Monitor your Fortigate devices via the REST API.
Remotely monitor your Fortigate Fortinet devices via the Fortigate REST API
There are two steps to install an Activegate extension:
Environment Activegate server - Extract the extension zip file to the plugin_deployment folder of the remote plugin module
unzip -o -d /opt/dynatrace/remotepluginmodule/plugin_deployment custom.remote.python.fortigate.zip
/opt/dynatrace
Browser - Upload the custom.remote.python.fortigate.zip
file to your tenant
Settings > Monitored technologies > Custom extensions > Upload extension
Create one endpoint for each device we want to monitor, the parameters are:
Metrics are sent to Custom Devices, those can be accessed via Infrastructure > Technologies and Processes
!{device](https://dt-cdn.net/hub/device.jpg)
