Remotely monitor your Informix databases and get insight into crucial Informix metrics.
This extension remotely connects to your Informix instances and collects the following metrics:
The Extension must be installed both on an ActiveGate and on the Dynatrace Cluster. See Deploy an extension in our full documentation for more details.
Extract the extension zip file to the plugin_deployment
folder at the root of the remote plugin module.
Linux:
unzip -o -d /opt/dynatrace/remotepluginmodule/plugin_deployment custom.remote.python.informix.zip
/opt/dynatrace
Windows:
%PROGRAMFILES%\dynatrace\remotepluginmodule\plugin_deployment
Upload the same extension zip file to your tenant. The Extension configuration and upload UI is located at:
Settings > Monitored technologies > Custom extensions > Upload extension
For every Informix instance, create an endpoint under Settings > Monitored Technologies > Custom extensions > Informix
We recommend monitoring up to 20 Informix endpoints on a single Activegate machine
The parameters are:
