Install the z/OS Java module
With the z/OS Java module, you can get observability for your Java applications including IBM MQ and database calls.
Observability for | Including |
WebSphere Application Server WebSphere Liberty |
z/OS Connect |
CICS/IMS transactions | Transactions initiated using
Database calls | Database calls with their SQL statements from Java applications to Db2 via JDBC |
Analyze the performance of your transactions end-to-end using the Service flow.
Use the PurePath distributed traces to drill down to the code level and to optimize your programs.
Quickly detect anomalies with the Service response time hotspots.
Analyze failures and exceptions with detailed stack traces.
Gain insights into your JVM with the Dynatrace managed memory metrics:
Understand the health and performance of your application servers with technology-specific metrics:
JVM specific metrics:
Metric group | Metric | Source |
JVM memory | Garbage collection total activation count | JMX |
JVM memory | Garbage collection total collection time | JMX |
JVM memory pool | Garbage collection count | JMX |
JVM memory pool | Garbage collection time | JMX |
JVM memory pool | Heap memory pool maximum bytes | JMX |
JVM memory pool | Heap memory pool committed bytes | JMX |
JVM memory pool | Heap memory pool used bytes | JMX |
JVM memory runtime | Runtime maximum memory | JMX |
JVM memory runtime | Runtime total memory | JMX |
JVM memory runtime | Runtime free memory | JMX |
JVM threads | Thread count | JMX |
JVM classes | Total number of loaded classes | JMX |
JVM classes | Number of loaded classes | JMX |
JVM classes | Number of unloaded classes | JMX |
WebSphere Liberty and z/OS Connect specific metrics:
Metric group | Metric | Metric description | Source |
JDBC connection pool | In use connections | The number of connections in use. This number might include multiple connections that are shared from a single managed connection. | JMX |
JDBC connection pool | Free connections | The number of managed connections in the free pool. | JMX |
JDBC connection pool | Managed connections | The total number of managed connections in the free, shared, and unshared pools. | JMX |
JDBC connection pool | In use time | The average time in milliseconds that a connection is in use. | JMX |
JDBC connection pool | Wait time | The average waiting time in milliseconds until a connection is granted if a connection is not currently available. | JMX |
Thread pool | Pool size | The average number of threads in pool. | JMX |
Thread pool | Active threads | The number of active threads that are serving requests. | JMX |
Servlet | Request count | The total number of requests that a servlet processed. | JMX |
Websphere Application Server specific metrics:
JDBC connection pool | Pool size | The size of the connection pool. | PMI |
JDBC connection pool | Free pool size | The number of managed connections that are in the free pool. | PMI |
JDBC connection pool | Concurrent waiters | The number of threads that are currently waiting for a connection. | PMI |
JDBC connection pool | Average wait time | The average waiting time in milliseconds until a connection is granted if a connection is not currently available. | PMI |
JDBC connection pool | Average use time | The average time in milliseconds that a connection is in use. | PMI |
JDBC connection pool | Percent used | The percent of the pool that is in use. | PMI |
Thread pool | Pool size | The average number of threads in pool. | PMI |
Thread pool | Active threads | The number of concurrently active threads. | PMI |
Servlet | Live sessions | The number of local sessions that are currently cached in memory from the time at which this metric is enabled. | PMI |
Servlet | Total requests | The total number of requests that a servlet processed. | PMI |
Yes, you can use the z/OS Java module to monitor custom JMX metrics. For more information, see Monitor JMX metrics on z/OS.
Prerequisite
Activate the OneAgent feature Forward Tag 4 trace context extension.
Download
Download z/OS product datasets and extract the JAR file (
dynatrace-oneagent-zos-java.jar
Transfer the JAR file to your z/OS Unix System Services (USS) environment in binary mode.
