A curated catalogue of supported technologies, integrations and extensions provided by Dynatrace and trusted partners.
All the operational and business performance metrics you need.
Route traffic, monitor cloud environments, monitor remote technologies with extensions and run synthetic monitors.
Open source message broker written in Java together with a full Java Message Service client.
Get real-time answers for business anomalies with shared business context from Adobe Analytics
Monitor hybrid mobile apps built with Adobe PhoneGap running on iOS or Android
Solve ADO.NET performance problems at code level.
AI-driven full-stack solution for continuous performance optimization.
Powerful reactive, concurrent, and distributed applications in Java and Scala.
Seamlessly organize your IT infrastructure with maximum scalability, security and availability.
Service for developers to create, publish, maintain, monitor, and secure APIs.
Fully managed application streaming service that provides users with instant access to their desktop applications from anywhere.
Interactive query service that makes it easy to analyze data directly in Amazon S3 using standard SQL.
Relational database service developed and offered by Amazon Web Services.
Content delivery network offered by Amazon Web Services.
Set up, manage, and scale a search solution for your website or application using CloudSearch.
Monitoring service for AWS cloud resources and the applications you run on AWS.
Monitor, store, and access your log files from instances, AWS CloudTrail, Route 53, and other sources.
Add user sign-up, sign-in, and access control to your web and mobile apps quickly and easily.
Easy to use omnichannel cloud contact center that helps you to provide superior customer service at a lower cost.
Amazon DocumentDB (with MongoDB compatibility) is a fast, reliable, and fully managed database service.
Fully managed NoSQL database service that supports key-value and document data structures.
Fully managed, highly available, in-memory cache for your Amazon DynamoDB.
Web service that provides secure, resizable compute capacity in the cloud.
Amazon EC2 Auto Scaling helps you ensure that you have the correct number of Amazon EC2 instances available.
Spot Instances and On-Demand Instances to meet the target capacity that you specified.
Fully managed in-memory data store and cache service by Amazon Web Services.
Raw block-level storage that can be attached to Amazon EC2 instances.
Fully managed container orchestration service.
Cloud storage service provided by Amazon Web Services.
Accelerate deep learning inference workloads by attaching to your Amazon EC2 CPU instances.
Kubernetes service that allows you to run on AWS without managing the control plane.
Fully managed service to deploy, secure, and run Elasticsearch cost effectively at scale, without the operational overhead.
Convert and transcode media files stored in Amazon S3.
Cloud big data platform for processing vast amounts of data using open source tools.
Serverless event bus to connect applications together using data from your own applications, integrated SaaS applications, and AWS services.
Makes it easy and cost-effective to launch and run the popular, high-performance Lustre file system.
Provides a managed Microsoft Windows file servers, backed by a native Windows file system.
Enables developers to deploy, operate, and scale dedicated, low-cost servers in the cloud for session-based, multiplayer games.
Tests the network accessibility of your EC2 instances and the security state of your applications that run on those instances.
Scalable, highly available, and managed Apache Cassandra–compatible database service.
Transform and analyze streaming data in real time with open source framework and engine for processing data streams (Apache Flink).
Fully managed service for delivering real-time streaming data.
Collect log and event data from sources such as servers, desktops, and mobile devices.
Provides you SDKs to install on your devices to make it easy to stream media.
Service for building conversational interfaces for applications using voice and text.
Fully managed service that enables you to build and run applications that use Apache Kafka to process streaming data.
Fast, reliable, fully managed graph database built for highly connected datasets.
Cloud service that converts text into lifelike speech.
Ledger by a central trusted authority that provides an immutable, and cryptographically verifiable transaction log.
Data warehouse product which forms part of the larger cloud-computing platform AWS.
Amazon Rekognition makes it easy to add image and video analysis to your applications.
Cloud web service designed to simplify the setup, operation, and scaling of a relational database.
Effectively connects user requests to infrastructure running in AWS.
Provides object storage through a web service interface.
Build, train, and deploy machine learning (ML) models quickly.
Cloud-based service that helps developers send marketing, notification, and transactional emails.
Provides a simple web services interface that can be used to create topics you want to notify apps.
Programmatic sending of messages via web service applications.
Makes it easy to build applications that coordinate work across distributed components.
Makes it easy to add document text detection and analysis to your applications.
Provides fully managed support for file transfers directly into and out of Amazon S3 using SFTP, FTPS, and FTP
Text translation service using machine learning to provide high-quality translation on demand.
Connect to the Internet from instances within a private subnet in an AWS Virtual Private Cloud.
Secure, managed business email and calendaring service with support for existing desktop and mobile email clients.
