Monitor your Veritas Netbackup jobs execution status.
The Netbackup Jobs extension gathers metrics and events about Netbackup Jobs.
There is a single metric called Job States that counts the number of jobs on each state, like DONE, QUEUED, ACTIVE, REQUEUED, etc.
When a job fails, an event is sent to Dynatrace with the details
The Extension must be installed both on an ActiveGate and on the Dynatrace Cluster. See Deploy an extension in our full documentation for more details.
Extract the extension zip file to the plugin_deployment
folder at the root of the remote plugin module.
Linux:
unzip -o -d /opt/dynatrace/remotepluginmodule/plugin_deployment custom.remote.python.netbackup.zip
/opt/dynatrace
Windows:
%PROGRAMFILES%\dynatrace\remotepluginmodule\plugin_deployment
Upload the same extension zip file to your tenant. The Extension configuration and upload UI is located at:
Settings > Monitored technologies > Custom extensions > Upload extension
The parameters for each endpoint are:
