Extend the platform,
empower your team.
Network Time Protocol assures host clocks are in sync with a trusted time source.
Technology by DynatraceNTP extension measures time deviation on the host compared to the time source and reports time offset, which can be later used to alert on hosts going out of sync.
The reference servers, if available, are automatically obtained from the following sources:
/etc/ntp.conf
System\CurrentControlSet\Services\W32Time\Parameters
under value NtpServer
If your host isn't synced with an NTP server, you can pass a comma-separated list of servers to check the time against. A server is selected at random for each request, similar to actual NTP sync operation.
You can specify the NTP servers at the environment level or for a single host.
Because the extension makes its own NTP requests, you can expect an increased load on your NTP servers of one request per host per minute. However, the absolute network overhead will likely be insignificant.
The extension collects just one metric, NTP time offset, which is the time drift from the configured time server. Drift can be positive or negative, indicating that the host is ahead of or behind the time received from the NTP server. You can access collected measurements by creating a simple chart showing the NTP time offset over time.
The only available dimension for the NTP time offset metric is the host. 3. Set Visualization to Graph, Line. 4. Select Run query to display the preview chart. 5. To pin the chart to a dashboard of your choice, select Pin to dashboard.
For details, see Data explorer.
Network Time Protocol is used to synchronize time across a network of computers. Time synchronization is vital to many distributed systems, including Kubernetes. You can use Dynatrace to monitor the time offset of your hosts and chart it on your dashboards.
Because Dynatrace detects host time drift, you can also track NTP synchronization failures. If your host isn't synced to any NTP server, you can manually add an NTP server of your choice. Dynatrace won't synchronize time on your host but will measure the offset.
