Monitoring consolidation - eliminate event storms, reduce MTTR using Nagios hosts data and problems in Dynatrace leveraging Davis AI engine.
Consolidate and integrate your monitoring tools. Alanata's Nagios integration enables you to connect existing Nagios monitoring with Dynatrace. Enrich Dynatrace SmartScape with Nagios hosts, ingest Nagios problems, and let Davis AI engine process the problems together with native Dynatrace events in an integrated AIOps solution. With this extension, you can use Dynatrace as a unifying platform for data from external monitoring solutions, eliminate event storms and minimize the time spent investigating.
Synchronization:
Filtering:
Context information:
Problem metric:
Nagios technology:
