Extend the platform,
empower your team.
Get insights into Google Cloud SQL service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Extension by DynatraceThis Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Cloud SQL services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
View and analyze 40 metrics that are specific to Google Cloud SQL, like Auto-failover Requests, Available for failover, CPU reserved cores, and more.
Use dashboard presets for immediate visibility into availability, usage, and performance of your Google Cloud SQL services.
Build custom dashboards for your cloud infrastructure.
Analyze Google Cloud SQL logs.
Use preconfigured alerting.
Set custom alerts that trigger remediation workflows.
Google Cloud SQL metric and log ingestion requires advanced GCP integration.
This extension package contains:
Cloud SQL Database CPU utilization [GCP]
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
Below is a complete list of the feature sets provided in this version. To ensure a good fit for your needs, individual metrics can be activated and deactivated by your administrator during configuration.
Metric name | Metric key | Description | Unit |
Auto-failover Requests | cloud.gcp.cloudsql_googleapis_com.database.auto_failover_request_count | - | Count |
Available for failover | cloud.gcp.cloudsql_googleapis_com.database.available_for_failover | - | Count |
CPU reserved cores | cloud.gcp.cloudsql_googleapis_com.database.cpu.reserved_cores | - | Count |
CPU usage | cloud.gcp.cloudsql_googleapis_com.database.cpu.usage_time.count | - | Second |
CPU utilization | cloud.gcp.cloudsql_googleapis_com.database.cpu.utilization | - | Percent |
Bytes used | cloud.gcp.cloudsql_googleapis_com.database.disk.bytes_used | - | Byte |
Disk quota | cloud.gcp.cloudsql_googleapis_com.database.disk.quota | - | Byte |
Disk read IO | cloud.gcp.cloudsql_googleapis_com.database.disk.read_ops_count | - | Count |
Disk utilization | cloud.gcp.cloudsql_googleapis_com.database.disk.utilization | - | Count |
Disk write IO | cloud.gcp.cloudsql_googleapis_com.database.disk.write_ops_count | - | Count |
Instance state | cloud.gcp.cloudsql_googleapis_com.database.instance_state | - | Unspecified |
Memory quota | cloud.gcp.cloudsql_googleapis_com.database.memory.quota | - | Byte |
Total memory usage | cloud.gcp.cloudsql_googleapis_com.database.memory.total_usage | - | Byte |
Memory usage | cloud.gcp.cloudsql_googleapis_com.database.memory.usage | - | Byte |
Memory utilization | cloud.gcp.cloudsql_googleapis_com.database.memory.utilization | - | Count |
InnoDB dirty pages | cloud.gcp.cloudsql_googleapis_com.database.mysql.innodb_buffer_pool_pages_dirty | - | Count |
InnoDB free pages | cloud.gcp.cloudsql_googleapis_com.database.mysql.innodb_buffer_pool_pages_free | - | Count |
InnoDB total pages | cloud.gcp.cloudsql_googleapis_com.database.mysql.innodb_buffer_pool_pages_total | - | Count |
InnoDB fsync calls | cloud.gcp.cloudsql_googleapis_com.database.mysql.innodb_data_fsyncs.count | - | Count |
InnoDB log fsync calls | cloud.gcp.cloudsql_googleapis_com.database.mysql.innodb_os_log_fsyncs.count | - | Count |
InnoDB pages read | cloud.gcp.cloudsql_googleapis_com.database.mysql.innodb_pages_read.count | - | Count |
InnoDB pages written | cloud.gcp.cloudsql_googleapis_com.database.mysql.innodb_pages_written.count | - | Count |
Queries | cloud.gcp.cloudsql_googleapis_com.database.mysql.queries.count | - | Count |
Questions | cloud.gcp.cloudsql_googleapis_com.database.mysql.questions.count | - | Count |
Network bytes received by MySQL | cloud.gcp.cloudsql_googleapis_com.database.mysql.received_bytes_count | - | Byte |
Available for failover (Deprecated) | cloud.gcp.cloudsql_googleapis_com.database.mysql.replication.available_for_failover | - | Count |
Last I/O thread error number. | cloud.gcp.cloudsql_googleapis_com.database.mysql.replication.last_io_errno | - | Count |
Last SQL thread error number. | cloud.gcp.cloudsql_googleapis_com.database.mysql.replication.last_sql_errno | - | Count |
Replica lag | cloud.gcp.cloudsql_googleapis_com.database.mysql.replication.seconds_behind_master | - | Second |
Slave I/O thread running state | cloud.gcp.cloudsql_googleapis_com.database.mysql.replication.slave_io_running_state | - | Unspecified |
Slave SQL thread running state | cloud.gcp.cloudsql_googleapis_com.database.mysql.replication.slave_sql_running_state | - | Unspecified |
Network bytes sent by MySQL | cloud.gcp.cloudsql_googleapis_com.database.mysql.sent_bytes_count | - | Byte |
Cloud SQL Connections | cloud.gcp.cloudsql_googleapis_com.database.network.connections | - | Count |
Received bytes | cloud.gcp.cloudsql_googleapis_com.database.network.received_bytes_count | - | Byte |
Sent bytes | cloud.gcp.cloudsql_googleapis_com.database.network.sent_bytes_count | - | Byte |
PostgreSQL Connections | cloud.gcp.cloudsql_googleapis_com.database.postgresql.num_backends | - | Count |
Lag bytes | cloud.gcp.cloudsql_googleapis_com.database.postgresql.replication.replica_byte_lag | - | Byte |
Number of transactions | cloud.gcp.cloudsql_googleapis_com.database.postgresql.transaction_count | - | Count |
Replication lag | cloud.gcp.cloudsql_googleapis_com.database.replication.replica_lag | - | Second |
Server up | cloud.gcp.cloudsql_googleapis_com.database.up | - | Count |
Uptime | cloud.gcp.cloudsql_googleapis_com.database.uptime.count | - | Second |
Execution time | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.aggregate.execution_time.count | - | MicroSecond |
IO time | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.aggregate.io_time.count | - | MicroSecond |
Latency | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.aggregate.latencies | - | MicroSecond |
Aggregated lock time | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.aggregate.lock_time.count | - | MicroSecond |
Affected rows | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.aggregate.row_count | - | Count |
Shared blocks cache access | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.aggregate.shared_blk_access_count | - | Count |
Per query execution time | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.perquery.execution_time.count | - | MicroSecond |
Per query IO time | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.perquery.io_time.count | - | MicroSecond |
Per query latency | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.perquery.latencies | - | MicroSecond |
Per query lock time | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.perquery.lock_time.count | - | MicroSecond |
Per query affected rows | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.perquery.row_count | - | Count |
Per query shared blocks cache access | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.perquery.shared_blk_access_count | - | Count |
Per tag execution time | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.pertag.execution_time.count | - | MicroSecond |
Per tag IO time | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.pertag.io_time.count | - | MicroSecond |
Per tag latency | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.pertag.latencies | - | MicroSecond |
Per tag lock time | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.pertag.lock_time.count | - | MicroSecond |
Per tag affected rows | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.pertag.row_count | - | Count |
Per tag shared blocks cache accessed | cloud.gcp.cloudsql_googleapis_com.database.postgresql.insights.pertag.shared_blk_access_count | - | Count |
Support for GCP overview
Now you can enable monitoring of Query insights for PostgreSQL databases. Set of 18 metrics is bundled in a new featureset (postgresinsights).
No release notes
