Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
MySQL (remote monitoring)MySQL (remote monitoring)
Remotely monitor your MySQL instances, collect key KPIs and slow queries details
Extension
Free trialDocumentation
Overview dashboardInstance statistics on the new platformSlow queries viewExecution plan details
  • Product information
  • Release notes
Overview
Remotely monitor MySQL databases where you cannot install an OneAgent.
Get started
Activating the extension
  • Activate Extension in the Hub by going to:
  • Extensions → MySQL → Add to environment
  • Add a new monitoring configuration for every MySQL instance you'd like to monitor
Creating a MySQL user
Create a user that is identified by a native password, customize the username and password as you please
CREATE USER 'dynatrace'@'%' IDENTIFIED WITH mysql_native_password BY 'password';
Give the user the permissions:
  • GRANT SELECT ON performance_schema.* TO 'dynatrace'@'%';
    • Allows the user to query the performance_schema schema
  • GRANT PROCESS ON *.* TO 'dynatrace'@'%';
    • Allows the user to see thread and connection metrics for other users
  • GRANT SHOW DATABASES ON *.* TO 'dynatrace'@'%';
    • Allows the user to see database metrics for all databases
  • GRANT SELECT ON mysql.slow_log TO 'dynatrace'@'%';
    • Allows the user to query slow queries
  • GRANT SELECT ON sys.x$memory_global_by_current_bytes TO 'dynatrace'@'%';
    • Allow the user to query memory statistics
NOTE: Due to a MySQL limitation, to calculate database sizes you MUST grant SELECT permissions on the individual databases where you want to collect size from.
Collecting Infrastructure metrics
To enable CPU metrics collection, run this query on the MySQL instance:
SET GLOBAL innodb_monitor_enable='cpu%';
Collecting Top Slow Queries
Enable slow queries logging to a table:
SET GLOBAL log_output = 'TABLE';
SET GLOBAL slow_query_log = 'ON';
The default slow query threshold is 10 seconds You can chose the threshold of what is a "slow query" by executing:
SET GLOBAL long_query_time = 2;
This would set slow queries threshold to 2 seconds.
Execution Plan Fetching
To fetch execution plans, you must create a stored procedure for the dynatrace user:
CREATE SCHEMA IF NOT EXISTS dynatrace;
DELIMITER $$
CREATE PROCEDURE dynatrace.dynatrace_execution_plan(IN query TEXT)
    SQL SECURITY DEFINER
BEGIN
    SET @explain := CONCAT('EXPLAIN FORMAT=JSON ', query);
    PREPARE stmt FROM @explain;
    EXECUTE stmt;
    DEALLOCATE PREPARE stmt;
END $$
DELIMITER ;
And then grant execution permission for the dynatrace user
GRANT EXECUTE ON PROCEDURE dynatrace.dynatrace_execution_plan TO 'dynatrace'@'%';
Compatibility information
  • MySQL >= 5.7
FAQ
Why don't I see Waits metrics?
To gather wait metrics, data collection need to be enabled for the MySQL instance, please refer to the documentation: https://dev.mysql.com/doc/mysql-perfschema-excerpt/8.0/en/performance-schema-wait-tables.html
Can I monitor MariaDB with this extension?
This extension was only tested against MySQL instances, MariaDB is not officially supported via this extension.
I get an error "RSA public key is not available client side"
This means that the username is not identified by a native password, please refer to Get Started.
I can't see CPU and Memory metrics
Make sure that data collection is enabled for your instance.