Enables you to provision virtual, cloud-based Microsoft Windows or Amazon Linux desktops, known as WorkSpaces.
Managed message broker service for Apache ActiveMQ that makes it easy to migrate to a message broker in the cloud.
Accelerated Mobile Pages performance monitoring to ensure perfect user experience.
Monitor mobile applications that are running on the popular Android operating system.
Provides tools for browsing the web.
Platform for building mobile and desktop web applications.
JavaScript-based open-source front-end web framework mainly maintained by Google.
The simplest way to automate apps and IT infrastructure.
Way to automate apps and IT infrastructure.
Core engine for Web services.
Monitor hybrid mobile apps built with Cordova running on iOS or Android
Open-source, fully featured Web services framework.
Develop and maintain an open-source HTTP server.
Build management and continuous integration server from JetBrains.
Apache Kafka is an open-source, distributed publish-subscribe message bus designed to be fast, scalable, and durable.
Abstracts CPU, memory and storage away from machines, enabling to easily run systems effectively.
Open-source enterprise-search platform, written in Java, from the Apache Lucene project.
Distributed general-purpose cluster-computing framework for programming entire clusters.
Open source implementation of the Java Servlet, Pages, Expression Language and WebSocket.
Java Enterprise Edition of Apache Tomcat that combines several Java enterprise projects.
Design, secure, and analyze APIs across the entire API lifecycle.
Graphical web browser developed by Apple, based on the WebKit engine.
Deep visibility into the code execution of your ASP.NET apps.
Set of extensions to ASP.NET
Deep visibility into the code execution of your ASP.NET Core apps.
Deep visibility into the code execution of your ASP.NET MVC apps.
Flexible set of components for building and hosting OWIN-based web applications.
Atlassian, Dynatrace & DevOps partners - integrating AI and automation for high-caliber orchestration and collaboration.
Continuous integration and continuous deployment server developed by Atlassian.
Issue tracking product that allows bug tracking and agile project management.
Reliable, scalable, and inexpensive cloud computing services with pay-as-you-go pricing approach.
Enterprise-level, fully managed GraphQL service with real-time data synchronization and offline programming features.
The service that you use to pay your AWS bill, monitor usage, and analyze and control costs.
Enables DevOps to use Amazon Chime and Slack chat rooms to monitor and respond to events.
Hardware security modules (HSM) in the AWS Cloud.
Fully managed service that automates software deployments to a variety of compute services.
Continuous delivery service automating release pipelines for application and infrastructure updates.
Makes it easy to migrate relational databases, and other types of data stores.
Transfer service designed to simplify and automate copying large amounts of data to and from AWS services.
Links your internal network to an AWS Direct Connect location over a standard Ethernet fiber-optic cable.
Quickly deploy and manage applications in the AWS Cloud without having to learn about the infrastructure beneath.
Automatically distributes incoming application traffic across multiple targets.
Service that makes it easy for broadcasters and other premium video providers to reliably ingest live video into the AWS Cloud.
File-based video processing service that provides scalable video processing for content owners and distributors.
Just-in-time video packaging and origination service that runs in the AWS Cloud.
Scalable ad insertion service that runs in the AWS Cloud.
Serverless compute for containers. Dynatrace provides automatic monitoring of AWS Fargate containers at scale.
Fully managed extract, transform, and load (ETL) service.
Run local compute, messaging, data caching, and machine learning inference capabilities.
Automates the steps required to analyze data from IoT devices.
Orchestration service that simplifies development of IoT applications.
Automatic and intelligent end-to-end observability for AWS Lambda traces.
Configuration management service that helps you configure and operate applications by using Puppet or Chef.
Fully managed service that extends AWS infrastructure, AWS services, APIs, and much more.
Provides private connectivity between VPCs, AWS services, and on-premises applications.
Service that makes it easy to create robotics applications at scale.
Enables organizations to create and manage catalogs of IT services that are approved for use on AWS.
Allows connecting and routing from your VPC to your remote network.
Enables you to coordinate the components of distributed applications and microservices using visual workflows.
Connects an on-premises software appliance with cloud-based storage to provide data security.
View and control your infrastructure on AWS using Systems Manager.
Network transit hub interconnecting virtual private clouds (VPC) and on-premises networks.
Identifies ways to reduce cost, increase performance, and improve security for your AWS account.
Web application firewall that lets you monitor the HTTP(S) requests.
Fully managed platform as a service (PaaS) that provides enterprise-grade data models in the cloud.
Detects anomalies in time series data with numerical values that are uniformly spaced in time.
Create consistent and modern API gateways for existing back-end services.
Service to provide centrally managed application settings and feature flags.
