Extend the platform,
empower your team.
Gain insights into the performance of your F5 BIG-IP LTM and DNS solutions.
Extension by DynatraceThe F5 BIG-IP extension uses SNMP to collect data remotely. Data is collected from your F5 devices every minute and continuously analyzed by the Dynatrace platform. The insights provided go beyond simple charting capabilities cover both the Local Traffic Manager (LTM) and DNS (formerly Global Traffic Manager) modules of the BIG-IP platform. The unified analysis pages offer insight into the health and performance of the platform, while the Dynatrace analytics engine baselines and alerts on the most important indicators. The topology-first approach allows Davis AI to investigate and correlate detected problems between components and identify root causes.
This is intended for users who:
This enables you to:
Compatibility Requirements
Activate the extension in your environment web-UI using the in-product Hub, provide the necessary device configuration, and you’re all set.
Read more in our SNMP extension documentation.
The extension package contains:
This extension is built on top of the new Extension 2.0 Framework.
More information can be found on the Dynatrace Product News Blog.
Below is a complete list of the feature sets provided in this version. To ensure a good fit for your needs, individual metrics can be activated and deactivated by your administrator during configuration.
Metric name | Metric key | Description | Unit |
Requests | com.dynatrace.extension.f5.bigip.pool.stat.tot.requests.count | The total number of requests to the specified pool. | Count |
Connections | com.dynatrace.extension.f5.bigip.pool.stat.server.tot.conns.count | The total connections from server-side to the specified pool. | Count |
Current sessions | com.dynatrace.extension.f5.bigip.pool.stat.cur.sessions | The current number of sessions to the specified pool. | Count |
Pool member state | com.dynatrace.extension.f5.bigip.gtm.pool_member.state | State metric which captures details of F5 DNS (GTM) Pool Members. Value is always 1. | NotApplicable |
Accepted syn cookies | com.dynatrace.extension.f5.bigip.virtualserver.stat.wl.syncookie.accepts.count | The number of whitelist syn cookies received that were accepted. | Count |
Rejected syn cookies | com.dynatrace.extension.f5.bigip.virtualserver.stat.wl.syncookie.rejects.count | The number of whitelist syn cookies received that were rejected. | Count |
Total swap | com.dynatrace.extension.f5.bigip.mem.total.swap | The total amount of swap space configured for this host. | KiloByte |
Available swap | com.dynatrace.extension.f5.bigip.mem.avail.swap | The amount of swap space currently unused or available. | KiloByte |
Shared memory | com.dynatrace.extension.f5.bigip.mem.shared | The total amount of real or virtual memory currently allocated for use as shared memory. This object will not be implemented on hosts where the underlying operating system does not explicitly identify memory as specifically reserved for this purpose. | KiloByte |
Cached memory | com.dynatrace.extension.f5.bigip.mem.cached | The total amount of real or virtual memory currently allocated for use as cached memory. This object will not be implemented on hosts where the underlying operating system does not explicitly identify memory as specifically reserved for this purpose. | KiloByte |
Buffer memory | com.dynatrace.extension.f5.bigip.mem.buffer | The total amount of real or virtual memory currently allocated for use as memory buffers. This object will not be implemented on hosts where the underlying operating system does not explicitly identify memory as specifically reserved for this purpose. | KiloByte |
Bits received | com.dynatrace.extension.f5.bigip.gtm.virtualserver.bits_persec_in_count | The number of bits per second received by the specified virtual server. | BitPerSecond |
Bits sent | com.dynatrace.extension.f5.bigip.gtm.virtualserver.bits_persec_out_count | The number of bits per second sent by the specified virtual server. | BitPerSecond |
Packets received | com.dynatrace.extension.f5.bigip.gtm.virtualserver.pkts_persec_in_count | The number of packets per second received by the specified virtual server. | PerSecond |
Packets sent | com.dynatrace.extension.f5.bigip.gtm.virtualserver.pkts_persec_out_count | The number of packets per second received by the specified virtual server. | PerSecond |
Connections | com.dynatrace.extension.f5.bigip.gtm.virtualserver.connections_count | The number of total connections to the specified virtual server. | Count |
Bytes received | com.dynatrace.extension.f5.bigip.virtualserver.stat.client.bytes.in.count | The number of bytes received by the specified virtual server from client-side. | Byte |