  • For CPU: SET GLOBAL innodb_monitor_enable='cpu%';
  • For Memory: Visit https://dev.mysql.com/doc/refman/8.0/en/monitor-mysql-memory-use.html
You can test that you can query the data by running:
SELECT * FROM information_schema.INNODB_METRICS WHERE name IN ('cpu_utime_abs', 'cpu_stime_abs');
And:
SELECT SUBSTRING_INDEX(event_name,'/',2) AS code_area,
                SUM(current_alloc) AS current_alloc
          FROM sys.x$memory_global_by_current_bytes
          GROUP BY SUBSTRING_INDEX(event_name,'/',2)
          ORDER BY SUM(current_alloc) DESC;
I can't see slow queries
Refer to the Collecting Top Slow Queries in the Getting Started session.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Extension content
Content typeNumber of items included
screen chart groups
13
screen logs cards
4
screen injections
1
screen layout
3
screen entities lists
6
list screen layout
2
metric metadata
33
generic relationship
3
screen custom cards
2
dashboards
1
screen actions
2
screen properties
3
generic type
2
screen dql table
4
Feature sets
Waits IOmysql.waits.waits_io.countThe number of times that the server has waited for an I/O operation to complete.Count
Waits IO Timemysql.waits.waits_io_time.countThe total time the server has waited for I/O operations to complete.MilliSecond
Waits Syncmysql.waits.waits_sync.countThe number of times that the server has waited for a synchronization operation to complete.Count
Waits Sync Timemysql.waits.waits_sync_time.countThe total time the server has waited for synchronization operations to complete.MilliSecond
Commitsmysql.statements.commit.countThe number of COMMIT statements executed by this serverCount
Deletesmysql.statements.delete.countThe number of DELETE statements executed by this serverCount
Multi-Table Deletesmysql.statements.delete_multi.countThe number of multi-table DELETE statements executed by this serverCount
Insertsmysql.statements.insert.countThe number of INSERT statements executed by this serverCount
Selectsmysql.statements.select.countThe number of SELECT statements executed by this serverCount
Updatesmysql.statements.update.countThe number of UPDATE statements executed by this serverCount
Executesmysql.statements.execute.countThe number of EXECUTE statements executed by this serverCount
Multi-Table Updatesmysql.statements.update_multi.countThe number of multi-table UPDATE statements executed by this serverCount
Bytes Sentmysql.statements.bytes_sent.countThe number of bytes sent to all clientsByte
Bytes Receivedmysql.statements.bytes_received.countThe number of bytes received from all clientsByte
-mysql.global_status.queries.count--
Slow Queriesmysql.global_status.slow_queries.countThe number of queries that have taken more than long_query_time seconds. This counter increments regardless of whether the slow query log is enabled. For information about that log, see Section 5.4.5, The Slow Query Log.Count
Table Locks Waitedmysql.global_status.table_locks_waited.countThe number of times that a request for a table lock could not be granted immediately and a wait was needed. If this is high and you have performance problems, you should first optimize your queries, and then either split your table or tables or use replication.Count
Table Locks Immediatemysql.global_status.table_locks_immediate.countThe number of times that a request for a table lock could be granted immediately.Count
Current Connectionsmysql.global_status.current_connectionsThe number of currently open connections.Count
Threads Runningmysql.global_status.threads_runningThe number of threads that are not sleeping.Count
Innodb Buffer Pool Pages Datamysql.global_status.innodb_buffer_pool_pages_dataThe number of pages in the InnoDB buffer pool containing data. The number includes both dirty and clean pages. When using compressed tables, the reported Innodb_buffer_pool_pages_data value may be larger than Innodb_buffer_pool_pages_totalCount
Innodb Buffer Pool Pages Dirtymysql.global_status.innodb_buffer_pool_pages_dirtyThe current number of dirty pages in the InnoDB buffer pool.Count
Innodb Buffer Pool Pages Freemysql.global_status.innodb_buffer_pool_pages_freeThe number of free pages in the InnoDB buffer pool.Count
Innodb Buffer Pool Pages Totalmysql.global_status.innodb_buffer_pool_pages_totalThe total size of the InnoDB buffer pool, in pages. When using compressed tables, the reported Innodb_buffer_pool_pages_data value may be larger than Innodb_buffer_pool_pages_totalCount
Innodb Data Readsmysql.global_status.innodb_data_reads.countThe total number of data reads (OS file reads).Count
Innodb Data Writesmysql.global_status.innodb_data_writes.countThe total number of data writes.Count
Innodb Data Readmysql.global_status.innodb_data_read.countThe total amount of data read from files.Byte
Innodb Data Writtenmysql.global_status.innodb_data_written.countThe total amount of data written.Byte
Availabilitymysql.global_status.availabilityWhether or not a connection can be made to the databasePercent
Statusmysql.global_status.statusA status of AVAILABLE is returned if we can query the databaseState
CPU Usermysql.infrastructure.cpu.userThe total CPU time spent in user mode.Percent
CPU Systemmysql.infrastructure.cpu.systemThe total CPU time spent in system mode.Percent
Memorymysql.infrastructure.memoryThe amount of memory used per each code area.Byte
Database Sizemysql.databases.sizeThe size of the DatabaseMegaByte
Full version history
ReleaseDate
Version 2.0.6
🚀 Features
  • There is a now a SAME_AS relationship between a MySQL instance and its Process Group Instance.
Fixed in this version:
  • Sorting SQL statements would produce duplicate results
Version 2.0.1
  • Add support for execution plan fetching, please check the hub page for details
  • Add screen definitions for the 3rd gen platform
Note: these features require Activegate 1.293+
Version 1.1.3
  • Fix an issue with the configure extension link in the overview dashboard
Version 1.1.2
Add metrics:
  • mysql.global_status.availability
  • mysql.global_status.status
Version 1.1.1
  • Fix an issue where MySQL entities were created from unrelated logs
Version 1.1.0
  • Add CPU metrics
  • Add Memory metrics
  • Add Slow Queries (log events)
Version 1.0.0
  • First release, instance and database metrics
Dynatrace Hub
Hub HomeGet data into DynatraceBuild your own app
Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Analytics
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
All
0 Results filtered by:
Reach out to certified Dynatrace partners to solve your unique use-case
Moviri logo
Moviri
Certified individuals: 14
Advanced Sales Partner
Alanata logo
Alanata
Certified individuals: 30Endorsements: Services Endorsed Partner
Premier Sales Partner
Spica Solutions logo
Spica Solutions
Authorized Sales Partner
Matrix logo
Matrix
Omnilogy logo
Omnilogy
Certified individuals: 38Endorsements: Services Endorsed Partner
AHEAD logo
AHEAD
Certified individuals: 8
Arctiq logo
Arctiq
Certified individuals: 19
Eviden logo
Eviden
Certified individuals: 79Endorsements: Services Endorsed Partner
Phenisys logo
Phenisys
Certified individuals: 32Endorsements: Services Endorsed Partner
Accenture logo
Accenture
Certified individuals: 156
AsiaPac Technology Pte Ltd logo
AskMe Solutions & Consultants Co Ltd logo
Asper Technologia logo
Asper Technologia
Certified individuals: 20
Avocado logo
Avocado
Certified individuals: 9
avodaq AG logo
avodaq AG
Certified individuals: 31Endorsements: Services Endorsed Partner
Carahsoft logo
Carahsoft
Certified individuals: 21
Deutsche Telekom MMS gmbh logo
Certified individuals: 18Endorsements: Services Endorsed Partner
DPM logo
DPM
Certified individuals: 30Endorsements: Services Endorsed Partner, SaaS Upgrade specialization
DXC logo
DXC
Certified individuals: 341
Evolane logo
Evolane
Certified individuals: 29
Galaxy Software Services Corporation (GSS) logo
ISATEC logo
ISATEC
Certified individuals: 20Endorsements: Services Endorsed Partner
Konsalt logo
Konsalt
Certified individuals: 13
Kyndryl logo
Kyndryl
Certified individuals: 202
PRAGMA INFORMATICA SA logo
Certified individuals: 10
PT. Mitra Integrasi Informatika logo
Certified individuals: 24
Scala logo
Scala
Spindox logo
Spindox
Certified individuals: 11
TestCrew logo
TestCrew
TI724 logo
TI724
Tsoft logo
Tsoft
VS Data logo
VS Data
Certified individuals: 12
Your Compass logo
Your Compass
Certified individuals: 68Endorsements: Services Endorsed Partner, CloudOps specialization