Web traffic load balancer that enables you to manage traffic to your web applications.
An extensible Application Performance Management (APM) service for developers and DevOps.
Cloud computing based platform for hosting websites, created and operated by Microsoft.
Allows you to automate your Azure management tasks and to orchestrate actions across external systems from right within Azure.
Get complete picture of jobs, tasks and node tracking, in each state, for operational efficiency.
Helps users complete queries faster by adding intelligent type-ahead capabilities to your app or website.
An easy-to-use, ad-free, commercial-grade search tool that lets you deliver the results you want.
Bring rich context data to your apps through entity information for a more engaging experience.
Build apps and services that find webpages, images, news, locations, and more.
Correct spelling and word breaks errors, recognize slang, names, homonyms, brands and more.
Handles stored objects, with millions of requests per second, for customers around the world.
Fully managed ledger service that enables users the ability to grow and operate blockchain networks at scale in Azure.
Industry-standard SSL to secure your data in transit and Azure Storage disk encryption at rest.
Collections of CDN endpoints and each CDN profile contains one or more CDN endpoints.
Deploy web apps (web roles) and background services (worker roles) onto Azure virtual machines.
Manage VMware virtual machines (VMs) from the Azure portal.
Bring AI within reach of every developer—without requiring machine-learning expertise.
AI service to boost content discoverability, automate text extraction, analyze video in real time, and more.
This tool is designed to meet and accomplish your hybrid identity goals.
Deploy and manage serverless containers on the Microsoft Azure cloud, without having to manage any underlying infrastructure.
Managed, private Docker registry service based on the open-source Docker Registry 2.0.
AI service for content moderation and human review tool for images, text, and videos.
Globally-distributed, multi-model database service "for managing data at planet-scale".
Customize computer vision for specific domain. No machine learning expertise is required.
Full coverage of performance for critical workloads with AI-problem detection, availability, and more.
Full observability of MYSQL servers and database instances to ensure database health and performance.
Full insight into database performance for critical workloads with AI-problem detection and more.
Rebranded as Azure Stack Edge. ... Azure Stack Edge is a Hardware-as-a-service solution.
Fully managed cloud service that lets users discover the data sources they need and understand the data sources they find.
Engine and data management clusters which uses several Azure resources such as Azure Linux VM's and Storage.
Cloud-based ETL and data integration service for creating data-driven workflows for moving and transforming data at scale.
Distributed, cloud-based data processing architecture offered by Microsoft in the Azure cloud.
Fully-managed, elastic, scalable, and secure file system that supports HDFS semantics and works with the Hadoop ecosystem.
Platform as a Service tool that allows you to share data sets using Azure Services.
Helper service for IoT Hub that enables just-in-time provisioning to the right IoT hub without human intervention.
Integrate Dynatrace via Keptn into your Azure DevOps Pipelines to automate SLO-based quality gates & enable performance as a self-service
Cloud storage offering providing multiple solutions for organizations.
Data resource that contains the DNS records for a domain name.
Simplifies the development of event-based applications and simplifies the creation of serverless workflows.
Support for Azure Event Grid Subscriptions.
Topic based events for serverless and event based workflows.
Big data streaming platform and event ingestion service. It can receive and process millions of events per second.
Fully managed data ingestion service that's simple, and scalable.
Extend your on-premise networks into the Microsoft cloud over a private connection.
Connect your on-premises infrastructure and Microsoft cloud services through a connectivity provider.
An AI service that analyzes faces in images
Fully managed file shareing in the cloud.
Managed, cloud-based network security service that protects your Azure Virtual Network resources.
Optimize application performance with visibility into requests and latency, ensuring routing efficiency and backend health.
Serverless compute functions. Dynatraces provides full observability for Azure functions end-to-end, at scale.
Holistic analytics of HDInsights with integrated metrics from Hadoop, Spark, and Kafka, all in one place.
An AI service to embed text reading into applications.
An AI service that provides a cloud-based REST API to analyze and recognize digital ink content.
Allows you to deploy Logic Apps as a service in your Azure Virtual Network.
Fully hosted by Microsoft, which reduces the administration overhead of managing your applications.
Cloud-hosted solution backend to connect virtually any device.
Cloud service within you can securely store keys, passwords, certificates, and other secrets.
Kubernetes based, managed container orchestration service, available on the Microsoft Azure public cloud.
Migrate existing application to container(s) and run within the Azure managed Kubernetes service.
An AI service that allows users to interact with your applications, bots, and IoT devices by using natural language.
Layer-4 load balancer that provides high availability by distributing incoming traffic among VMs.