Create a new file with the name
dtconfig.json
in the z/OS USS folder where the module is located.A minimal
dtconfig.json
file contains your Dynatrace environment ID (Tenant), cluster ID (ClusterID), and the zDC subsystem name (ZdcName). For example:{"Tenant": "<tenant>","ClusterID": <cluster>,"ZdcName": "DEFAULT"}Replace
<tenant>
and<cluster>
with your Dynatrace environment values. To find these values, in Dynatrace Hub, select OneAgent > Set up > z/OS.If the zDC name is defined as
DEFAULT
, the module will connect to the default zDC subsystem ID. To use a different zDC, replaceDEFAULT
with an alternative subsystem ID.You can find the zDC subsystem name in the SYSIN parameters of your JCL SYSIN member
ZDCSYSIN
. The default zDC subsystem name isMEPC
.//SYSIN DD DISP=SHR,DSN=<hlq>.SZDTSAMP(ZDCSYSIN)SUBSYSTEM_ID(MEPC)DEFAULT(YES)If
DEFAULT
is set toYES
in the SYSIN parameters, you can also useDEFAULT
in thedtconfig.json
file.
- EBCDIC 1047, UTF-8, and ASCII encodings are supported for the
dtconfig.json
file. - The module automatically reads
dtconfig.json
when it's placed in the same folder asdynatrace-oneagent-zos-java.jar
. - If you put
dtconfig.json
in a different folder, you need to specify the path to it via the environment variableDT_CONFIG_FILE
. The path must include the filename. You can use an absolute path or a path relative to the working folder of the process.
Installation
Application server
You need to add the z/OS Java module to the JVM arguments of each application server that you want to monitor.
Middleware
You need to add the z/OS Java module to each product that you want to monitor.
JDBC database calls tracing
z/OS Java module version 1.243+ Tracing of JDBC database calls requires an opt-in.
z/OS Java module version 1.251+ Tracing of JDBC database calls is activated per default, no opt-in is required.
To opt-in for JDBC database calls tracing, add DisableJdbctransformer
to your dtconfig.json
file with the value false
. For example
{"DisableJdbctransformer": false}
Only the Db2 JDBC driver types 2 and 4 are supported.
Logging
By default, logging is disabled for the z/OS Java module. To enable logging, add one of the following options to the JVM argument:
Option | Default value | Description |
log-stdout |
| If |
log-stderr |
| If |
log-file |
| If |
If needed, you can log to multiple locations. For example:
-javaagent:/PATH_TO/dynatrace-oneagent-zos-java.jar=log-stdout=true,log-file=true
If needed, you can customize the file logging with the following options:
log-file-dir |
| By default, write log files to the z/OS Java module folder. It's also possible to write the log files to an absolute path (schema: |
By changing the default folder, ensure that the application server has appropriate write permissions for the folder in which the module should write the log files.
OneAgent diagnostics
Dynatrace recommends to write the logs to the shared log folder of the zDC so that they are included into the OneAgent diagnostics workflow. For example, if the dtzagent
binary is located at /u/dt/agent/lib64/dtzagent
in the z/OS USS environment, the log folder is /u/dt/log
. Typically, a shared zDC log folder already exists and contains some zDC logs.
To enable file logging to an absolute path such as the shared zDC log folder /u/dt/log
, specify the JVM argument as follows:
-javaagent:/PATH_TO/dynatrace-oneagent-zos-java.jar=log-file=true,log-file-dir=/u/dt/log
If your zDC is installed in a different location, you must adopt the absolute path of the shared zDC log folder.
Update
To update your z/OS Java module to a newer version
- Download z/OS product datasets and transfer the JAR file (
) to your z/OS USS environment in binary mode. Stop your monitored application server or middleware.
Replace your current JAR file with the new JAR file.
Start your application server or middleware.
Disable sensors of the z/OS Java module
By default, all sensors of the z/OS Java module are enabled. In case of problems, you can disable specific sensors by setting their value to false
in the dt.config.json
file.
{"Sensors": {"Enable": {"CTG": {"Server": "false","Client": "false"},"HttpClient": {"Apache": "false"},"JDBC": "false","JMS": "false","IbmMQ": "false","Servlet": "false","ZosConnect": "false"}}}