Ephemeral bytes received | com.dynatrace.extension.f5.bigip.virtualserver.stat.ephemeral.bytes.in.count | The number of bytes received ephemeral by the specified virtual server. | Byte |
Bytes transmitted | com.dynatrace.extension.f5.bigip.virtualserver.stat.client.bytes.out.count | The number of bytes sent to client-side from the specified virtual server. | Byte |
Ephemeral bytes transmitted | com.dynatrace.extension.f5.bigip.virtualserver.stat.ephemeral.bytes.out.count | The number of bytes transmitted ephemeral from the specified virtual server. | Byte |
Packets received | com.dynatrace.extension.f5.bigip.virtualserver.stat.client.pkts.in.count | The number of packets received by the specified virtual server from client-side. | Count |
Ephemeral packets received | com.dynatrace.extension.f5.bigip.virtualserver.stat.ephemeral.pkts.in.count | The number of packets received ephemeral by the specified virtual server. | Count |
Packets transmitted | com.dynatrace.extension.f5.bigip.virtualserver.stat.client.pkts.out.count | The number of packets sent to client-side from the specified virtual server. | Count |
Ephemeral packets transmitted | com.dynatrace.extension.f5.bigip.virtualserver.stat.ephemeral.pkts.out.count | The number of packets transmitted ephemeral from the specified virtual server. | Count |
Total memory | com.dynatrace.extension.f5.bigip.sys.host.memory.total | The total host memory in bytes (not including TMM). This is for a single host system. | Byte |
Used memory | com.dynatrace.extension.f5.bigip.sys.host.memory.used | The host memory in bytes currently in use (not including TMM). This is for a single host system. | Byte |
Wide IP state | com.dynatrace.extension.f5.bigip.gtm.wip.state | State metric which captures the metadata details of an F5 DNS (GTM) Wide IP. The value is always 1. | NotApplicable |
Wide IP to Pool link | com.dynatrace.extension.f5.bigip.gtm.wip.pool_link | Relational metric linking F5 DNS (GTM) Pools to a Wide IP | NotApplicable |
Bytes received | com.dynatrace.extension.f5.bigip.pool_member.stat.server.bytes.in.count | The number of bytes received by the specified pool member from server-side. | Byte |
Bytes transmitted | com.dynatrace.extension.f5.bigip.pool_member.stat.server.bytes.out.count | The number of bytes sent to server-side from the specified pool member. | Byte |
Packets received | com.dynatrace.extension.f5.bigip.pool_member.stat.server.pkts.in.count | The number of packets received by the specified pool member from server-side. | Count |
Packets transmitted | com.dynatrace.extension.f5.bigip.pool_member.stat.server.pkts.out.count | The number of packets sent to server-side from the specified pool member. | Count |
Idle CPU | com.dynatrace.extension.f5.bigip.sys.global.host.cpu.idle1m | The average time spent by the specified processor doing nothing for the system in the last one minute. | Percent |
IO Wait CPU | com.dynatrace.extension.f5.bigip.sys.global.host.cpu.iowait1m | The average time spent by the specified processor waiting for external I/O to complete for the system in the last one minute. | Percent |
IRQ CPU | com.dynatrace.extension.f5.bigip.sys.global.host.cpu.irq1m | The average time spent by the specified processor servicing hardware interrupts for the system in the last one minute. | Percent |
Soft IRQ CPU | com.dynatrace.extension.f5.bigip.sys.global.host.cpu.softirq1min | The average time spent by the specified processor servicing soft interrupts for the system in the last one minute. | Percent |
Stolen CPU | com.dynatrace.extension.f5.bigip.sys.global.host.cpu.stolen1m | The average time 'stolen' from the system in the last one minute. | Percent |
System CPU | com.dynatrace.extension.f5.bigip.sys.global.host.cpu.system1m | The average time spent by the specified processor servicing system calls for the system in the last one minute. | Percent |
User CPU | com.dynatrace.extension.f5.bigip.sys.global.host.cpu.user1m | The average time spent by the specified processor in user context for the system in the last one minute. | Percent |
Ephemeral connections | com.dynatrace.extension.f5.bigip.virtualserver.stat.ephemeral.tot.conns.count | The total ephemeral connections to the specified virtual server. | Count |
Slow connections killed | com.dynatrace.extension.f5.bigip.virtualserver.stat.client.slow.killed.count | The number of slow client-side connections that have been killed on the specified virtual server. | Count |
Evicted connections | com.dynatrace.extension.f5.bigip.virtualserver.stat.client.evicted.conns.count | The number of client-side connections that have been evicted on the specified virtual server. | Count |