Cloud service that helps you schedule, automate, and orchestrate tasks across enterprises or organizations.
Collection of services and tools intended to help developers train and deploy machine learning models.
Provides the geospatial capability for mapping the data.
Cloud-based platform to build solutions that achieve broadcast-quality video streaming.
Enterprise-class, high-performance, metered file storage service
File-storage service to run your most demanding file-workloads in Azure, without the need for any code modification.
Enables an Azure Virtual Machine to communicate with internet, Azure and on-premises resources.
Provides tools to monitor, diagnose, view metrics, and enable or disable logs for resources in an Azure virtual network.
Push engine that allows you to send notifications to any platform from any backend (cloud or on-premises).
Virtual network peering enables you to seamlessly connect networks in Azure Virtual Network.
An AI service that prioritizes relevant content, layouts, and conversations to deliver personalized user experience.
Hosting service for DNS domains, providing name resolution using the Microsoft Azure infrastructure.
Reserved public IP addresses for your public endpoints in Azure.
Build, train and publish a sophisticated bot without machine learning experience.
Service for storing large numbers of messages that can be accessed from anywhere in the world.
Enables you to securely expose services that run in your corporate network to the public cloud.
Fully managed cloud search service that provides a better user experience for customers.
Cloud messaging as a service (MaaS) and simple hybrid integration.
Package, deploy, and manage scalable and reliable microservices and containers.
Deployment of microservice applications without managing virtual machines, storage, or networking.
Simplifies writing and managing stateless and stateful services.
Adding real-time communications to your web application is as simple as provisioning a service.
An AI service that accurately converts spoken audio to text.
Brings modern microservice patterns to Spring Boot apps eliminating boilerplate code to quickly develop robust Java apps.
Managed cloud database provided as part of Microsoft Azure.
Full observability into cloud database performance and automated monitoring for Azure SQL Managed.
Dynamically stretch warm and cold transactional data from SQL Server 2016 to Azure.
Centralize your file shares in the cloud while keeping the benefits of an on-premise file server.
Serverless job service that eliminates the need for infrastructure, servers, virtual machines, or managed clusters.
Cloud-based, scale-out, relational database capable of processing massive volumes of data.
Stores structured NoSQL data in the cloud, providing a key/attribute store with a schemaless design.
Uncover insights such as sentiment, entities, and key phrases in unstructured text.
Fully managed analytics, storage, and visualization service for managing IoT-scale time-series data in the cloud.
Multi-cloud support for improved application performance and availability with distributed tracing.
AI powered service to translate text in real time across more than 70 languages.
Documentation for creating and managing Windows virtual machines in Azure.
Scale-out workloads, stateless web front ends, container orchestration, and microservices clusters.
Deep observability into Azure cloud service virtual machines and applications.
Monitor connecting workloads and performance to ensure Azure network is successfully connected.
Fundamental building block for your private network in Azure. VNet enables many types of Azure resources.
Host websites, web apps, RESTful APIs, and mobile back ends in Azure App Service.
JavaScript library based on the Model–view–presenter application design paradigm.
Version control repository service for source code thas use either Mercurial or Git systems.
Commercial, self-service load testing platform as a service.
Auto-injection in BOSH bpm container (Deep monitoring)
Procedural programming language supporting lexical variable scope, and recursion.
High-level, general-purpose programming language as an extension of the C programming language.
Open-source web framework, model–view–controller approach.
Right choice when you need scalability and high availability without compromising performance.
Community-supported computing platform compatible with Red Hat Enterprise Linux.
Configuration management tool.
Monitor your Cisco Adaptive Security Appliance (ASA) devices
All-in-one web ADC that makes applications run up to five times faster.
Complete virtual app and desktop solution to meet all your business needs.
Content-delivery-network services, DDoS mitigation, Internet security, and distributed services.
Open source cloud application platform for developing and deploying cloud applications.
Concourse is the automation engine for cloud native CI/CD.
Application server method of pooling and sharing multiple connections to a database.
HashiCorp's Consul service mesh is designed to work with traditional and legacy applications, and workloads running in Kubernetes.
Automated deep monitoring w/o code-changes for apps and microservices running in containerd containers in Kubernetes.
Monitor your Control-M jobs execution status
Detailed visibility of CoreDNS server health state and throughput
Open-source lightweight OS based on the Linux, providing infrastructure to clustered deployments.
NoSQL document-oriented database software package optimized for interactive applications.
Open-source document-oriented NoSQL database, implemented in Erlang.
Automated deep monitoring w/o code-changes for apps and microservices running in cri-o containers in Kubernetes.
