Extend the platform,
empower your team.
Get insights into Google App Engine service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Extension by DynatraceThis Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google App Engine services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
View and analyze 40 metrics that are specific to Google App Engine, like Monitoring Agent API Request Count, Logging Agent Log Entry Count, Logging Agent Retried Log Entry Writes Count, and more.
Build custom dashboards for your cloud infrastructure.
Analyze Google App Engine logs.
Use preconfigured alerting.
Set custom alerts that trigger remediation workflows.
Google App Engine metric and log ingestion requires advanced GCP integration.
This extension package contains:
Google App Engine Application CPU utilization [GCP], Google App Engine Instance CPU Utilization [GCP]
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
Below is a complete list of the feature sets provided in this version. To ensure a good fit for your needs, individual metrics can be activated and deactivated by your administrator during configuration.
Metric name | Metric key | Description | Unit |
Monitoring Agent API Request Count | cloud.gcp.agent_googleapis_com.agent.gae_app.api_request_count | - | Count |
Logging Agent Log Entry Count | cloud.gcp.agent_googleapis_com.agent.gae_app.log_entry_count | - | Count |
Logging Agent Retried Log Entry Writes Count | cloud.gcp.agent_googleapis_com.agent.gae_app.log_entry_retry_count | - | Count |
Monitoring Agent Memory Usage | cloud.gcp.agent_googleapis_com.agent.gae_app.memory_usage | - | Byte |
Monitoring Agent Metric Point Count | cloud.gcp.agent_googleapis_com.agent.gae_app.monitoring.point_count | - | Count |
Logging Agent API Request Count | cloud.gcp.agent_googleapis_com.agent.gae_app.request_count | - | Count |
Monitoring Agent Process Labels Size | cloud.gcp.agent_googleapis_com.agent.gae_app.streamspace_size | - | Byte |
Monitoring Agent is Throttling Processes | cloud.gcp.agent_googleapis_com.agent.gae_app.streamspace_size_throttling | - | Count |
Monitoring/Logging Agent Uptime | cloud.gcp.agent_googleapis_com.agent.gae_app.uptime.count | - | Second |
Autoscaling Metrics Utilization Capacity | cloud.gcp.appengine_googleapis_com.flex.autoscaler.capacity | - | Count |
Autoscaling Metrics Current Utilization | cloud.gcp.appengine_googleapis_com.flex.autoscaler.current_utilization | - | Count |
Connections | cloud.gcp.appengine_googleapis_com.flex.connections.current | - | Count |
Reserved cores | cloud.gcp.appengine_googleapis_com.flex.cpu.reserved_cores | - | Count |
CPU utilization | cloud.gcp.appengine_googleapis_com.flex.cpu.utilization | - | Percent |
Disk bytes read | cloud.gcp.appengine_googleapis_com.flex.disk.read_bytes_count | - | Byte |
Disk bytes written | cloud.gcp.appengine_googleapis_com.flex.disk.write_bytes_count | - | Byte |
Network bytes received. | cloud.gcp.appengine_googleapis_com.flex.network.received_bytes_count | - | Byte |
Network bytes sent. | cloud.gcp.appengine_googleapis_com.flex.network.sent_bytes_count | - | Byte |
Interception count | cloud.gcp.appengine_googleapis_com.http.server.dos_intercept_count | - | Count |
Quota denial count | cloud.gcp.appengine_googleapis_com.http.server.quota_denial_count | - | Count |
Response count | cloud.gcp.appengine_googleapis_com.http.server.response_count | - | Count |
Response latency | cloud.gcp.appengine_googleapis_com.http.server.response_latencies | - | MilliSecond |
Response count by style | cloud.gcp.appengine_googleapis_com.http.server.response_style_count | - | Count |
Memcache utilization | cloud.gcp.appengine_googleapis_com.memcache.centi_mcu_count | - | Count |
Hit ratio | cloud.gcp.appengine_googleapis_com.memcache.hit_ratio | - | Count |
Memcache operations | cloud.gcp.appengine_googleapis_com.memcache.operation_count | - | Count |
Memcache received bytes | cloud.gcp.appengine_googleapis_com.memcache.received_bytes_count | - | Byte |
Memcache sent bytes | cloud.gcp.appengine_googleapis_com.memcache.sent_bytes_count | - | Byte |
Used Cache Size | cloud.gcp.appengine_googleapis_com.memcache.used_cache_size | - | Byte |
Estimated instance count | cloud.gcp.appengine_googleapis_com.system.billed_instance_estimate_count.gauge | - | Count |
CPU megacycles | cloud.gcp.appengine_googleapis_com.system.cpu.usage | - | Count |
Instance count | cloud.gcp.appengine_googleapis_com.system.instance_count.gauge | - | Count |
Memory usage | cloud.gcp.appengine_googleapis_com.system.memory.usage | - | Byte |
Received bytes | cloud.gcp.appengine_googleapis_com.system.network.received_bytes_count | - | Byte |
Sent bytes | cloud.gcp.appengine_googleapis_com.system.network.sent_bytes_count | - | Byte |
Connections | cloud.gcp.appengine_googleapis_com.flex.instance.connections.current | - | Count |
CPU Utilization | cloud.gcp.appengine_googleapis_com.flex.instance.cpu.utilization | - | Percent |
Network bytes received | cloud.gcp.appengine_googleapis_com.flex.instance.network.received_bytes_count | - | Byte |
Network bytes sent | cloud.gcp.appengine_googleapis_com.flex.instance.network.sent_bytes_count | - | Byte |
Websocket average duration | cloud.gcp.appengine_googleapis_com.flex.instance.ws.avg_duration | - | Second |
Support for GCP overview
No release notes