Monitor status | com.dynatrace.extension.f5.bigip.pool_member.monitor.status | The hierarchical load balance state for the specified node address, including parent status. Value is always 1. Status dimension takes values: unchecked(0), checking(1), inband(2), up(3), addr-down(18), down(19), forced-down(20), maint(21), irule-down(22), inband-down(23), down-manual-resume(24) | Unspecified |
Pool Member state | com.dynatrace.extension.f5.bigip.pool_member.state | General state metric for the pool_member. Value is always 1, but dimensions 'Enabled state' and 'Availability state' define the state. The availability state takes the following values: 0 (none/error); 1 (green/available in some capacity); 2 (yellow/not currently available); 3 (red/not available); 4 (blue/availability is unknown); 5 (gray/unlicensed). Enabled state takes values 0 (none), 1 (enabled), 2 (disabled), 3 (disabled by parent). | Unspecified |
Common connections | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.tot.compat.conns.count | The total number of concurrent compat connections with established SSL sessions being maintained by the filter. | Count |
Native connections | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.tot.native.conns.count | The total number of concurrent native connections with established SSL sessions being maintained by the filter. | Count |
Fatal alerts | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.fatal.alerts.count | The total number of the fatal alerts. | Count |
DTLSv1 connections | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.dtlsv1.count | The total connections for SSL DTLS protocol version 1. | Count |
DTLSv2 connections | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.sslv2.count | The total connections for SSL protocol version 2. | Count |
SSLv3 connections | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.sslv3.count | The total connections for SSL protocol version 3. | Count |
TLSv1.1 connections.count | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.tlsv11.count | The total connections for SSL TLS protocol version 1.1. | Count |
TLSv1.2 connections | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.tlsv12.count | The total connections for SSL TLS protocol version 1.2. | Count |
TLSv1 connections | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.tlsv1.count | The total connections for SSL TLS protocol version 1. | Count |
Preferred lb requests | com.dynatrace.extension.f5.bigip.gtm.pool.lb_preferred_count | The number of times which the preferred load balance method is used for the specified pool. | Count |
Alternate lb requests | com.dynatrace.extension.f5.bigip.gtm.pool.lb_alternate_count | The number of times which the alternate load balance method is used for the specified pool. | Count |
Fallback lb requests | com.dynatrace.extension.f5.bigip.gtm.pool.lb_fallback_count | The number of times which the fallback load balance method is used for the specified pool. | NotApplicable |
Dropped messages | com.dynatrace.extension.f5.bigip.gtm.pool.dropped_count | The number of dropped DNS messages for the specified pool. | Count |
Return to DNS | com.dynatrace.extension.f5.bigip.gtm.pool.return_to_dns_count | The number of times which a resolve was returned to DNS (for resolution) for the specified pool. | Count |
Return from DNS | com.dynatrace.extension.f5.bigip.gtm.pool.return_from_dns_count | The number of times which a resolve was returned from DNS for the specified pool. | Count |
Requests | com.dynatrace.extension.f5.bigip.gtm.wip.requests_count | The number of total requests for the specified wide IP. | Count |
Resolutions | com.dynatrace.extension.f5.bigip.gtm.wip.resolutions_count | The number of total resolutions for the specified wide IP. | Count |
Persisted requests | com.dynatrace.extension.f5.bigip.gtm.wip.persisted_requests_count | The number of persisted requests for the specified wide IP. | Count |
Preferred lb requests | com.dynatrace.extension.f5.bigip.gtm.wip.lb_preferred_count | The number of times which the preferred load balance method is used for the specified wide IP. | Count |
Fallback lb requests | com.dynatrace.extension.f5.bigip.gtm.wip.lb_fallback_count | The number of times which the fallback load balance method is used for the specified wide IP. | Count |
Alternate lb requests | com.dynatrace.extension.f5.bigip.gtm.wip.lb_alternate_count | The number of times which the alternate load balance method is used for the specified wide IP. | Count |
Dropped messages | com.dynatrace.extension.f5.bigip.gtm.wip.dropped_count | The number of dropped DNS messages for the specified wide IP. | Count |
Return to DNS | com.dynatrace.extension.f5.bigip.gtm.wip.return_to_dns_count | The number of times which a resolve was returned to DNS (for resolution) for the specified wide IP. | Count |