Make custom databases queries to your Oracle, Postgres, MSSQL or DB2 databases and send the metrics to Dynatrace
Immediate actionable answers to complex Dynatrace questions with a simple conversation.
Monitor application and cluster health in highly-dynamic container environments.
Association of individuals who have made common cause to create a free operating system.
Ansible collection for OneAgent deployment is an official and supported method for rolling out OneAgents in large environments.
OS-level virtualization to deliver software in packages called containers.
Modular JavaScript library open source based.
Web content management for back-end framework.
The Dynatrace mobile app provides real-time alerts detected in your application environment.
Provides real-time alerts on your iPhone/iPad when performance problems are detected.
Integrated development environment.
Provides a Web server and javax.servlet container.
Provides a distributed, multitenant-capable full-text search engine, based on the Lucene library.
DevOps software by Cloudbees.
Open-source JavaScript web framework, based on the Model–view–viewmodel pattern.
General-purpose, concurrent, functional programming language, and a runtime system.
Used in the AWS cloud for locating services for load balancing and failover of servers.
Fast, unopinionated, minimalist web framework for Node.js.
Intelligently manages network traffic so applications are always fast, available, and secure.
Linux distribution sponsored primarily by Red Hat, a subsidiary of IBM.
Check for files existence, size, modification date, content or permissions
Stream your logs via Fluentd to Dynatrace and analyze them
Monitor mobile applications built with Flutter on iOS or Android.
Monitor your Fortigate devices via the REST API
Suite of inter-working software products.
Complete suite of software that helps companies continuously visualize and optimize their business.
Auto-injection in Garden-RunC container (Deep monitoring)
Open-source load and performance testing framework based on Scala, Akka and Netty.
Open source Java EE reference implementation.
Open source language that makes it easy to build simple, reliable, and efficient software.
Track and optimize marketing campaigns with shared business context from UTM parameters tracked in Google Analytics.
Service and cloud computing platform for developing and hosting web applications.
Enterprise data warehouse.
NoSQL Big Data database service.
Cross-platform web browser developed by Google.
Programmatic interfaces for Google Cloud services.
A fully managed workflow orchestration service.
Streaming analytics service.
A cloud service for running Apache Spark and Apache Hadoop clusters.
Support for Google Cloud DNS.
High-performance, fully managed file storage.
A flexible, scalable database for mobile, web, and server development.
Get direct physical connections between your on-prem network and Google Cloud.
Secure device connection and management.
High performance, scalable load balancing across multiple targets.
A fully managed in-memory data store service.
Meet your business challenges head on with cloud computing services from Google.
Exchange routes between your VPC and on-premises networks by using BGP.
Dynatrace provides AI-powered observability into serverless containerized apps running on Google Cloud Run
MySQL database service.
Reliable and secure object storage for any amount of data.
Distributed task queues.
Train and run machine learning models.
Distributed tracing system that collects latency data from your apps and displays it in the GCP.
Service component of Google Cloud Platform, built on the global infrastructure.
Dynatrace OneAgent monitors Kubernetes nodes with Google's secure Container-optimized OS quickly, efficiently, and securely.
Provides fast, scalable classification and redaction for sensitive data elements.
NoSQL database.
Mobile platform for application development.
Serverless platform for building event-based microservices.
Dynatrace provides AI powered observability for Google Kubernetes Engine pods, nodes, and clusters.
Machine learning services.
Service running Microsoft AD that enables you to manage authentication and authorization.
Visualization tool for viewing the topology of your VPC networks and the metrics.
Real-time messaging service.
Help protect your website from fraudulent activity, spam, and abuse.
Horizontally scalable, globally consistent, relational database service.
Complete large-scale online data transfers from online and on-premises sources to Cloud Storage.
Provides support for Google VPC access.
Java VM and JDK based on HotSpot/OpenJDK, implemented in Java.
Build automation system that introduces a language for declaring the project configuration.
Groovy-based web application framework for the JVM built on top of Spring Boot.
Open source remote procedure call (RPC) system.
Set of tools that allows web developers to create and maintain JavaScript front-end applications.
The Hadoop Distributed File System (HDFS) is a distributed file system designed for high throughput, large application data sets.
Collection of utilities that allows to solve problems involving massive amounts of data.
Load balancer and proxy server for applications that spreads requests across multiple servers.
Leverage Terraform to automate deployment of dashboards, custom services, management zones etc. across your complete Dynatrace instance.
Dynatrace PurePath 4 seamlessly integrates OpenTracing data for Java emitted by the Hazelcast in-memory computing platform.
Platform as a service that enables developers to build, run, and operate applications in the cloud.
Open-source asynchronous messaging project from JBoss.
