Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Flagsmith JavaScript IntegrationFlagsmith JavaScript Integration
Understand the impact of your feature releases on user behavior in Dynatrace.
Technology by Flagsmith
Documentation
  • Product information
Overview
By connecting Flagsmith's feature flag, remote config and A/B Testing data with Dynatrace's session data, you can learn more about your users. The Flagsmith JavaScript SDK can be configured so a feature's state, remote config and user traits can be stored as Dynatrace session properties. The integration requires a configured Dynatrace dtrum object already set up.
Flagsmith
Documentation
By the partner
Request support
Request information
Copy to clipboard
Dynatrace Hub
Hub HomeGet data into DynatraceBuild your own app
Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
All
0 Results filtered by:
Default empty state
We couldn't find any results
You can search all listings, or try a different spelling or keyword. Still nothing? Dynatrace makes it easy to create custom apps.
Find a partnerLearn to build apps