Return from DNS | com.dynatrace.extension.f5.bigip.gtm.wip.return_from_dns_count | The number of times which a resolve was returned from DNS for the specified wide IP. | Count |
CNAME resolutions | com.dynatrace.extension.f5.bigip.gtm.wip.cname_resolutions_count | The number of times which a query is resolved by the CNAME of pools associated with the specified Wide IP. | Count |
Preferred lb requests | com.dynatrace.extension.f5.bigip.gtm.pool_member.lb_preferred_count | The number of times which the preferred load balance method is used for the specified pool member. | Count |
Alternate lb requests | com.dynatrace.extension.f5.bigip.gtm.pool_member.lb_alternate_count | The number of times which the preferred load balance method is used for the specified pool member. | Count |
Fallback lb requests | com.dynatrace.extension.f5.bigip.gtm.pool_member.lb_fallback_count | The number of times which the fallback load balance method is used for the specified pool member. | Count |
Bytes received | com.dynatrace.extension.f5.bigip.pool.stat.server.bytes.in.count | The number of bytes received by the specified pool from server-side. | Byte |
Bytes transmitted | com.dynatrace.extension.f5.bigip.pool.stat.server.bytes.out.count | The number of bytes sent to server-side from the specified pool. | Byte |
Packets received | com.dynatrace.extension.f5.bigip.pool.stat.server.pkts.in.count | The number of packets received by the specified pool from server-side. | Count |
Packets transmitted | com.dynatrace.extension.f5.bigip.pool.stat.server.pkts.out.count | The number of packets sent to server-side from the specified pool. | Count |
Secure handshakes | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.secure.handshakes.count | The number of handshakes, including mid-stream re-negotiations, performed with peers supporting SSL secure renegotiation. | Count |
Handshake failures | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.handshake.failures.count | The total number of handshake failures. | Count |
Profile state | com.dynatrace.extension.f5.bigip.gtm.profile.state | A state metric containing the details of a DNS Profile. The value is always 1, use the dimensions to understand the details. | NotApplicable |
Virtual server state | com.dynatrace.extension.f5.bigip.virtualserver.state | General state metric for the server. Value is always 1, but dimensions carry all details of a virtual server. | Unspecified |
Signature failures | com.dynatrace.extension.f5.bigip.gtm.dnssec.sig_failures_count | Total number of general signature failures. | Count |
RRSET failures | com.dynatrace.extension.f5.bigip.gtm.dnssec.rrset_failures_count | Total number of failures due to an RRSET failing to be signed. | Count |
DNSKEY queries | com.dynatrace.extension.f5.bigip.gtm.dnssec.dnskey_queries_count | Total number of queries for DNSKEY type. | Count |
DNS queries | com.dynatrace.extension.f5.bigip.gtm.profile.queries_count | The total number of DNS queries. | Count |
DNS responses | com.dynatrace.extension.f5.bigip.gtm.profile.responses_count | The total number of DNS responses. | Count |
Cache requests | com.dynatrace.extension.f5.bigip.gtm.profile.to_cache_count | The number of requests sent to the DNS cache. | Count |
DNS requests | com.dynatrace.extension.f5.bigip.gtm.profile.to_dns_count | The number of requests sent to backend DNS. | Count |
Dropped messages | com.dynatrace.extension.f5.bigip.gtm.profile.drops_count | The number of packets dropped (not sent to GTM, DNS-Express, DNSSEC, DNS64, or Backend DNS (e.g. BIND)). | Count |
NOERROR responses | com.dynatrace.extension.f5.bigip.gtm.profile.resp_noerror_count | The number of NOERROR responses sent. | Count |
NXDOMAIN responses | com.dynatrace.extension.f5.bigip.gtm.profile.resp_nxdomain_count | The number of responses whose return code is NXDOMAIN. | Count |
SERVFAIL responses | com.dynatrace.extension.f5.bigip.gtm.profile.resp_servfail_count | The number of responses whose return code is SERVFAIL. | Count |
REFUSED responses | com.dynatrace.extension.f5.bigip.gtm.profile.resp_refused_count | The number of responses whose return code is REFUSED. | Count |
Malicious packets | com.dynatrace.extension.f5.bigip.gtm.profile.malicious_count | The number of malicious packets received. | Count |
Requests | com.dynatrace.extension.f5.bigip.virtualserver.stat.tot.requests.count | The total number of requests going through the specified virtual server. | Count |
CPU Usage | com.dynatrace.extension.f5.bigip.virtualserver.stat.vs.usage.ratio1m | The percentage of time Virtual Server was busy over the last 1 minute. | Percent |
Connections | com.dynatrace.extension.f5.bigip.virtualserver.stat.client.tot.conns.count | The total connections from client-side to the specified virtual server. | Count |