Markup language used for structuring and presenting content on the web.
Application protocol for distributed, collaborative, hypermedia information systems.
Binary protocol that brings push, multiplexing streams and frame control to the web.
Isolate points of access to remote systems, services, and third-party libraries.
Series of proprietary Unix operating systems developed and sold by IBM.
Allows business information to flow between applications across multiple platforms.
Architecture diagram templates to create your own architectures using simple icons.
General-purpose transaction processing subsystem for the z/OS® operating system.
Set of cloud computing services for business offered by the information technology company IBM.
Dynatrace provides AI powered observability for IBM Cloud Kubernetes Service pods, nodes, and clusters.
Enables the classification of data requests based on service and application-level information.
Data management products, including database servers, developed by IBM.
Extend IBM DB2 for Linux, UNIX and Windows (LUW) monitoring capabilities with a deeper look into performance metrics.
Web server that runs on AIX, HP-UX, Linux, Solaris, JADE, Windows NT, IBM i and z/OS.
Versatile, Multi-Environment H2Servers for the Era of e-business on demand.
Database and information management system with extensive transaction processing capabilities.
Platform-specific component that runs a Java program.
Enterprise-grade messaging capabilities that safely move information between applications.
Monitor issues in your Watson Explorer Engine collections
Application and integration middleware allowing end-users to create and integrate applications.
Java server runtime environment for enterprise applications.
Application server for modernizing and building applications and cloud-native services.
Allows information to flow between disparate applications across multiple platforms.
Enterprise software used to build and manage web portals.
Collective term for the Linux operating system compiled to run on IBM mainframes.
Monitor your entire stack with a single solution, and control the sprawl.
Mainframe operating system that offers a stable, secure, and continuously available environment.
Open-source Rich Internet Application (RIA) development framework for Java EE.
Monitor hybrid mobile apps built with the Ionic framework running on iOS or Android
Monitor mobile applications that are running on Apple's popular iOS operating system.
Collect metrics about IBM Security Access Manager (ISAM)
Open platform to connect, manage, and secure microservices.
Istio service mesh helps managing distributed microservices architectures, especially in Kubernetes.
The #1 programming language for IoT, enterprise architecture, and cloud.
Application programming interface for the Java, defines access to a database.
Java message-oriented middleware API for sending messages between two or more clients.
Programming language that conforms to the ECMAScript specification.
Delivers enterprise-grade security, performance, and scalability in any environment.
Open source server which enables developers to reliably build, test, and deploy their software.
Management system for publishing web content.
JavaScript library designed to simplify HTML DOM tree traversal and manipulation.
Networking & cybersecurity solutions to service providers, enterprise companies & public sector.
Unit testing framework for the Java programming language.
Implementation of the Python programming language designed to run on the Java platform.
Event-based control plane for continuous delivery and automated operations.
Open-source system for automating deployment, scaling, and management of containerized applications.
Virtualization module in the Linux kernel that allows the kernel to function as a hypervisor.
PHP web framework, intended for the development of web applications.
Vendor-neutral protocol for accessing and maintaining distributed directory information services.
Execute synthetic LDAP searches to monitor the availability of your LDAP servers
Observability, reliability, and security without requiring any code changes for Kubernetes.
LInkerD service mesh provides runtime debugging, observability, reliability, and security with zero code changes.
Family of open source Unix-like operating systems based on the Linux kernel.
Load testing tool for project teams.
Robust, cloud-based service that makes it easy for developers of all skill levels to use machine learning technology.
Deep insight into user experience, top landing & exit pages and bounce rates.
Muild automation tool used primarily for Java projects.
Distributed memory-caching system often used to speed up dynamic database-driven websites.
Monitors the sync status of your Active Directory servers
Cloud computing service for building, testing, deploying, and managing applications and services.
Gather metrics from your Biztalk Server deployments
Real user monitoring - visibility and monitoring starting on you clients browser (desktop, tablet, mobile)
Mail server and calendaring server developed by Microsoft.
Native hypervisor that can create virtual machines on x86-64 systems running Windows.
Flexible, secure and manageable Web server for hosting anything on the Web for Windows® Server.
Series of graphical web browsers.
Gather metrics about your MSMQ queues
Database management system - store and retrieve data as requested by other software applications.
Expand visibility to improve the health and performance monitoring of your Microsoft SQL Servers!
Hub for team collaboration in Microsoft 365 that integrates the people, content, and tools.
Integrated development environment from Microsoft.
Distributed database built for modern application developers and for the cloud era.
Object-oriented JavaScript framework. Released under the free, open-source MIT License.
Free, open source web browser that uses the Gecko layout engine.
