Extend the platform,
empower your team.
Remotely monitor your Veritas NetBackup Jobs and Storoge
ExtensionThis extension gather metrics and events through the Veritas NetBackup APIs. Every minute the extension polls NetBackup for Events, Jobs and Storage data.
This extension enables insights into the overall health, status and capacity of NetBackup.
Activate the extension in your environment using the in-product Hub and provide the required configuration. Follow the instructions and prompts within the extension settings.
The extension requires a user with read-only access to query: Jobs, Alerts, Storage Servers, Disk Pools, Storage Drives, Malware scans, Eventlog Notifications
This extension uses the API to collect important resource data.
This extension collects data for:
/admin/jobs
/manage/alerts
/storage/disk-pools
/storage/drives
/malware/scan-results
/eventlog/notifications
This extension also defines a metric event to generate Dynatrace problems for failing jobs. A problem will be raised when a NetBackup Job finishes with a status code other than 0 (success). The full list of status codes with descriptions and recommendations and are available at: Veritas NetBackup™ Status Codes Reference Guide. You can enable/disable this event under Dynatrace Settings -> Anomaly Detection -> Metric Events -> NetBackup Job Failure
Below is a complete list of the feature sets provided in this version. To ensure a good fit for your needs, individual metrics can be activated and deactivated by your administrator during configuration.
Metric name | Metric key | Description | Unit |
Storage Server Used Space | veritas.netbackup.storage.server.usedSpaceBytes | Used space of the storage server in bytes | Byte |
Storage Server available Space | veritas.netbackup.storage.server.availableSpaceBytes | Available space of the storage server in bytes | Byte |
Storage Server State | veritas.netbackup.storage.server.state | The State of the storage server | Count |
Disk Pool Usable Size | veritas.netbackup.storage.disk_pool.usableSizeBytes | Usable size of the disk-pool in bytes | Byte |
Disk Pool Used Size | veritas.netbackup.storage.disk_pool.usedCapacityBytes | Used size of the disk-pool in bytes | Byte |
Disk Pool State | veritas.netbackup.storage.disk_pool.state | State of the disk pool | Count |
Connectivity | veritas.netbackup.connectivity | Netbackup successful connection percentage | Percent |
Job Status | veritas.netbackup.job.status | The Netbackup status code of the job. Status code 0 is successful. | Count |
Drive driveControl status | veritas.netbackup.storage.drive.driveControl | State of the driveControl | Count |
Drive status | veritas.netbackup.storage.drive.driveStatus | State of the storage drive | Count |
endTime ge <CURRENT_TIME - SCHEDULE>
No release notes