CPU Usage | com.dynatrace.extension.f5.bigip.gtm.virtualserver.cpu_usage_count | The CPU usage in percentage for the specified virtual server. | Percent |
Memory available | com.dynatrace.extension.f5.bigip.gtm.virtualserver.memory_available_count | The memory available in bytes for the specified virtual server. | Byte |
Insecure handshakes accepted | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.insecure.handshake.accepts.count | The number of handshakes, including mid-stream re-negotiations, performed with peers not supporting SSL secure renegotiation. | Count |
Insecure handshakes rejected | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.insecure.handshake.rejects.count | The number of rejected initial handshakes with peers not supporting SSL secure renegotiation. | Count |
Insecure renegotiations rejected | com.dynatrace.extension.f5.bigip.profile.server.ssl.stat.insecure.renegotiation.rejects.count | The number of rejected renegotiation attempts by peers not supporting SSL secure renegotiation. | Count |
GET Requests | com.dynatrace.extension.f5.bigip.profile.http.stat.get.reqs.count | The total number of HTTP get requests. | Count |
POST Requests | com.dynatrace.extension.f5.bigip.profile.http.stat.post.reqs.count | The total number of HTTP post requests. | Count |
2xx Responses | com.dynatrace.extension.f5.bigip.profile.http.stat.resp2xx.cnt.count | The number of server-side responses in range of 200 to 206 (successful responses) | Count |
3xx Responses | com.dynatrace.extension.f5.bigip.profile.http.stat.resp3xx.cnt.count | The number of server-side responses in range of 300 to 307 (redirection responses). | Count |
4xx Responses | com.dynatrace.extension.f5.bigip.profile.http.stat.resp4xx.cnt.count | The number of server-side responses in range of 400 to 417 (client errors). | Count |
5xx Responses | com.dynatrace.extension.f5.bigip.profile.http.stat.resp5xx.cnt.count | The number of server-side responses in range of 500 to 505 (server errors). | Count |
Members | com.dynatrace.extension.f5.bigip.pool.member.cnt | The total number of members in the specified pool. | Count |
Active members | com.dynatrace.extension.f5.bigip.pool.active.member.cnt | The number of the current active members in the specified pool. | Count |
Pool state | com.dynatrace.extension.f5.bigip.pool.state | General state metric for the pool. Value is always 1, but dimensions 'Enabled state' and 'Availability state' define the state. The availability state takes the following values: 0 (none/error); 1 (green/available in some capacity); 2 (yellow/not currently available); 3 (red/not available); 4 (blue/availability is unknown); 5 (gray/unlicensed). Enabled state takes values 0 (none), 1 (enabled), 2 (disabled), 3 (disabled by parent). | Unspecified |
DNS Pool state | com.dynatrace.extension.f5.bigip.gtm.pool.state | State metric which captures details of DNS (GTM) Pools. Value is always 1. | NotApplicable |
Status | com.dynatrace.extension.f5.bigip.sys.interface.status | The current state of the specified interface. | Unspecified |
Bytes received | com.dynatrace.extension.f5.bigip.sys.interface.stat.bytes.in.count | The number of bytes received on the specified interface. | Byte |
Bytes transmitted | com.dynatrace.extension.f5.bigip.sys.interface.stat.bytes.out.count | The number of bytes transmitted out of the specified interface. | Byte |
Packets received | com.dynatrace.extension.f5.bigip.sys.interface.stat.pkts.in.count | The number of packets received on this interface. | Count |
Packets transmitted | com.dynatrace.extension.f5.bigip.sys.interface.stat.pkts.out.count | The number of packets transmitted out of the specified interface. | Count |
Dropped incoming packets | com.dynatrace.extension.f5.bigip.sys.interface.stat.drops.in.count | The number of packets dropped on ingress for various reasons on the specified interface. | Count |
Dropped outgoing packets | com.dynatrace.extension.f5.bigip.sys.interface.stat.drops.out.count | The number of packets aged out or with excessive transmission delays due to multiple deferrals on the specified interface. | Count |
Incoming errors | com.dynatrace.extension.f5.bigip.sys.interface.stat.errors.in.count | The number of received packets that are either undersized, oversized, or have FCS errors by the specified interface. | Count |
Outgoing errors | com.dynatrace.extension.f5.bigip.sys.interface.stat.errors.out.count | The number of excessive collisions, incremented for each frame that experienced 16 collisions during transmission and was aborted on the specified interface. | Count |
Failures | com.dynatrace.extension.f5.bigip.rule.event.stat.failures.count | The number of failures for executing the specified rule. | Count |
Aborts | com.dynatrace.extension.f5.bigip.rule.event.stat.aborts.count | The number of aborts when executing the specified rule. | Count |
Executions | com.dynatrace.extension.f5.bigip.rule.event.stat.total.executions.count | The total number of event executions for the specified rule. | Count |
Common connections | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.tot.compat.conns.count | The total number of concurrent compat connections with established SSL sessions being maintained by the filter. | Count |
Native connections | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.tot.native.conns.count | The total number of concurrent native connections with established SSL sessions being maintained by the filter. | Count |
Fatal alerts | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.fatal.alerts.count | The total number of the fatal alerts. | Count |
Secure handshakes | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.secure.handshakes.count | The number of handshakes, including mid-stream re-negotiations, performed with peers supporting SSL secure renegotiation. | Count |
Handshake failures | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.handshake.failures.count | The total number of handshake failures. | Count |
Insecure handshakes accepted | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.insecure.handshake.accepts.count | The number of handshakes, including mid-stream re-negotiations, performed with peers not supporting SSL secure renegotiation. | Count |
Insecure handshakes rejected | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.insecure.handshake.rejects.count | The number of rejected initial handshakes with peers not supporting SSL secure renegotiation. | Count |
Insecure renegotiations rejected | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.insecure.renegotiation.rejects.count | The number of rejected renegotiation attempts by peers not supporting SSL secure renegotiation. | Count |
DTLSv1 connections | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.dtlsv1.count | The total connections for SSL DTLS protocol version 1.0. | Count |
SSLv2 connections | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.sslv2.count | The total connections for SSL protocol version 2. | Count |
SSLv3 connections | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.sslv3.count | The total connections for SSL protocol version 3. | Count |
TLSv1 connections | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.tlsv1.count | The total connections for SSL TLS protocol version 1. | Count |
TLSv1.1 connections | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.tlsv11.count | The total connections for SSL TLS protocol version 1.1. | Count |
TLSv1.2 connections | com.dynatrace.extension.f5.bigip.profile.client.ssl.stat.tlsv12.count | The total connections for SSL TLS protocol version 1.2. | Count |
Virtual server state | com.dynatrace.extension.f5.bigip.gtm.virtualserver.state | State metric describing the details of a DNS virtual server. The value is always 1, use the dimensions to understand the details. | NotApplicable |
Requests | com.dynatrace.extension.f5.bigip.pool_member.stat.tot.requests.count | The total number of requests going through the specified pool member. | Count |
Connections | com.dynatrace.extension.f5.bigip.pool_member.stat.server.tot.conns.count | The total connections from server-side to the specified pool member. | Count |
Failover and Sync status | com.dynatrace.extension.f5.bigip.sys.cm.state | The failover and config synchronization status of the device. Failover states can be: (0)unknown - the failover status of the device is unknown; (1)offline - the device is offline; (2)forcedOffline - the device is forced offline; (3)standby - the device is standby; (4)active - the device is active. Synchronization status can be: unknown(0), syncing(1), needManualSync(2), inSync(3), syncFailed(4), syncDisconnected(5), standalone(6), awaitingInitialSync(7), incompatibleVersion(8), partialSync(9) | NotApplicable |
Block size | com.dynatrace.extension.f5.bigip.sys.host.disk.block.size | The number of bytes in the specified partition. | Byte |
Total blocks | com.dynatrace.extension.f5.bigip.sys.host.disk.total.blocks | The number of total blocks in the specified partition. | Count |
Free blocks | com.dynatrace.extension.f5.bigip.sys.host.disk.free.blocks | The number of free blocks in the specified partition. | Count |
$prefix(/Common/)
will include for monitoring Pools in the Common partition as well as their pool members.New in this version:
Fixed in this version:
No release notes
Min. Dynatrace version updated to 1.237
Minimum platform requirements:
No release notes