Event source enabling you to set up an HTTP server and trigger flows when requests are received.
Gather metrics about your Workers and Applications running in Mulesoft Cloudhub
Open-source relational database management system.
Expand visibility to improve the health and performance monitoring of your MySQL databases!
Automated Load Testing tool enabling you to run Continuous Performance Testing.
Automated performance testing platform that helps enterprises to implement continuous testing.
Developer platform for building apps: web, mobile, desktop, gaming, IoT, cloud, and microservices.
Monitor your Veritas Netbackup jobs execution status
Deep insights into the your .NET Core framework and optimize the overall performance.
Provides runtime containers, libraries and services that power microservices.
Software framework developed by Microsoft that runs primarily on Microsoft Windows.
Portable Class Libraries enalbes you to share code across various platform-specific projects.
Lightweight and easy to deploy queueing system on premises and in the cloud.
Application programming interface for interprocess communication.
Formal specification of .NET APIs that are intended to be available on all .NET implementations.
I/O client-server framework for the development of Java network applications.
Computing platform created by Microsoft and first introduced in Windows 10.
Accelerates application delivery, improves security, facilitates availability & scalability.
All‑in‑one load balancer, content cache, and web server.
JavaScript runtime built on Chrome's V8 JavaScript engine.
Network Time Protocol assures host clocks are in sync with a trusted time source
Open-source unit testing framework for the .NET Framework and Mono.
Monitor your OCSP certificates and validate them against an OCSP Responder
Use OpenMetrics to ingest, store and analyze metrics at scale
The openSUSE project is a community program sponsored by SUSE Linux and other companies.
Dynatrace seamlessly integrates OpenTelemetry data to provide end-to-end distributed tracing, analysis, and actionable answers at scale.
Dynatrace PurePath 4 seamlessly integrates OpenTracing data emitted by auto- and custom-instrumentation of Java source code.
Freeware web browser for Microsoft Windows, Android, iOS, macOS, and Linux operating systems.
Alerting and on-call management platform for operating always-on services.
Monitor the utilization of your Oracle ASM (Automatic Storage Management) disks
Cloud computing serviceproviding servers, storage, network, applications and services.
Database management system used for running online transaction processing and data warehousing.
Monitor the synchronization of your Oracle GoldenGate Veridata tables
Gather CPU, memory and filesystem metrics from Oracle GridControl
Web server component for Oracle Fusion Middleware.
Provides proven, enterprise-class security, reliability, and performance for SPARC and x86 systems.
Allows building enterprise applications using Java EE, and deploying them.
SaaS incident response platform for IT departments.
Gather metrics from your Palo Alto firewalls using SNMP
Gather any perfmon (performance monitor) metrics from your windows hosts
Perl is a family of two high-level, general-purpose, interpreted, dynamic programming languages.
Popular general-purpose scripting language that is especially suited for web development.
FPM (FastCGI Process Manager) is an alternative PHP FastCGI implementation for heavy-loaded sites.
Unit testing framework for the PHP programming language.
Multi-cloud platform for the deployment, management, and continuous delivery of applications. Pivotal is now VMware Tanzu.
Open-source web application framework which follows the model–view–controller architectural pattern.
Relational database management system emphasizing extensibility and SQL compliance.
Gather data about the number of connections and their state for any process
Collect metrics from Prometheus exporters in Kubernetes and analyze them with Dynatrace.
Web JavaScript framework, implemented as a single file of JavaScript code.
Python is an interpreted, high-level, general-purpose programming language.
Open-source emulator that performs hardware virtualization.
Monitor your RadiantOne Federated Identity and Directory Service clusters health
JavaScript library for building user interfaces.
Monitor mobile applications built with React Native running on iOS or Android.
Provides open source software products to the enterprise community.
Scale existing apps across bare-metal, virtual, container, and all types of cloud environments.
Consistent hybrid cloud foundation for building and scaling containerized applications.
Free open standard cloud computing platform, infrastructure-as-a-service in clouds.
Open source, in-memory data structure store, used as a database, cache and message broker.
Framework for building semantically correct RESTful web services ready for use at scale.
NoSQL data store that offers high availability, operational simplicity, and scalability.
Ajax-enabled component library for JavaServer Faces (open source).
Dynatrace monitors your Ruby applications and services on the process level.
Detect vulnerabilities in loaded libraries in real-time, with full context and automated risk assessment.
Infrastructure automation software that is used to drive security and reliability.
Interpreted, high-level, general-purpose programming language.
SAP Cloud Platform integrates data and business processes.
SAP GUI is the primary way in which SAP users interact with SAP ERP systems. ABAP is the default programming language for SAP applications.
