Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
LaunchDarkly Integration for DynatraceLaunchDarkly Integration for Dynatrace
The LaunchDarkly Dynatrace integration combines the analytics from Dynatrace with the power of LaunchDarkly’s feature management platform.
Technology by LaunchDarkly
Documentation
  • Product information
Overview
The LaunchDarkly Dynatrace integration makes it easier to diagnose problems by sending flag change events to Dynatrace. Dynatrace can display those events alongside performance graphs, making it easier for Dynatrace users to correlate feature rollouts to changes in operational health. We also support flag triggers with Dynatrace, allowing you to toggle a flag on or off when Dynatrace triggers a predefined or custom event.
Key Features
  • Send flag change events to Dynatrace
  • Understand the impact that features have on your operations
  • Trigger changes to feature flags based on data coming into your Dynatrace account
  • Automatically remediate issues in your infrastructure through feature flags
Resources
  • Dynatrace Performance Café - Launchdarkly
  • Accelerating Remediation with Automation
LaunchDarkly
Documentation
By the partner
Request support
Bring your own license
Copy to clipboard
Dynatrace Hub
Hub HomeGet data into DynatraceBuild your own app
Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Analytics
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
All
0 Results filtered by:
We couldn't find any results
You can search all listings, or try a different spelling or keyword. Still nothing? Dynatrace makes it easy to create custom apps.
Find a partnerLearn to build apps
