Harness automation and AI to simplify Kubernetes observability at scale.
Dynatrace is the only Kubernetes observability solution for full stack insights and troubleshooting without changing code, container images, or deployments. Dynatrace enables you to monitor Google Kubernetes cluster and workload metrics, events and logs as well as automated distributed tracing for your applications and microservices. Seamless end-to-end traces and AI-powered anomaly detection and root cause analysis will help you excel in your cloud-native journey.
Autopilot is supported with the automatic applicationMonitoring
configuration.
Get started with Google Kubernetes full-stack observability by simply deploying the Dynatrace Operator to the Kubernetes environment.
Please refer the documentation for details.