Easily understand the health and performance of your SAP HANA databases!
Cloud based CRM (customer relationship management) Suite.
Programming language providing support for functional programming and a strong static type system.
Retrieve alerts and metrics from SCOM to augment Davis, the Dynatrace AI
Web automation framework that allows you to execute your tests against different browsers.
JavaScript application framework for building interactive cross platform web applications.
User interface JavaScript library, or web framework, specifically built for the Mobile Web.
IT service management for large corporations, including help desk functionality.
Monitor the performance of any application from an end user‘s perspective.
Gathers metrics from the Siebel SARM logs to provide aggregated task information
Where the people you need, the information you share, and the tools you use come together.
Monitoring devices using SNMP feeds Dynatrace with metrics to allow alerting and Davis problem detection
Receive SNMP traps and create Dynatrace Problems from them.
Snyk is integrated with Dynatrace to provide precise vulnerability matches, actionable descriptions, and detailed remediation guidance.
Monitor events and node performance
Application framework and inversion of control container for the Java platform.
Gather metrics about your Always On availability groups, availability databases and replicas
The easiest way to get you custom application metrics into Dynatrace.
Software versioning and revision control system distributed under the Apache License.
Distributed system and application software from other open source projects.
Monitor the health of your Suse Pacemaker clusters
Gathers performance and utilization metrics from Sybase ASE
Gathers performance and utilization metrics from Sybase IQ
PHP web application framework and a set of reusable PHP components/libraries.
Make sure that your databases always respond in a timely fashion by using a synthetic monitor.
Synthetically monitor your DNS servers to be proactively alerted when they go down.
Synthetically monitor your device availability using ping. This allows you to be proactively alerted when they are unavailable.
Synthetically monitor port availability on your servers. This allows you to be proactively alerted when they are unavailable.
Monitor SFTP availability and performance.
Powerful continuous integration out of the box.
Automatically analyze and monitor hundreds of Telegraf provided plugins and metrics with Dynatrace
Tempest’s integration for Jira connects Dynatrace AI-powered, end-to-end, full-stack data and intelligent metrics with Atlassian Jira.
Complete observability of applications and technologies across BusinessWorks processes.
Automatic monitoring and tracing for flawless Enterprise-grade messaging system.
Easy, free, flexible, and visual way to manage your projects and organize anything.
Self-contained Java-based program, ready to run out-of-the-box.
Monitor mobile apps running on Apple TV.
Open-source, free Linux distribution based on Debian.
HTTP accelerator designed for content-heavy dynamic web sites as well as APIs.
Collect VCenter alerts into Dynatrace
Centralized management utility for VMware.
Store topology meta data, metrics and configurations of IT monitoring to support IT operations.
Incident management platform that combines the power of people and data to embolden DevOps teams.
Virtualization solution to partion a single physical server into multiple virtual machines.
Integrated cloud offering jointly developed by Amazon Web Services (AWS) and VMware.
Servers/data storage devices on which the ESX or ESXi hypervisor has been installed.
Gather metrics from your VMware Horizon gateways, connection servers, domains, farms, event databases and Remote Desktop Services (RDS)
Dynatrace & VMware Tanzu – accelerate adoption automatic, AI-powered; TAS, TKG, hybrid, multi-cloud, automated DevOps continuous CD.
Gather connection metrics for your VMware UAG (Unified Access Gateway)
Gather metrics about your VMware vSAN datastores
Out-of-the-box integrations that automatically push problem notifications to third-party solutions.
Flexible, lightweight, managed application runtime that helps you build amazing applications.
Group of several proprietary graphical operating system families, developed by Microsoft.
Free and open-source runtime in the .NET Framework for building connected, service-oriented apps.
Monitors completion of tasks on Windows Scheduler
Increase security, evolve your datacenter, and innovate faster with the cloud-ready OS.
Monitor the utilization of your File System Quotas in Windows Servers
All your needs from building to monetization of heterogeneous AI solutions.
Content management system written in PHP and paired with a MySQL or MariaDB database.
A fully open-source, full lifecycle API Management solution.
Monitor mobile applications built with Microsofts's popular Xamarin platform running on iOS or Android.
Environment containing a suite for developing software for macOS, iOS, iPadOS, watchOS, and tvOS.
Offers a solution for Application Release Orchestration.
Type-1 hypervisor, allows computer operating systems to execute on the same hardware concurrently.
Identify, prevent, and resolve IT issues before they impact customers.
Open source, object-oriented, component-based MVC PHP web application framework.
Bring events from your Zabbix Hosts into Dynatrace
Open-source Ajax Web application framework, written in Java.
