Amazon Web Services (AWS) and VMware.
VMware ESXi Host
Monitor health and performance of VMware ESXi virtual machines from the system’s perspective.
VMware Horizon
Gather metrics from your VMware Horizon gateways, connection servers, domains, farms, event databases and Remote Desktop Services (RDS)
VMware Tanzu
Dynatrace & VMware Tanzu – accelerate adoption automatic, AI-powered; TAS, TKG, hybrid, multi-cloud, automated DevOps continuous CD.
VMware Unified Access Gateway
Gather connection metrics for your VMware UAG (Unified Access Gateway)
VMware VCenter Alarms
Collects VCenter triggered alarms into Dynatrace
VMware vCenter Server
Monitor health and performance of VMware vCenter Server virtual machines from the system’s perspective.
VMware vSAN
Gather metrics about your VMware vSAN Datastores
WebHooks
Out-of-the-box integrations that automatically push problem notifications to third-party solutions.
Wildfly
Windows
Group of several proprietary graphical operating system families, developed by Microsoft.
Windows Communication Foundation (WCF)
Free and open-source runtime in the .NET Framework for building connected, service-oriented apps.
Windows Scheduled Tasks
Monitor the state and execution of your tasks set up in Windows Task Scheduler.
Windows Server File System Quotas
Monitor the utilization of your File System Quotas in Windows Servers
WIPRO Holmes
All your needs from building to monetization of heterogeneous AI solutions.
WordPress
Content management system written in PHP and paired with a MySQL or MariaDB database.
WSO2 API Manager
A fully open-source, full lifecycle API Management solution.
Xamarin
Monitor mobile applications built with Microsofts's popular Xamarin platform running on iOS or Android.
Xcode
Environment containing a suite for developing software for macOS, iOS, iPadOS, watchOS, and tvOS.
Xen
Monitor health and performance of Xen virtual machines from the system’s perspective.
xMatters
xMatters powers the world’s most reliable customer experiences.
Yii
Automatically and intelligently monitor, analyze, and optimize your applications developed with Yii.
Zabbix hosts
Bring events from your Zabbix Hosts into Dynatrace
Zabbix Integration
Monitoring consolidation - eliminate event storms, reduce MTTR using Zabbix hosts data and problems in Dynatrace leveraging Davis AI engine
Zenduty
Modern incident response with Dynatrace & Zenduty
ZigiOps - Integration Platform
ZigiOps is a highly scalable no-code integration platform, which creates powerful integrations within minutes with security in mind.
ZK
Open-source Ajax Web application framework, written in Java.
