Extend the platform,
empower your team.
Get insights into Google Cloud Bigtable metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
ExtensionThis Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Bigtable services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
View and analyze 19 metrics that are specific to Google Cloud Bigtable, like CPU load, CPU load (hottest node), Disk load, and more.
Build custom dashboards for your cloud infrastructure.
Analyze Google Cloud Bigtable logs.
Set custom alerts that trigger remediation workflows.
Google Cloud Bigtable metric and log ingestion requires advanced GCP integration.
This extension package contains:
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
Metric name | Metric key | Description | Unit |
CPU load | cloud.gcp.bigtable_googleapis_com.cluster.cpu_load | - | Count |
CPU load (hottest node) | cloud.gcp.bigtable_googleapis_com.cluster.cpu_load_hottest_node | - | Count |
Disk load | cloud.gcp.bigtable_googleapis_com.cluster.disk_load | - | Count |
Nodes | cloud.gcp.bigtable_googleapis_com.cluster.node_count.gauge | - | Count |
Storage utilization | cloud.gcp.bigtable_googleapis_com.cluster.storage_utilization | - | Count |
Data stored | cloud.gcp.bigtable_googleapis_com.disk.bytes_used | - | Byte |
Storage capacity per node | cloud.gcp.bigtable_googleapis_com.disk.per_node_storage_capacity | - | Byte |
Storage capacity | cloud.gcp.bigtable_googleapis_com.disk.storage_capacity | - | Byte |
Replication latencies | cloud.gcp.bigtable_googleapis_com.replication.latency | - | MilliSecond |
Replication maximum delay | cloud.gcp.bigtable_googleapis_com.replication.max_delay | - | Second |
Error count | cloud.gcp.bigtable_googleapis_com.server.error_count | - | Count |
Server Latencies | cloud.gcp.bigtable_googleapis_com.server.latencies | - | MilliSecond |
Modified rows | cloud.gcp.bigtable_googleapis_com.server.modified_rows_count | - | Count |
Multi-cluster failovers | cloud.gcp.bigtable_googleapis_com.server.multi_cluster_failovers_count | - | Count |
Received bytes | cloud.gcp.bigtable_googleapis_com.server.received_bytes_count | - | Byte |
Request count | cloud.gcp.bigtable_googleapis_com.server.request_count | - | Count |
Returned rows | cloud.gcp.bigtable_googleapis_com.server.returned_rows_count | - | Count |
Sent bytes | cloud.gcp.bigtable_googleapis_com.server.sent_bytes_count | - | Byte |
Data stored | cloud.gcp.bigtable_googleapis_com.table.bytes_used | - | Byte |
Support for GCP overview
No release notes
