Monitors the sync status of your Active Directory servers as well as the file shares status.
This OneAgent extension runs commands like repadmin and net view to bring in the metrics:
The Extension must be installed both on an OneAgent and on the Dynatrace Cluster. See Deploy an extension in our full documentation for more details.
Extract the extension zip file to the plugin_deployment
folder at the root of the oneagent.
Linux:
unzip -o -d /opt/dynatrace/oneagent/plugin_deployment custom.python.ad_replication_checks.zip
/opt/dynatrace
Windows:
%PROGRAMFILES%\dynatrace\oneagent\plugin_deployment
Upload the same extension zip file to your tenant. The Extension configuration and upload UI is located at:
Settings > Monitored technologies > Custom extensions > Upload extension
There are four parameters:
